Bike Finder · Scott
Scott Lumen
Scott
Lumen 2025
CurrentLightweight eMTBLegacy · 2.2/10iFreshness 2.2/10
Lightweight carbon eMTB with TQ HPR50 motor
Motor
TQ HPR50 · 50Nm · 300W
Battery
TQ HPR Battery 360 · 360Wh
Travel F/R
140/130mm
Wheels
29F/29R
Frame
Full carbon
Weight
15.5 kg
Price
From £5,160
View the Scott Lumen on Scott’s site
Scott Lumen 2025
From £5,160
EMTB Forums verdict
The Scott Lumen 2025 is a carbon SL eMTB built around the TQ HPR50 motor and an integrated 360Wh battery. Headline numbers: 130mm fork, 130mm rear, TQ HPR50 at 50Nm and 300W peak from a 1.85kg motor, 17.8kg claimed on the eRIDE 910 entry trim, 65.5 degree head angle and reach 416 to 501mm across seven sized variants. Trim ladder: eRIDE 910 at GBP 6,489, eRIDE 920 at GBP 7,999 (18.1kg) and 900 SL at GBP 13,699. The community read is that the Lumen is one of the quietest, lightest TQ-powered downcountry/trail platforms on sale: @simonsmidt weighs his eRIDE 910 at 17.5kg, even lighter than the manufacturer claim.
Drive system and range. The TQ HPR50 is the lightest credible SL motor on the market: 50Nm of torque, 300W peak and a 1.85kg motor mass. It trades raw torque for an exceptionally low noise floor and a magnetic gearbox that adds a roughly 4kg total system penalty. The 360Wh integrated battery is not removable. @Roaming50 notes the newer HPR60 motor is not yet available in the US market: only the older HPR50 is sold. Range on 360Wh on a 130mm trail bike sits at one and a half to two and a half hours of mixed singletrack in mid-modes. @erider1 reports significant engine braking on the 910 when exceeding 20mph, a side-effect of the current 25mph speed limit programming.
Geometry and handling. 65.5 degrees up front is on the steep side of modern trail eMTB norms: confidently XC-leaning rather than slack and aggressive. Reach steps cleanly: 416 (S/SM), 446 (M/MD), 476 (L/LG), 501 (XL). Chainstays are a uniform 450mm and wheelbase tops out at 1270mm on XL. The single-pivot rear with TwinLoc-style Fox Nude damper integration is one of the Lumen's signatures: @Shark58 notes the traction control position reduces rear travel from 130mm to 90mm and raises the rear for climbing, fully integrated inside the frame.
Build and value. Three trims. eRIDE 910 (GBP 6,489, 17.8kg) is the entry: TQ HPR50 motor, 360Wh battery, RockShox or Fox 34-class fork and the Fox Nude shock with TwinLoc integration. eRIDE 920 (GBP 7,999, 18.1kg) steps up the build kit. The 900 SL (GBP 13,699) is the carbon flagship with top-tier suspension and AXS Transmission. Standout: sub-18kg with a quiet, refined TQ HPR50 platform is among the best SL packages on sale. Questionable: 360Wh non-removable battery limits big-day range; large headset-related gaps reported (see caveats).
Community-verified strengths.
  • Sub-18kg system weight. @simonsmidt confirms 17.5kg weighed reality on the 910, even lower than the claim.
  • Quiet drivetrain. @skizzian describes the TQ motor as "very quiet", a defining Lumen characteristic.
  • Owner upgrade scope. @SaabaruAero on a 905 with carbon rims, XT four-pot brakes, Fox 34 Kashima and Racer's tape protection demonstrates the headroom available to a serious upgrader.
Caveats and known gripes.
  • Motor reliability concern. @Borut reports a Lumen motor failed three times requiring two motor replacements before being sold on.
  • Engine braking above 20mph. @erider1 reports the 910 generates significant engine braking when exceeding 20mph due to current speed limit programming: affects fast descents and road sections.
