Bike Finder · Scott
Scott Aspect eRIDE
Scott
Aspect eRIDE 2022
DiscontinuedFull Power · Cross-CountryLegacy · 1/10iFreshness 1/10
Budget full-power hardtail for commuting and light trail use
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
23.4 kg
Price
From £2,449
View the Scott Aspect eRIDE on Scott’s site
Scott Aspect eRIDE 2022
From £2,449
EMTB Forums verdict
The 2022 Aspect eRIDE was Scott's entry-level hardtail eMTB range: one alloy frame with a 120 mm Suntour fork, Bosch mid-drive power and an integrated, removable PowerTube battery, sold in four numbered trims from 940 to 910. Rack and mudguard compatibility, a kickstand mount and pre-installed Bosch light cabling gave it a practical, do-it-all brief alongside light trail duty.
The 920 was the value pick, pairing the full-fat Bosch Performance Line CX motor and 625 Wh battery with a coil fork and SRAM NX/SX Eagle 12-speed for £2,999. The 910 added an air-sprung Suntour XCR34 fork and four-piston Shimano MT420 brakes, while the 930 and 940 stepped down to the weaker Bosch Performance Line and Active Line Plus motors, the 940 also dropping to a 500 Wh battery and 9-speed drivetrain.
Geometry is conservative by trail standards, with a 67.5 degree head angle, long 480 mm chainstays and modest reach figures, suiting stability and comfort over aggressive riding. All trims roll on 29 x 2.6 inch Kenda Booster tyres with 180 mm rotors front and rear.
The range is discontinued; the 2023 Aspect eRIDE that superseded it broadened the line-up again, from a 900 flagship down to a 950.
Geometry read
Size
Descending
48
A solid all-round descender (67.5° head angle, 120mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
63
Size balance
38
Rear-long with a planted front in L (FC:RC 1.50) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
74
Bosch Performance Line CX Gen 4 and a steep 74.9° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
Weight23.4 kgabout average weight
Battery625 Wh61 Wh below average
Motor torque85 Nmabout average torque
Value for money95/100from £2,449 · most Bosch Performance Line CX Gen 4 bikes ~£3,499
Bike geometry diagram
SMLXL
Reach398 mm415 mm433 mm450 mm
Stack637 mm644 mm653 mm663 mm
Seattube400 mm440 mm480 mm520 mm
Chainstay480 mm480 mm480 mm480 mm
Headtube Angle67.5°67.5°67.5°67.5°
Seattube Angle (eff)75.2°75°74.9°74.7°
Wheelbase1160 mm1180 mm1202 mm1222 mm
Headtube110 mm120 mm130 mm140 mm
BB Height320 mm320 mm320 mm320 mm
Standover787 mm809 mm838 mm853 mm
Front Centre680 mm*700 mm*722 mm*742 mm*
FC:RC1.421.461.501.55
Trims · 4
940
£2,449
930
£2,799
920
£2,999
910
£3,349
MotorBosch Active Line Plus · 85 NmBosch Performance Line · 85 NmBosch Performance Line CX Gen 4 · 85 NmBosch Performance Line CX Gen 4 · 85 Nm
BatteryBosch PowerTube 625 · 625 Wh · all trims
Travel F/R120/? mm · all trims
FrameAluminium alloy · all trims
ForkSR Suntour XCM34 Coil, 120 mm, remote lockout, tapered steerer, 15x110 mm QR axleSR Suntour XCM34 Coil, 120 mm, remote lockout, tapered steerer, 15x110 mm QR axleSR Suntour XCM34 Coil, 120 mm, remote lockout, tapered steerer, 15x110 mm QR axleSR Suntour XCR34 Air, 120 mm, remote lockout, tapered steerer, 15x110 mm QR axle
HeadsetSyncros OE, tapered 1.5"-1 1/8", semi-integratedSyncros OE, tapered 1.5"-1 1/8", semi-integratedSyncros OE, tapered 1.5"-1 1/8", semi-integratedSyncros Pro Press Fit E2, tapered 1.5"-1 1/8"
StemSyncros 3.0, 7°, blackSyncros 3.0, 7°, blackSyncros 3.0, 7°, blackSyncros FL2.0 alloy, 6°, integrated top cap, 31.8 mm
HandlebarSyncros 3.0, 720 mm, 12 mm rise, 9°, 31.8 mmSyncros 3.0, 720 mm, 12 mm rise, 9°, 31.8 mmSyncros 3.0, 720 mm, 12 mm rise, 9°, 31.8 mmSyncros Hixon 2.0 alloy, 740 mm, 12 mm rise, 9°
GripsSyncros Comfort lock-on · all trims
SaddleSyncros ER2.5Syncros ER2.5Syncros ER2.5Syncros ER2.0
SeatpostSyncros 3.0, 31.6 mm · all trims
BrakesShimano BR-MT200 hydraulic discShimano BR-MT200 hydraulic discShimano BR-MT200 hydraulic discShimano BR-MT420 4-piston hydraulic disc
Rear derailleurShimano RD-M3100, 9-speedShimano Deore, 10-speedSRAM NX Eagle, 12-speedSRAM NX Eagle, 12-speed
CrankFSA CK-200, 165 mm, FSA WB437 32T w/CG chainringFSA CK-200, 165 mm, FSA WB437 32T w/CG chainringFSA CK-220, 165 mm, SRAM Eagle 36T DM w/CG steel chainringFSA CK-745, 165 mm, SRAM Eagle 36T DM w/CG steel chainring
ShiftersShimano SL-M2000Shimano SL-M4100SRAM SX Eagle Single ClickSRAM SX Eagle Single Click
CassetteShimano CS-HG200-9 Acera, 11-36TShimano CS-M4100 Deore, 11-46TSRAM PG1210, 11-50TSRAM PG1210, 11-50T
ChainKMC e9SKMC e10SSRAM SX EagleSRAM SX Eagle
DrivetrainShimano RD-M3100, 9-speed; FSA CK-200, 165 mm, FSA WB437 32T w/CG chainring; Shimano SL-M2000; Shimano CS-HG200-9 Acera, 11-36T; KMC e9SShimano Deore, 10-speed; FSA CK-200, 165 mm, FSA WB437 32T w/CG chainring; Shimano SL-M4100; Shimano CS-M4100 Deore, 11-46T; KMC e10SSRAM NX Eagle, 12-speed; FSA CK-220, 165 mm, SRAM Eagle 36T DM w/CG steel chainring; SRAM SX Eagle Single Click; SRAM PG1210, 11-50T; SRAM SX EagleSRAM NX Eagle, 12-speed; FSA CK-745, 165 mm, SRAM Eagle 36T DM w/CG steel chainring; SRAM SX Eagle Single Click; SRAM PG1210, 11-50T; SRAM SX Eagle
WheelsSyncros X18, 32H, 30 mm, Pin JointSyncros X18, 32H, 30 mm, Pin JointSyncros MD30, 32H, 30 mm, Pin Joint, tubeless readySyncros MD30, 32H, 30 mm, Pin Joint, tubeless ready
TyresKenda Booster 29x2.6" 30TPI front and rear · all trims
Weight24.3 kg24 kg23.4 kg23.7 kg
Price£2,449£2,799£2,999£3,349
Rides similarly
Spot a mistake?
