A solid all-round descender (65.5° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Lumen eRIDE 2026
The Lumen eRIDE is Scott's lightweight Cross-Country and Trail e-MTB, built on a Spark-derived carbon chassis with the shock, motor and battery hidden inside the frame. For 2026 the whole range steps up to TQ's new HPR60 motor, lifting peak torque from 50 to 60Nm while keeping the same featherweight system mass, paired with a 360Wh internal battery and an included 160Wh range extender for up to 520Wh. Travel grows to 140mm up front and 130mm out back via the SCOTT TwinLoc-controlled FOX NUDE shock, and the headline 900 SL build comes in around 16kg.
Four builds cover a wide spread. The carbon HMX 900 SL at GBP 12,999 (claimed 16.0kg) is the flagship, with a FOX 36 SL Factory fork, SRAM XX Eagle AXS Transmission, Motive Ultimate brakes and full-carbon Syncros Silverton SL2 wheels. The 900 (GBP 8,699, 17.0kg) keeps the HMX frame but moves to FOX 36 SL Performance Elite and SRAM GX AXS, the 910 (GBP 7,299, 17.8kg) runs a FOX 34 Rhythm fork with SRAM S1000 AXS and alloy Alex rims, and the 920 (GBP 5,999, 18.5kg) opens the range on a hybrid carbon-front, alloy-rear frame with a RockShox Recon Gold fork and mechanical SRAM Eagle 70.
Geometry is shared across the line and leans modern-trail for an XC-rooted bike: a 65.5 degree head angle (adjustable plus or minus 0.6 degrees through the Acros headset), steep effective seat angles from 76.8 to 77.5 degrees, a consistent 450mm chainstay and a low 338.5mm BB. Reach runs 416 to 501mm across four sizes (S to XL) with wheelbases from 1176 to 1270mm. The combination of sub-19kg builds, full 29in wheels, 140/130mm travel and a discreet mid-power motor positions the Lumen as a down-country-leaning light assist bike rather than a heavy enduro hitter.
Short 450mm rear and a lighter build — easy to pop, manual and throw around.
Rear-long with a planted front in L (FC:RC 1.76) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
TQ HPR60 and a steep 77.2° seat angle keep the weight planted over the front — a proper winch. 350W of peak power and 60Nm of torque.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Lightweight · Cross-Country bikes (from 62 bikes in the database)
| S | M | L | XL | |
| Reach | 416 mm | 446 mm | 476 mm | 501 mm |
| Stack | 615 mm | 615 mm | 625 mm | 638 mm |
| Seattube | 415 mm | 440 mm | 480 mm | 520 mm |
| Chainstay | 450 mm | 450 mm | 450 mm | 450 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 76.8° | 77° | 77.2° | 77.5° |
| Wheelbase | 1176 mm | 1206 mm | 1240 mm | 1270 mm |
| Headtube | 110 mm | 110 mm | 120 mm | 135 mm |
| BB Height | 338.5 mm | 338.5 mm | 338.5 mm | 338.5 mm |
| Standover | 765 mm | 767 mm | 780 mm | 800 mm |
| Front Centre | 726 mm* | 756 mm* | 790 mm* | 820 mm* |
| FC:RC | 1.61 | 1.68 | 1.76 | 1.82 |
Trims · 4
920 £5,999 | 910 £7,299 | 900 £8,699 | 900 SL £12,999 | |
| Motor | TQ HPR60 · 60 Nm · all trims | |||
| Battery | TQ HPR V01 360 · 360 Wh · all trims | |||
| Travel F/R | 140/130 mm · all trims | |||