  • Headset gap issue. @erider1 reports a visible gap around the headset on the eRIDE 910 from new, allowing moisture and debris ingress and shortening headset life. Reported as a design issue, not bike-specific.
  • Crank options. @trailrunnerx notes TQ-compatible crank options are limited, mainly Race Face.
  • 360Wh integrated battery. Not removable; charging on-bike only. No range extender path matches Specialized Levo SL's MasterMind/Range Extender system.
  • HPR60 unavailable in US. @Roaming50 flags the newer-spec HPR60 is not yet sold on the 900 SL in the US, so buyers needing the latest TQ should confirm market availability.
Verdict. The 2025 Lumen is one of the most refined SL trail/downcountry eMTBs on sale, with the quietest TQ HPR50 motor, a sub-18kg carbon frame and seven sized fit options. It suits riders who value the lightest possible eMTB with analogue ride feel, who ride mostly XC, trail centres and moderate natural terrain. Buyers chasing 600Wh-plus battery, slack-and-low geometry or full-power torque should look at the Trek Fuel EXe (HPR60), Specialized Levo SL or full-power Bosch SX rivals. Production status: current.
💬 Forum discussion
Scott Lumen eRide 2023
18 replies · 6.9k views · last reply 29 months ago
Join the discussion →
“There's quite a bit in Knut's article about it.”
— Zimmerframe · ♥ 4 · most-liked post
Bike geometry diagram
SMLXL
Reach416 mm446 mm476 mm501 mm
Stack615 mm615 mm625 mm638 mm
Chainstay450 mm450 mm450 mm450 mm
Headtube Angle65.5°65.5°65.5°65.5°
Seattube Angle (eff)76.8°77°77.2°77.5°
BB Drop39 mm39 mm39 mm39 mm
Wheelbase1176 mm1206 mm1240 mm1270 mm
Headtube110 mm110 mm120 mm135 mm
Standover765 mm767 mm780 mm800 mm
Front Centre726 mm756 mm790 mm820 mm
Trims · 6
920
£5,160
905
£6,450
eRIDE 910
£6,489
eRIDE 920
£7,999
900 SL
£13,699
900
MotorTQ HPR50 · 50 Nm · all trims
BatteryTQ HPR Battery 360 · 360 Wh · all trims
Travel F/R140/130 mm · all trims
FrameCarbon · all trims
ForkRockShox Recon RL 140mmFOX 34 Rhythm 140mmFOX 34 Float Rhythm Air Grip, 3-Modes, Kabolt 15x110mm axle, tapered steerer, 130mm travelRockShox Recon Gold RL Solo Air, 15x110mm axle, tapered steerer, 140mm travelFOX 36SL Factory 140mmFOX 36SL Performance Elite 140mm
ShockX-Fusion Nude, TwinLoc, 130mmFOX Nude 6T EVOL, TwinLoc, 130mmX-Fusion NUDE 5 RLX Trunnion, SCOTT customFOX Nude 6T EVOL, TwinLoc, 130mmFOX Nude 6T EVOL, TwinLoc, 130mm
HeadsetSyncros - Acros Angle adjust & Cable Routing HS System · all trims
StemSyncros DC 2.0, 0° rise, 6061 alloy, 31.8mmSyncros DC 2.0Syncros DC 2.0, 0° rise, alloy, 31.8mmSyncros DC 2.0, 0° rise, 6061 alloy, 31.8mm
HandlebarSyncros Fraser 2.0 DC Alloy 6061 D.B., 760mmSyncros Fraser 2.0 DC Alloy 6061 D.B., 760mmSyncros Fraser 2.0 DC Alloy 6061 D.B., 760mmSyncros Fraser 2.0 DC Alloy 6061 D.B., 760mmSyncros Fraser iC SL DC Carbon, 0° rise, 8° back sweep, 760mmSyncros Fraser iC SL DC Carbon, 8° back sweep, 760mm
