Bike Finder · Specialized
Specialized Turbo Kenevo
Specialized
Turbo Kenevo 2023
DiscontinuedFull Power · GravityLegacy · 0/10iFreshness 0/10
Motor
Specialized 2.1 · 90Nm · 560W
Battery
Specialized M2-500 · 500Wh
Travel F/R
180/180mm
Wheels
27.5F / 27.5R
Frame
Aluminium
Weight
24.23 kg
Price
From £6,750
View the Specialized Turbo Kenevo on Specialized’s site
Specialized Turbo Kenevo 2023
From £6,750
EMTB Forums verdict
The 2023 Specialized Turbo Kenevo is the full-power, gravity-focused eMTB in the Turbo line, not to be confused with the much lighter Kenevo SL. This was a runout, carryover year for the platform and the model is now discontinued. It runs a full 180mm of travel front and rear on 27.5in wheels, built around a Specialized M5 Premium aluminium frame with the asymmetric Sidearm chassis and a rearward axle path designed to keep momentum over rough ground.
Power comes from the Specialized 2.1 Custom Rx Trail Tuned motor, rated at 90Nm and 565W, paired with a frame-integrated, removable battery: a 500Wh M2-500 pack on the Comp and a larger 700Wh M2-700 pack on the Expert. Geometry is shared across both builds and runs S2 to S5 with reach from 450mm to 525mm, a slack 64.5 degree head angle, a steep 78 degree effective seat angle, a 351mm BB height and a consistent 454mm chainstay.
Two builds were offered. The Comp (GBP 6,750) pairs a 180mm FOX 38 Rhythm fork with a FOX DHX coil shock, Shimano SLX four-piston brakes on 203mm rotors and a Shimano LinkGlide 11-speed drivetrain, with a claimed weight of 24.23kg. The Expert (GBP 8,750) steps up to a dual-crown RockShox BoXXer Select fork and Super Deluxe coil shock, SRAM Code RS brakes on 220mm rotors and a wireless SRAM GX Eagle AXS 12-speed drivetrain, at a claimed 25.0kg. Both roll on Specialized Butcher Grid Gravity T9 27.5 x 2.6in tyres.
As a discontinued model the specification is fixed at this 2023 build, and the figures above are taken from the published manufacturer spec rather than any ride or reliability testing.
Geometry read
Size
Descending
68
A solid all-round descender (64.5° head angle, 180mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
53
Size balance
98
Rear-long with a planted front in S3 (FC:RC 1.78) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
82
Specialized 2.1 and a steep 78° seat angle keep the weight planted over the front — a proper winch. 560W of peak power and 90Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
Watch out forNo major red flags in the S3 geometry.
How it stacks up vs other Full Power · Gravity bikes (from 138 bikes in the database)
Weight24.23 kgabout average weight
Battery500 Wh211 Wh below average
Motor torque90 Nm12 Nm below average
Value for money28/100from £6,750 · comparable bikes ~£5,889
💬 Forum discussion
Specialized Turbo Levo and Kenevo Weight
129 replies · 79.2k views · last reply 47 months ago
Join the discussion →
“My 2019 Turbo Levo Expert weighs in at 19.85kg (43.76 lbs) including the SWAT tool, water bottle cage and pedals. I've done a few things to it, including going from a 700wh battery to a 500wh model. I've also swapped out the wheels for…”
— ofcounsel · ♥ 8 · most-liked post
OWNERS’ REPORT
Specialized Kenevo (2018-2023) — what owners actually know
21,538 posts · 2,416 owners · data through Jul 2026
105GEN 2: 2.1 motor early-life failures and the 4-year warranty extension (motor internals in the Brose/Specialized report) · typical onset: Early life; 500-mile repeat cycles in the worst cases pre-fix.
39Water ingress (both gens; also tracked in the Brose/Specialized report) · typical onset: Wet seasons; pressure-washing accelerates.
30GEN 2: firmware update side effects (7.4.2 era) · typical onset: Immediately post-update.
