Bike Finder · Scott
Scott Aspect eRIDE
Scott
Aspect eRIDE 2026
CurrentHardtail eMTBMature · 6.3/10iFreshness 6.3/10
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
25.8 kg
Price
From £3,499
View the Scott Aspect eRIDE on Scott’s site
Scott Aspect eRIDE 2026
From £3,499
Bike geometry diagram
SMLXL
Reach395.5 mm402.8 mm410.1 mm414.8 mm
Stack643.6 mm652.8 mm662.1 mm680.7 mm
Seattube420 mm450 mm480 mm520 mm
Chainstay500 mm500 mm500 mm500 mm
Headtube Angle68°68°68°68°
Seattube Angle (eff)74°74°74°74°
Wheelbase1175.7 mm1186.8 mm1197.8 mm1210 mm
Standover780 mm798 mm819 mm850 mm
Front Centre675.7 mm*686.8 mm*697.8 mm*710 mm*
Trims · 4
Aspect eRIDE 910
£3,499
Aspect eRIDE 910 Wave (low-step)
£3,499
Aspect eRIDE 900
£3,999
Aspect eRIDE 900 Wave (low-step)
£4,099
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube · 800 Wh · all trims
Travel F/R120/? mm · all trims
Frame6061 alloy custom-butted tubing, UDH interface6061 alloy custom-butted tubing, Wave low-step6061 alloy custom-butted tubing6061 alloy custom-butted tubing, Wave low-step
ForkSR Suntour XCM34 RL Coil, tapered, 120mm, 15x110 bolt axleSR Suntour XCM34 RL Coil, tapered, 120mm, 15x110 bolt axle, remote lockoutSR Suntour XCR34X LOR Air, tapered, 120mm, 15x110 bolt axleSR Suntour XCR34X LOR Air, tapered, 120mm, 15x110 bolt axle, remote lockout
HeadsetAcros, 1.5"-1.5" semi integ. OD 50/61mm, ID 44/55mm · all trims
StemSyncros AM2.0, 6061 Alloy, 31.8mm, 0° · all trims
HandlebarSyncros 3.0, 720mm, 31.8mm, 9°, 12mm rise · all trims
GripsSyncros Comfort lock-on grips · all trims
SaddleSyncros Tofino E 2.0 · all trims
SeatpostSyncros M3.0, 31.6mm, 350mm · all trims
BrakesShimano BR-MT420 hydraulic disc, 180/180mm rotors · all trims
Rear derailleurSRAM NX Eagle, 12-speedSRAM NX Eagle, 12-speedShimano Deore RD-M6100 SGS Shadow Plus, 12-speedShimano Deore RD-M6100 SGS Shadow Plus, 12-speed
CrankFSA CK-220, 165mm · all trims
ShiftersSRAM SX Eagle Single Click TriggerSRAM SX Eagle Single Click TriggerShimano Deore Trigger SL-M6100RCShimano Deore Trigger SL-M6100RC
CassetteSRAM PG1210, 11-50TSRAM PG1210, 11-50TShimano CS-M6100, 10-51TShimano CS-M6100, 10-51T
ChainSRAM SX EagleSRAM SX EagleKMC e12SKMC e12S
DrivetrainSRAM NX Eagle, 12-speed; FSA CK-220, 165mm; SRAM SX Eagle Single Click Trigger; SRAM PG1210, 11-50T; SRAM SX EagleSRAM NX Eagle, 12-speed; FSA CK-220, 165mm; SRAM SX Eagle Single Click Trigger; SRAM PG1210, 11-50T; SRAM SX EagleShimano Deore RD-M6100 SGS Shadow Plus, 12-speed; FSA CK-220, 165mm; Shimano Deore Trigger SL-M6100RC; Shimano CS-M6100, 10-51T; KMC e12SShimano Deore RD-M6100 SGS Shadow Plus, 12-speed; FSA CK-220, 165mm; Shimano Deore Trigger SL-M6100RC; Shimano CS-M6100, 10-51T; KMC e12S
WheelsCross X19 rims, 32H, 30mm, Pin Joint · all trims
TyresKenda Booster 29x2.6", 30TPI · all trims
Weight25.8 kg27.7 kg26.7 kg28.6 kg
Price£3,499£3,499£3,999£4,099
Rides similarly
Spot a mistake?