GripsSyncros Performance XC lock-on gripsSyncros Performance XC lock-on gripsSyncros Performance XC lock-on gripsSyncros Performance XC lock-on grips
SaddleSyncros Tofino 2.0 RegularSyncros Tofino 2.0 Regular, CRMO railsSyncros Tofino 2.0 Regular, CRMO railsSyncros Tofino 2.0 RegularSyncros Tofino Regular 1.0, Carbon railsSyncros Tofino 1.5 Regular
SeatpostSyncros Dropper Post and PartsSyncros Dropper Post and PartsSyncros Duncan Dropper Post 2.0, 31.6mmSyncros Duncan Dropper Post 2.0, 31.6mmFOX Dropper PostSyncros Dropper Post
BrakesSRAM DB4 4 Piston DiscShimano Deore 4 Piston DiscShimano Deore M6120 4 Piston Disc, 180mm rotorsShimano MT520 4 Piston DiscSRAM Motive Ultimate 4 Piston DiscSRAM Motive Silver 4 Piston Disc
Rear derailleurShimano Deore RD-M6100 SGS, Shadow Plus, 12 SpeedSRAM S1000 Eagle AXS Transmission, 12 SpeedShimano XT RD-M8100 SGS, Shadow Plus, 12 SpeedShimano Deore RD-M6100 SGS, Shadow Plus, 12 SpeedSRAM XX Eagle AXS Transmission, 12 SpeedSRAM GX Eagle AXS Transmission, 12 Speed
CrankFSA Alloy, SCOTT custom spider, 34TFSA Alloy, SCOTT custom spider, SRAM Eagle Transmission 34TFSA Alloy crankset, 175mm, 34TFSA Alloy, SCOTT custom spider, 34Te*thirteen e*spec Race Carbon, 34TFSA Carbon, 175mm, 34T
ShiftersShimano Deore SL-M6100-IR, Rapidfire PlusSRAM AXS Pod ControllerShimano Deore SL-M6100-IR, Rapidfire PlusShimano Deore SL-M6100-IR, Rapidfire PlusSRAM AXS POD Ultimate ControllerSRAM AXS Pod Controller
CassetteShimano CS-M6100, 10-51TSRAM Eagle XS-1270 Transmission, 10-52TShimano CS-M6100, 10-51TShimano CS-M6100, 10-51TSRAM XX Eagle XS-1297 Transmission, 10-52TSRAM GX Eagle XS-1275 Transmission, 10-52T
ChainShimano CN-M6100SRAM GX Eagle TransmissionShimano CN-M6100Shimano CN-M6100
DrivetrainSRAM Eagle 70, 12 SpeedSRAM AXS Transmission 12 SpeedShimano XT RD-M8100 SGS, Shadow Plus, 12 Speed; FSA Alloy crankset, 175mm, 34T; Shimano Deore SL-M6100-IR, Rapidfire Plus; Shimano CS-M6100, 10-51T; Shimano CN-M6100Shimano Deore RD-M6100 SGS, Shadow Plus, 12 Speed; FSA Alloy, SCOTT custom spider, 34T; Shimano Deore SL-M6100-IR, Rapidfire Plus; Shimano CS-M6100, 10-51T; Shimano CN-M6100SRAM XX AXS Transmission 12 SpeedSRAM GX AXS Transmission 12 Speed
WheelsFormula hubs with Syncros X-30S 32H 30mm tubeless-ready rimsFormula hubs with Syncros X-30S 32H 30mm tubeless-ready rimsFormula hubs with Syncros X-30SE 32H 30mm tubeless-ready rimsFormula hubs with Syncros X-30S 32H 30mm tubeless-ready rimsSyncros Silverton SL2 CF WheelsetSyncros Silverton 1.5 TR Wheelset
TyresSchwalbe Wicked WillSchwalbe Wicked WillSchwalbe Wicked Will 29x2.4 EVO, Super Race, TLESchwalbe Wicked Will 29x2.4 EVO, Super Race, TLESchwalbe Wicked WillSchwalbe Wicked Will
Weight18.6 kg17.8 kg18.1 kg15.5 kg15.5 kg
Price£5,160£6,450£6,489£7,999£13,699
Rides similarly
Spot a mistake?