Specialized handled its biggest motor crisis in public, on this forum, with a CEO letter and a 4-year retroactive warranty; community sentiment flipped from…
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
S2S3S4S5
Reach450 mm475 mm500 mm525 mm
Stack602 mm611 mm620 mm629 mm
Seattube400 mm420 mm440 mm465 mm
Chainstay454 mm454 mm454 mm454 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)78°78°78°78°
Wheelbase1234 mm1263 mm1292 mm1322 mm
Headtube105 mm115 mm125 mm135 mm
BB Height351 mm351 mm351 mm351 mm
Standover799 mm799 mm799 mm799 mm
Front Centre780 mm*809 mm*838 mm*868 mm*
FC:RC1.721.781.851.91
Trims · 2
Comp
£6,750
Expert
£8,750
MotorSpecialized 2.1 · 90 Nm · all trims
BatterySpecialized M2-500 · 500 Wh · all trims
Travel F/R180/180 mm · all trims
FrameSpecialized M5 Premium Aluminum · all trims
ForkFOX 38 Rhythm, Grip damper, 180mm travel, 37mm rakeRockShox Boxxer Select 27.5", 180mm travel, 46mm offset
ShockFOX DHX Performance Series coil. Springs: S2: 450lb, S3: 500lbs, S4: 550lbs, S5: 600lbsRockshox Super Deluxe Coil, 230x62.5mm, S2:450lb, S3:500lb, S4:550lb, S5:600lb
StemAlloy Trail Stem, 35mm bar boreDescendant 35mm Direct Mount Stem, 50mm length
HandlebarSpecialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm widthSpecialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 800mm, 35mm clamp
GripsSpecialized Trail GripsDeity Grips
SaddleBridge Comp, Hollow Cr-mo rails, 155/143mmBridge, 155/143mm, Hollow Ti-rails
SeatpostX-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mmOneUp, Dropper Post-V2, MMX lever, 34.9 (S2:120mm, S3:150mm, S4: 180mm, S5: 210mm)
BrakesFront: Shimano SLX M7120, 4-piston caliper, hydraulic disc, 203mm rotor; Rear: Shimano SLX M7120, 4-piston caliper, hydraulic disc, 203mm rotorFront: SRAM Code RS, 4-piston caliper, hydraulic disc, 220mm; Rear: SRAM Code RS, 4-piston caliper, hydraulic disc, 220mm
Rear derailleurShimano Deore XT LINKGLIDE, 11-speedSRAM GX Eagle AXS, w/ battery cover
CrankPraxis Forged Alloy, 160mm (Chainrings: 32t Praxis, steel)Praxis forged M30, custom offset, 160mm (Chainrings: SRAM X-Sync Eagle, 104BCD, 32T, steel)
ShiftersShimano Deore XT, 11-speedSRAM GX Eagle AXS Controller
CassetteShimano LINKGLIDE, 11-speed, 11-50tSram XG-1275, 12-speed, 10-52t
ChainShimano LINKGLIDE, 11-speedSRAM GX Eagle, 12-speed
DrivetrainShimano Deore XT LINKGLIDE, 11-speed; Praxis Forged Alloy, 160mm (Chainrings: 32t Praxis, steel); Shimano Deore XT, 11-speed; Shimano LINKGLIDE, 11-speed, 11-50t; Shimano LINKGLIDE, 11-speedSRAM GX Eagle AXS, w/ battery cover; Praxis forged M30, custom offset, 160mm (Chainrings: SRAM X-Sync Eagle, 104BCD, 32T, steel); SRAM GX Eagle AXS Controller; Sram XG-1275, 12-speed, 10-52t; SRAM GX Eagle, 12-speed
WheelsRoval 27.5" Alloy DH, 28mm internal width, 32h, tubeless ready · all trims
TyresFront: Butcher Grid Gravity 2Bliss Ready T9, 27.5 x 2.6"; Rear: Butcher Grid Gravity 2Bliss Ready T9, 27.5 x 2.6" · all trims
Weight24.23 kg25 kg
Price£6,750£8,750
Rides similarly
Spot a mistake?