| Frame | Carbon HMF main frame with alloy SST-CST rear | Carbon HMX | Carbon HMX | Carbon HMX |
| Fork | RockShox Recon Gold RL Solo Air, 15x110mm axle, tapered steerer, Reb. Adj., Lockout, 140mm travel | Fox 34 Rhythm Grip, 3P (3-Modes), Kabolt 15x110mm axle, tapered steerer, 140mm travel | FOX 36SL Performance Elite Air Grip SL, 3-Modes with low Speed adj., Kabolt 15x110mm axle, 44mm offset, tapered steerer, Reb. Adj., Lockout, 140mm travel | FOX 36SL Factory Air, Kashima Grip SL, 3-Modes with low Speed adj., Kabolt 15x110mm axle, 44mm offset, Tapered steerer, Lockout, Reb. Adj., 140mm travel |
| Shock | X-Fusion Nude 5 RLX Trunnion, SCOTT custom w. travel, geo adj., 3 modes: Lockout-Traction Control-Descend, Reb. Adj., T165X45mm | Fox Nude 6 EVOL Trunnion, SCOTT custom w. travel, geo adj., 3 modes: Lockout-Traction Control-Descend, Travel 130-90-Lockout, T165X45mm | FOX NUDE 6T EVOL Trunnion, 3 modes: Lockout-Traction Control-Descend, SCOTT custom w. travel, geo adj., Low Speed Adj., Custom large Air volume, Reb. Adj., Bearing Hardware, Travel 130-90-Lockout, T165X45mm | FOX NUDE 6T Factory EVOL Trunnion, SCOTT custom w. travel, geo adj., 3 modes: Lockout-Traction Control-Descend, Low Speed Adj., Custom large Air volume, Kashima, Reb. Adj., Bearing Hardware, Travel 130-90-Lockout, T165X45mm |
| Headset | Syncros - Acros Angle adjust & Cable Routing HS System, Stainless, +-0.6 degree head angle adjustment, ZS56/28.6 - ZS56/40 MTB | Syncros - Acros, +-0.6 degree head angle adjustment | Syncros - Acros Angle adjust & Cable Routing HS System, Stainless, +-0.6 degree head angle adjustment, ZS56/28.6 - ZS56/40 MTB | Syncros - Acros Angle adjust & Cable Routing HS System, Stainless, +-0.6 degree head angle adjustment, ZS56/28.6 - ZS56/40 MTB |
| Stem | Syncros DC 2.0, Syncros Cable Integration System, 0 degree rise, 6061 alloy, 31.8mm, 1 1/8" | Syncros DC 2.0, 31.8mm, 1 1/8" | Syncros Fraser iC SL DC Carbon one-piece cockpit | Syncros Fraser iC SL DC Carbon one-piece cockpit |
| Handlebar | Syncros Fraser 2.0 DC alloy 6061 D.B. Mini Rise, back sweep 8 degrees, 740mm | Syncros Fraser 2.0 DC alloy, 740mm | Syncros Fraser iC SL DC Carbon, 0 degree rise, back sweep 8 degrees, mini Rise, 760mm | Syncros Fraser iC SL DC Carbon, 0 degree rise, back sweep 8 degrees, mini Rise, 760mm |
| Grips | Syncros Performance XC Lock-On | Syncros Performance XC Lock-On | Syncros Performance XC lock-on grips | Syncros Performance XC lock-on grips |
| Saddle | Syncros Tofino R 1.5 | Syncros Tofino R 1.5 | Syncros Tofino 1.5 Regular, Titanium rails | Syncros Tofino Regular 1.0, Carbon rails |
| Seatpost | Syncros dropper post SP-M302-AL2, 31.6mm | Syncros dropper post SP-M302-AL2, 31.6mm | Syncros Duncan Dropper Post 1.5S, Travel Adjust, 31.6mm (S 140mm / M 160mm / L 180mm / XL 210mm) | FOX Transfer Factory Dropper Post Kashima, 31.6mm (S 120mm / M 150mm / L 180mm / XL 210mm) |
| Brakes | SRAM DB4 4-Piston | SRAM Motive Bronze 4-Piston | SRAM Motive Silver Stealth 4-Piston Disc | SRAM Motive Ultimate Stealth 4-Piston Disc |
