Slack 64° head angle, 170mm travel and a long 1267mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Bullit 2022
Lively carbon mullet enduro with even 170mm and premium finish
The 2022 Santa Cruz Bullit is the third-generation Bullit, the brand's full-power mixed-wheel (29in front, 27.5in rear) carbon enduro eMTB. Every build shares the same Carbon CC frame with a lower-link VPP layout, 170mm of travel front and rear, the Shimano STEPS EP8 (DU-EP800) drive unit and a 630Wh battery. Santa Cruz pitched it at terrain beyond even the Nomad and Megatower, and the 38mm-chassis forks and DoubleDown tyres across the range back that up.
The 2022 line ran six builds. The R (£7,499) opens the range with a RockShox Zeb fork, SRAM NX Eagle and SRAM Guide RE brakes. The S (£8,699) moves to a Fox 38 Float Performance fork, SRAM GX Eagle and Code R brakes. The XT and XT Coil (£9,499 each) pair a Fox 38 Performance Elite with a full Shimano XT M8100 groupset and 203mm Ice Tech rotors, the Coil version swapping in a RockShox Super Deluxe Coil Select+. The flagship X01 AXS RSV and X01 AXS RSV Coil (£11,699 each) add a Fox 38 Factory fork, SRAM X01 Eagle AXS wireless shifting, Code RSC brakes and Reserve carbon wheels on Industry Nine hubs.
Geometry is committed enduro fare: a 64-degree head angle on all four sizes (M to XXL), 450mm to 515mm of reach, a 449mm chainstay and a low 348mm bottom bracket. At around 22kg claimed it is a gravity bike first and foremost, with the EP8 and 630Wh pack there to earn the descents.
This model year is discontinued; the same six-build lineup carried into 2023 before the Bullit was later replaced by a new generation.
Short 449mm rear and a lighter build — easy to pop, manual and throw around.
Balanced front-to-rear in L (FC:RC 1.82) — weight sits evenly between the wheels.
Climbs well — a 77.1° seat keeps the front planted. 500W of peak power and 85Nm of torque — a strong full-power motor.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Gravity bikes (from 135 bikes in the database)
| M | L | XL | XXL | |
| Reach | 450 mm | 475 mm | 495 mm | 515 mm |
| Stack | 621 mm | 630 mm | 648 mm | 670.4 mm |
| Seattube | 405 mm | 430 mm | 460 mm | 500 mm |
| Chainstay | 449 mm | 449 mm | 449 mm | 449 mm |
| Headtube Angle | 64° | 64° | 64° | 64° |
| Seattube Angle (eff) | 77.2° | 77.1° | 77° | 76.8° |
| Wheelbase | 1238.5 mm | 1267.9 mm | 1296.7 mm | 1327.7 mm |
| Headtube | 100 mm | 110 mm | 130 mm | 155 mm |
| BB Height | 348 mm | 348 mm | 348 mm | 348 mm |
| Standover | 748 mm | 747 mm | 745 mm | 745 mm |
| Front Centre | 789.5 mm* | 818.9 mm* | 847.7 mm* | 878.7 mm* |
| FC:RC | 1.76 | 1.82 | 1.89 | 1.96 |
Trims · 6
R £7,499 | S £8,699 | XT £9,499 | XT Coil £9,499 | X01 AXS RSV £11,699 | X01 AXS RSV Coil £11,699 | |
| Motor | Shimano EP8 (DU-EP800) · 85 Nm · all trims | |||||
| Battery | Shimano 630Wh Integrated · 630 Wh · all trims | |||||
| Travel F/R | 170/170 mm · all trims | |||||
| Frame | Carbon CC · all trims | |||||
| Fork | RockShox Zeb, 170mm, 29" | FOX 38 Float Performance, 170mm | FOX 38 Float Performance Elite, 170mm | FOX 38 Float Performance Elite E-Tune, 170mm, 29" | FOX 38 Float Factory, 170mm | FOX 38 Float Factory, 170mm |
| Shock | RockShox Super Deluxe Select | RockShox Super Deluxe Select+ | RockShox Super Deluxe Select+ | RockShox Super Deluxe Coil Select+ (400 S, 450 M, 500 L-XL, 550 XXL) | RockShox Super Deluxe Ultimate | RockShox Super Deluxe Coil Ultimate (400 S, 450 M, 500 L-XL, 550 XXL) |
| Headset | Cane Creek 10 IS Integrated Headset | Cane Creek 40 IS Integrated Headset | Cane Creek 40 IS Integrated Headset | Cane Creek 40 IS Integrated Headset | Cane Creek 40 IS Integrated Headset | Cane Creek 40 IS Integrated Headset |
