A solid all-round descender (65.5° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Lightrider E Ultimate 2025
The Thömus Lightrider E Ultimate is the Swiss brand's halo lightweight e-MTB, built around an Ultra High Modulus carbon frame and the maxon BIKEDRIVE AIR drive unit. With a claimed weight from 14.6 kg it is one of the lightest full-suspension electric mountain bikes available, and the headline draw is how little the assistance changes the ride: 40 Nm of peak torque and a 250 W motor peaking over 300 W give a subtle hand on climbs rather than full-power shove.
This is a configurator bike rather than a range of fixed trims. You build it around Shimano SLX, XT or XTR drivetrains and brakes, and a Fox, Marzocchi or DT Swiss fork, so price and weight move with the spec you choose. Power comes from a frame-integrated 250 Wh battery, and the 3.5 kg drive unit lets maxon hide the battery inside the down tube so the bike looks almost indistinguishable from an unpowered Lightrider; an optional second 250 Wh battery roughly doubles the range when you need it.
Geometry is firmly in cross-country and light-trail territory. In the standard 140 mm setup the head angle sits at a steep 66.5 to 66.6 degrees with reach from 431 to 500 mm across the XS/S to L/XL sizes; fitting a 150 mm fork slackens that to 65.5 degrees and raises the front for more confident descending. The XS/S option and roughly 73 degree seat angle make it genuinely usable for smaller and lighter riders, which is rare in this class.
Short 444mm rear and a lighter build — easy to pop, manual and throw around.
Not enough geometry on record to judge size balance.
A workmanlike climber — expect to put in more rider effort on the steep stuff. 280W of peak power and 40Nm of torque.
Easy to throw around; happiest when you're active on the bike.
Lower torque or a slacker seat angle — fine, just don't expect a winch.
How it stacks up vs other Lightweight · Trail bikes (from 87 bikes in the database)
| L/XL | M/L | XS/S | |
| Reach | 500 mm | 466 mm | 431 mm |
| Stack | 628 mm | 615 mm | 601 mm |
| Seattube | 450 mm | 420 mm | 390 mm |
| Chainstay | 445 mm | 444 mm | 445 mm |
| Headtube Angle | 66.5° | 66.5° | 66.6° |
| Seattube Angle (eff) | 72° | 73° | 73.1° |
| Headtube | 125 mm | 110 mm | 95 mm |
Trims · 1
Base £5,630 | |
| Motor | Maxon BIKEDRIVE AIR · 40 Nm |
| Battery | Maxon BIKEDRIVE AIR 250 · 250 Wh |
| Travel F/R | 140/140 mm |
| Frame | Carbon |
| Fork | Customisable: Fox, Marzocchi or DT Swiss, 120-150 mm travel (140 mm standard) |
| Shock | DT Swiss R535 ONE rear shock, 120-140 mm travel (140 mm standard) |
| Stem | Thömus TIC, 60 mm |
| Handlebar | Thömus alloy flat handlebar, 720 mm |
| Saddle | Selle Italia X-Base, black |
| Seatpost | Dropper post, 150 mm (e.g. Shimano LEV-I) |
| Brakes | Hydraulic disc, Shimano (SLX / XT / XTR depending on configuration) |
| Rear derailleur | Shimano 1x12 (SLX / XT / XTR depending on configuration) |
| Crank | 32T chainring |
| Shifters | Shimano 1x12 (SLX / XT / XTR depending on configuration) |
| Cassette | Shimano 10-51T, 12-speed |
| Chain | Shimano 12-speed |
| Drivetrain | Shimano 1x12 (SLX / XT / XTR depending on configuration); 32T chainring; Shimano 1x12 (SLX / XT / XTR depending on configuration); Shimano 10-51T, 12-speed; Shimano 12-speed |
| Wheels | 29 inch (aluminium or carbon depending on configuration) |
| Tyres | Schwalbe Racing Ray / Racing Ralph 2.35 inch, tubeless |
| Weight | 14.6 kg |
| Price | £5,630 |
Rides similarly
Spot a mistake?