| Rear derailleur | SRAM Eagle 70 Transmission, 12 Speed | SRAM S1000 Eagle AXS Transmission 12 Speed | SRAM GX Eagle AXS Transmission 12 Speed, Wireless Electronic Shift System | SRAM XX Eagle AXS Transmission 12 Speed, Wireless Electronic Shift System |
| Crank | Praxis alloy; SRAM 104BCD 34T chainring | Praxis alloy; SRAM 104BCD 34T chainring | SRAM GX Eagle, Alloy; SRAM XX Eagle Transmission 34T chainring; e*thirteen e*spec Slider chainguide | SRAM XX, Carbon; SRAM XX Eagle Transmission 34T chainring; e*thirteen e*spec Slider chainguide |
| Shifters | SRAM Eagle 70 Trigger | SRAM AXS Pod Controller | SRAM AXS Pod Rocker Controller | SRAM AXS Pod Rocker Controller |
| Cassette | SRAM Eagle XS-1270 Transmission, 10-52T | SRAM Eagle XS-1270 Transmission, 10-52T | SRAM GX Eagle XS 1275 Transmission 10-52 | SRAM XX Eagle XS 1297 Transmission 10-52 |
| Chain | SRAM Eagle 70 Transmission | SRAM GX Eagle Transmission | SRAM CN GX Eagle Transmission | SRAM CN XX Eagle Transmission |
| Drivetrain | SRAM Eagle 70 Transmission, 12 Speed; Praxis alloy; SRAM 104BCD 34T chainring; SRAM Eagle 70 Trigger; SRAM Eagle XS-1270 Transmission, 10-52T; SRAM Eagle 70 Transmission | SRAM S1000 Eagle AXS Transmission 12 Speed; Praxis alloy; SRAM 104BCD 34T chainring; SRAM AXS Pod Controller; SRAM Eagle XS-1270 Transmission, 10-52T; SRAM GX Eagle Transmission | SRAM GX Eagle AXS Transmission 12 Speed, Wireless Electronic Shift System; SRAM GX Eagle, Alloy; SRAM XX Eagle Transmission 34T chainring; e*thirteen e*spec Slider chainguide; SRAM AXS Pod Rocker Controller; SRAM GX Eagle XS 1275 Transmission 10-52; SRAM CN GX Eagle Transmission | SRAM XX Eagle AXS Transmission 12 Speed, Wireless Electronic Shift System; SRAM XX, Carbon; SRAM XX Eagle Transmission 34T chainring; e*thirteen e*spec Slider chainguide; SRAM AXS Pod Rocker Controller; SRAM XX Eagle XS 1297 Transmission 10-52; SRAM CN XX Eagle Transmission |
| Wheels | Alex Rims X-30S 32H, Sleeve Joint, Tubeless ready (front and rear) | Alex Rims X-30S 32H, Tubeless ready (front and rear) | Syncros Silverton 1.5-30 CL, F: 15x110mm, R: 12x148mm, 30mm Tubeless ready rim 28H, XD Driver, Syncros Axle w/Removable Lever with 6mm Allen, T30 and T25 Tools | Syncros Silverton SL2-30 CL full Carbon, F: 15x110mm, R: 12x148mm, 30mm Tubeless ready rim, DT Swiss 240 Ratchet EXP 36, XD Driver, SRAM TyreWiz, Syncros SL Axle w/Removable Lever |
| Tyres | (F) Schwalbe Wicked Will EVO, TLE 29 x 2.40 / (R) Schwalbe Wicked Will EVO, TLE 29 x 2.40 | (F) Schwalbe Wicked Will EVO, TLE 29 x 2.40 / (R) Schwalbe Wicked Will EVO, TLE 29 x 2.40 | (F) Schwalbe Wicked Will 29x2.4" EVO, Super Race, TLE, 67EPI, Addix Speed Soft / (R) Schwalbe Wicked Will 29x2.4" EVO, Super Race, TLE, 67EPI, Addix Speed Grip | (F) Schwalbe Wicked Will 29x2.4" EVO, Super Race, TLE, 67EPI, Addix Speed Soft / (R) Schwalbe Wicked Will 29x2.4" EVO, Super Race, TLE, 67EPI, Addix Speed Grip |
| Weight | 18.5 kg | 17.8 kg | 17 kg | 16 kg |
| Price | £5,999 | £7,299 | £8,699 | £12,999 |
Rides similarly
Spot a mistake?