| Stem | e.13 Base | Burgtec Enduro MK3, 42.5mm | Burgtec Enduro MK3, 42.5mm | Burgtec Enduro MK3, 42.5mm | Burgtec Enduro MK3, 42.5mm | Burgtec Enduro MK3, 42.5mm |
| Handlebar | E13 TRS Base | Santa Cruz e35 Carbon Bar, 800mm, 35mm Rise | Santa Cruz e35 Carbon Bar, 800mm, 35mm Rise | Santa Cruz e35 Carbon Bar, 800mm, 35mm Rise | Santa Cruz e35 Carbon Bar, 800mm, 35mm Rise | Santa Cruz e35 Carbon Bar, 800mm, 35mm Rise |
| Grips | Santa Cruz House Grips or Burgtec Bartender Pro Grip Minnaar · all trims | |||||
| Saddle | WTB Silverado Race Saddle or WTB Volt | WTB Silverado Medium Cromoly SL Fusion Saddle or WTB Volt | WTB Silverado Medium Cromoly SL Fusion Saddle or WTB Volt | WTB Silverado Medium Cromoly SL Fusion Saddle or WTB Volt | WTB Silverado Medium Stainless Fusion Saddle or WTB Volt | WTB Silverado Medium Stainless Fusion Saddle or WTB Volt |
| Seatpost | SDG Tellis Dropper, 31.6 | SDG Tellis Dropper, 31.6 | Fox Transfer Performance Elite | Fox Transfer Performance Elite | Fox Transfer Factory | Fox Transfer Factory |
| Brakes | SRAM Guide RE; rotors: Avid Centerline 220mm front / 200mm rear | SRAM Code R; rotors: Avid Centerline 220mm front / 200mm rear | Shimano XT 8120; rotors: Shimano XT, Ice Tech, Centerlock, 203mm | Shimano XT 8120; rotors: Shimano XT, Ice Tech, Centerlock, 203mm | SRAM Code RSC; rotors: Avid Centerline 220mm front / 200mm rear | SRAM Code RSC; rotors: Avid Centerline 220mm front / 200mm rear |
| Rear derailleur | SRAM NX Eagle, 12spd | SRAM GX Eagle, 12spd | Shimano XT M8100, 12spd | Shimano XT M8100, 12spd | SRAM X01 Eagle AXS, 12spd | SRAM X01 Eagle AXS, 12spd |
| Crank | Shimano EM600 Crank Arms 165mm | Shimano EM600 Crank Arms, 165mm | Shimano XT M8150 Crank Arms, 165mm | Shimano XT M8150 Crank Arms, 165mm | Shimano EM900 HollowTech Crank Arms, 165mm | Shimano EM900 HollowTech Crank Arms, 165mm |
| Shifters | SRAM NX | SRAM GX Eagle Single Click, 12spd | Shimano XT M8100, 12spd | Shimano XT M8100, 12spd | SRAM GX AXS Controller | SRAM GX AXS Controller |
| Cassette | SRAM PG1210, 12spd, 11-50t | SRAM XG1275 Eagle, 12spd, 10-50t | Shimano XT M8100, 12spd, 10-51t | Shimano XT M8100, 12spd, 10-51t | SRAM XG1295 Eagle 10-50T | SRAM XG1295 Eagle 10-50T |
| Chain | SRAM NX Eagle, 12spd | SRAM GX Eagle, 12spd | Shimano XT, 12spd | Shimano XT, 12spd | SRAM X01 Eagle, 12spd | SRAM X01 Eagle, 12spd |
| Drivetrain | SRAM NX Eagle, 12spd; Shimano EM600 Crank Arms 165mm; SRAM NX; SRAM PG1210, 12spd, 11-50t; SRAM NX Eagle, 12spd | SRAM GX Eagle, 12spd; Shimano EM600 Crank Arms, 165mm; SRAM GX Eagle Single Click, 12spd; SRAM XG1275 Eagle, 12spd, 10-50t; SRAM GX Eagle, 12spd | Shimano XT M8100, 12spd; Shimano XT M8150 Crank Arms, 165mm; Shimano XT M8100, 12spd; Shimano XT M8100, 12spd, 10-51t; Shimano XT, 12spd | Shimano XT M8100, 12spd; Shimano XT M8150 Crank Arms, 165mm; Shimano XT M8100, 12spd; Shimano XT M8100, 12spd, 10-51t; Shimano XT, 12spd | SRAM X01 Eagle AXS, 12spd; Shimano EM900 HollowTech Crank Arms, 165mm; SRAM GX AXS Controller; SRAM XG1295 Eagle 10-50T; SRAM X01 Eagle, 12spd | SRAM X01 Eagle AXS, 12spd; Shimano EM900 HollowTech Crank Arms, 165mm; SRAM GX AXS Controller; SRAM XG1295 Eagle 10-50T; SRAM X01 Eagle, 12spd |
| Wheels | WTB ST i30 TCS 2.0 (29" F, 27.5" R) | RaceFace ARC HD 30 (29" F, 27.5" R) | RaceFace ARC HD 30 (29" F, 27.5" R) | RaceFace ARC HD 30 (29" F, 27.5" R) | Reserve 30 29 Carbon (front), Reserve Carbon DH 27.5 Carbon (rear) | Reserve 30 29 Carbon (front), Reserve Carbon DH 27.5 Carbon (rear) |
| Tyres | Front: Maxxis Assegai 29"x2.5", 3C, MaxxGRIP, Double Down, TR; Rear: Maxxis Minion DHR II 27.5"x2.4, 3C, DoubleDown, EXO, TR · all trims | |||||
| Weight | 22.57 kg | 22.47 kg | 21.99 kg | 22.49 kg | 22.26 kg | 22.61 kg |
| Price | £7,499 | £8,699 | £9,499 | £9,499 | £11,699 | £11,699 |
Rides similarly
Spot a mistake?
