Bike Finder · Thömus
Thömus Lightrider E Ultimate
Thömus
Lightrider E Ultimate 2024
DiscontinuedLightweight · Cross-CountryLegacy · 1.1/10iFreshness 1.1/10
Motor
Maxon BIKEDRIVE AIR · 40Nm · 280W
Battery
Maxon 250Wh integrated
Travel F/R
140/130mm
Wheels
29F / 29R
Frame
Full carbon
Weight
14.8 kg
Price
£0
View the Thömus Lightrider E Ultimate on Thömus’s site
Thömus Lightrider E Ultimate 2024
EMTB Forums verdict
The Lightrider E Ultimate is Thömus's lightweight cross-country and trail eMTB, built around an Ultra High Modulus carbon frame and developed in partnership with fellow Swiss firm maxon. Thömus claims a complete-bike weight of under 15kg, which it pitches as the lightest full-suspension e-mountain bike in the world, riding so close to an unassisted bike that it is hard to tell apart visually.
Drive comes from the maxon BIKEDRIVE AIR system. At just 3.5kg it is a featherweight by motor standards, with 250W nominal power, peaks of over 300W and 40Nm of peak torque, plus a freewheel design that lets assistance fade in and out naturally. The integrated battery is offered in 250Wh or 350Wh, and a 250Wh range extender can be fitted as a second pack for longer days.
Suspension is modest by trail-bike standards, with around 130mm at the rear paired with a front fork that can be specced from cross-country to trail duty. Geometry is offered in three banded sizes (XS/S, M/L, L/XL) across two fork setups: the shorter Cross Country configuration runs a 66.5 to 66.6 degree head angle, while the longer fork option slackens this to 65.5 degrees and lowers the bottom bracket drop, trading a touch of climbing position for more composure on descents. The XS option makes the platform unusually accessible to smaller and lighter riders.
As a bespoke Swiss build-to-order bike, the Lightrider E Ultimate was sold through Thömus's online configurator from a base price of CHF 6'290, with the finishing kit chosen by the buyer rather than fixed into named trims. The model has since been discontinued.
Geometry read
Size
Setting
Descending
58
A solid all-round descender (65.5° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
98
Short 444mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
60
Not enough geometry on record to judge size balance.
Technical climbing
18
A workmanlike climber — expect to put in more rider effort on the steep stuff. 280W of peak power and 40Nm of torque.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
Watch out forClimbing leans on the rider more than the motor.
Lower torque or a slacker seat angle — fine, just don't expect a winch.
How it stacks up vs other Lightweight · Cross-Country bikes (from 63 bikes in the database)
Weight14.8 kg3.8 kg lighter than average
Battery250 Wh185 Wh below average
Motor torque40 Nm19 Nm below average
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
Bike geometry diagram
Flip-chip position
geometry changes with the chip
L/XLM/LXS/S
Reach500 mm466 mm431 mm
Stack628 mm615 mm601 mm
Seattube450 mm420 mm390 mm
Chainstay445 mm444 mm445 mm
Headtube Angle66.5°66.5°66.6°
Seattube Angle (eff)72°73°73.1°
Headtube125 mm110 mm95 mm
Trims · 1
Base
£0
MotorMaxon BIKEDRIVE AIR · 40 Nm
BatteryMaxon 250Wh integrated · 250 Wh
Travel F/R140/130 mm
FrameUltra High Modulus Carbon
Weight14.8 kg
Price£0
Rides similarly
Spot a mistake?
