A solid all-round descender (65.5° head angle, 144mm) — capable in the rough and steep without being an all-out bruiser.
R.X735 2023
The Rotwild R.X735 is the German marque's full-power all-mountain eMTB on the IPU735 carbon platform, built around a handmade high-modulus carbon frame with 150 mm front and 144 mm rear travel on 29in wheels. A Shimano EP801 motor (85 Nm) is fed by the quick-release Rotwild IPU735 720 Wh carbon-housed battery, and the geometry is contemporary all-mountain: 65.5 degree head angle, 75 degree seat angle, 450 mm chainstays across all four sizes, and reach growing 430 to 500 mm from S to XL.
Three trims were offered. The Core (EUR 7,999) pairs Fox Performance suspension with Magura MT5 brakes and a mechanical Shimano XT drivetrain, claimed at 22.8 kg in size L. The Pro (EUR 9,499) steps up to a Fox 36 Performance Elite fork and Shimano XT Di2 electronic shifting. The Ultra (EUR 12,499) is the showpiece, with Kashima-coated Fox Factory suspension, Shimano XTR brakes, XTR cassette and carbon e*thirteen finishing kit, with a quoted weight of 21.2 kg.
This is a EUR-native range with no UK storefront, so pricing stays in euros. It is discontinued: the R.X735 nameplate continued into later model years with updated specs, so this 2023 build is no longer current.
Short 450mm rear and a lighter build — easy to pop, manual and throw around.
Rear-long with a planted front in L (FC:RC 1.78) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Shimano EP801 and a steep 75° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Trail bikes (from 248 bikes in the database)
| S | M | L | XL | |
| Reach | 430 mm | 450 mm | 475 mm | 500 mm |
| Stack | 625 mm | 625 mm | 643 mm | 652 mm |
| Seattube | 410 mm | 440 mm | 470 mm | 506 mm |
| Chainstay | 450 mm | 450 mm | 450 mm | 450 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 75° | 75° | 75° | 75° |
| Wheelbase | 1200 mm | 1219 mm | 1253 mm | 1282 mm |
| Headtube | 110 mm | 110 mm | 130 mm | 140 mm |
| BB Height | 345 mm | 345 mm | 345 mm | 345 mm |
| Standover | 729 mm | 729 mm | 729 mm | 729 mm |
| Front Centre | 750 mm* | 769 mm* | 803 mm* | 832 mm* |
| FC:RC | 1.67 | 1.71 | 1.78 | 1.85 |
Trims · 3
Core €7,999 | Pro €9,499 | Ultra €12,499 | |
| Motor | Shimano EP801 · 85 Nm · all trims | ||
| Battery | Rotwild IPU 720Wh · 720 Wh · all trims | ||
| Travel F/R | 150/144 mm · all trims | ||
| Frame | Full carbon (handmade high-modulus carbon fibre) · all trims | ||
| Fork | FOX 36 Float Performance, 150 mm / Fit Grip 3-POS Micro Adjust / E-Tuned | Fox 36 Float Performance Elite, 150 mm / Fit4 / 3-POS Micro Adjust / E-Tuned | FOX 36 Float Factory Kashima, 150 mm / Fit 4 3-POS Adjust / E-Tuned |
| Shock | FOX Float X Performance, 210 x 52.5 mm / 3-Pos. Adjust | Fox Float X Performance, 210 x 52.5 mm / 3-Pos. adjust | FOX Float X Factory Kashima, 210 x 52.5 mm / 3-Pos Adjust |
| Headset | ACROS RW735 1.5 | ACROS RW735 1.5 Headset W/ Blocklock (Size S) | ACROS RW735 1.5 Headset W/ Blocklock (Size S) |
| Stem | e*thirteen Plus, O35 mm / 50 mm / AL7050 I.C.R. · all trims | ||
| Handlebar | e*thirteen Plus, O35 mm / 20 mm Rise / 780 mm Width / AL7050 I.C.R | e*thirteen Plus, O35 mm / 20 mm Rise / 780 mm Width / AL7050 I.C.R | e*thirteen Race Carbon, O35 mm / 20 mm Rise / 780 mm Width / I.C.R |
| Grips | ERGON GD10 Slim Factory Frozen | Ergon GD10 Slim | ERGON GD10 Slim Factory Frozen |
| Saddle | ERGON SM SPORT | ERGON SM COMP | ERGON SM30 PRO / ERGON SM Pro |
| Seatpost | 8PINS H01, O34.9 mm / 25 mm Offset / 145 mm (S) / 160 mm (M) / 180 mm (L) / 200 mm (XL) | Eightpins H01, O34.9 mm / 25 mm Offset / 145 mm (S) / 160 mm (M) / 180 mm (L) / 200 mm (XL) | 8PINS NGS 2, O34.9 mm / 25 mm Offset / 170 mm (S) / 190 mm (M) / 210 mm (L) / 230 mm (XL) |
| Brakes | MAGURA MT5 HC-W (front) / MAGURA MT5 Shiftmix (rear) | SHIMANO XT 8120 Fin Pad | SHIMANO XTR 9120 Fin Pad |
| Rear derailleur | SHIMANO XT 8100, 12-Speed / SGS / Hyperglide+ | SHIMANO XT Di2 8150 SGS HYPERGLIDE+ | SHIMANO XT Di2 8150 SGS HYPERGLIDE+ |
| Crank | e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL) | e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL) | e*thirteen Race Carbon, 160 mm (S) / 165 mm (M, L) / 170 mm (XL) |
| Shifters | SHIMANO XT 8100 I-Spec EV | SHIMANO XT I-Spec EV / SHIMANO XT Di2 8150 | SHIMANO XT Di2 8150 I-Spec EV |
| Cassette | SHIMANO CS 6100, 10-51 T. / 12-Speed | SHIMANO CS 7100, 10-51 T. / 12-Speed | SHIMANO XTR 9100, 10-51 T. / 12-Speed |
| Chain | SHIMANO HG 7100, 12-Speed · all trims | ||
| Drivetrain | SHIMANO XT 8100, 12-Speed / SGS / Hyperglide+; e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); SHIMANO XT 8100 I-Spec EV; SHIMANO CS 6100, 10-51 T. / 12-Speed; SHIMANO HG 7100, 12-Speed | SHIMANO XT Di2 8150 SGS HYPERGLIDE+; e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); SHIMANO XT I-Spec EV / SHIMANO XT Di2 8150; SHIMANO CS 7100, 10-51 T. / 12-Speed; SHIMANO HG 7100, 12-Speed | SHIMANO XT Di2 8150 SGS HYPERGLIDE+; e*thirteen Race Carbon, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); SHIMANO XT Di2 8150 I-Spec EV; SHIMANO XTR 9100, 10-51 T. / 12-Speed; SHIMANO HG 7100, 12-Speed |
| Wheels | CRANKBROTHERS Synthesis Enduro (31.5/29.5) / 110-15/148-12 TAS / 6-Bolt | Crankbrothers Synthesis Enduro I9 (31.5/29.5) / 110-15/148-12 TAS / CL | CRANKBROTHERS Synthesis Enduro I9 (31.5/29.5) / 110-15/148-12 TAS / CL |
| Tyres | SCHWALBE Magic Mary / Hans Dampf, EVO Super Ground / Trail TLE Soft 29 x 2.40 (f.) 29 x 2.35 (r.) · all trims | ||
| Weight | 22.8 kg | — | 21.2 kg |
| Price | €7,999 | €9,499 | €12,499 |
Rides similarly
Spot a mistake?
