Bike Finder · Rotwild
Rotwild R.X375
Rotwild
R.X375 2023
DiscontinuedFull Power · TrailLegacy · 0.4/10iFreshness 0.4/10
Motor
Shimano EP8 (DU-EP800) · 85Nm · 500W
Battery
Rotwild IPU 360Wh Carbon
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Full carbon
Weight
19.1 kg
Price
From €8,499
View the Rotwild R.X375 on Rotwild’s site
Rotwild R.X375 2023
EMTB Forums verdict
The Rotwild R.X375 was the German marque's lightweight trail/all-mountain eMTB, billed as the 'trail king'. It paired a full-power Shimano EP8 (85 Nm) drive unit with a deliberately small, handmade carbon IPU375 battery (rated 360 Wh) to keep weight down to a claimed 19.1 kg in Ultra trim. The handmade high-modulus carbon frame ran 150 mm front and 140 mm rear on 29in wheels.
Geometry was identical across all four sizes (S to XL): a 66.5 degree head angle, 75.5 degree effective seat angle, a long 450 mm chainstay, reach from 430 to 500 mm and a constant 345 mm BB height. That is a moderate, balanced trail stance rather than an aggressive enduro number, in keeping with the bike's 'more person, less machine' pitch.
Three trims spanned a wide price range: Core at 8,499 EUR (Magura MT5 brakes, Shimano XT mechanical drivetrain, Fox 36 Performance), Pro at 9,499 EUR (Shimano XT 8120 brakes, Fox 36 Performance/Performance Elite, I9 wheels) and Ultra at 12,499 EUR (full Shimano XTR, Fox Factory Kashima suspension, Crankbrothers Synthesis Carbon wheels, Eightpins NGS 2 integrated dropper). All used the same frame, motor and battery, so the premium buys lighter, higher-end finishing kit rather than more capability.
The R.X375 is discontinued. It is a niche choice: small-battery range was always the trade-off for the low weight, and Rotwild is a EUR-native brand with no UK storefront, so pricing was only ever quoted in euros.
Geometry read
Size
Descending
53
A solid all-round descender (66.5° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
94
Short 450mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
93
Rear-long with a planted front in L (FC:RC 1.75) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
75
Shimano EP8 (DU-EP800) and a steep 75.5° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Trail bikes (from 245 bikes in the database)
Weight19.1 kg3.9 kg lighter than average
Battery360 Wh344 Wh below average
Motor torque85 Nm13 Nm below average
Bike geometry diagram
SMLXL
Reach430 mm450 mm475 mm500 mm
Stack618 mm620 mm636 mm645 mm
Seattube410 mm440 mm470 mm506 mm
Chainstay450 mm450 mm450 mm450 mm
Headtube Angle66.5°66.5°66.5°66.5°
Seattube Angle (eff)75.5°75.5°75.5°75.5°
Wheelbase1184 mm1205 mm1237 mm1266 mm
Headtube110 mm110 mm130 mm140 mm
BB Height345 mm345 mm345 mm345 mm
Standover730 mm730 mm730 mm730 mm
Front Centre734 mm*755 mm*787 mm*816 mm*
FC:RC1.631.681.751.81
Trims · 3
Core
€8,499
Pro
€9,499
Ultra
€12,499
MotorShimano EP8 (DU-EP800) · 85 Nm · all trims
BatteryRotwild IPU 360Wh Carbon · 360 Wh · all trims
Travel F/R150/140 mm · all trims
FrameHigh Modulus Carbon · all trims
ForkFox 36 Float Performance, 150 mm / Fit Grip 3-POS Micro Adjust / E-TunedFox 36 Float Performance or Performance Elite, 150 mm / FIT4 3-POS Adjust / E-TunedFox 36 Float Factory Kashima, 150 mm / Fit 4 3-POS Adjust / E-Tuned
ShockFox Float DPS Performance, 210 x 50 mm / 3-POSFox Float DPS Performance, 210 x 50 mm / 3-POSFox Float DPS Factory Kashima, 210 x 50 mm / 3-POS / EVOL / EV
HeadsetACROS RW375 1.5 Headset w/ Blocklock · all trims
Steme*thirteen Plus (35 mm / 50 mm / AL7050 I.C.R.) or ROTWILD S140 (35 mm / 50 mm / AL7075)e*thirteen Plus (35 mm / 50 mm / AL7050 I.C.R.) or ROTWILD S140 (35 mm / 50 mm / AL7075)ROTWILD S140, 35 mm / 50 mm / AL7075
Handlebare*thirteen Plus (35 mm / 20 mm Rise / 780 mm / AL7050 I.C.R) or ROTWILD B280 (35 mm / 35 mm Rise / 780 mm / AL7075)e*thirteen Plus (35 mm / 20 mm Rise / 780 mm / AL7050 I.C.R) or ROTWILD B280 (35 mm / 35 mm Rise / 780 mm / AL7075)ROTWILD B220 Carbon, 35 mm / 15 mm Rise / 780 mm Width
GripsERGON GD10 Slim Factory Frozen · all trims
SaddleERGON SM10 StealthERGON SM Pro or ERGON SM CompErgon SM Pro
SeatpostEightpins H01, 34.9 mm / 25 mm Offset / 145 mm (S) / 160 mm (M) / 180 mm (L) / 200 mm (XL)Eightpins H01, 34.9 mm / 25 mm Offset / 145 mm (S) / 160 mm (M) / 180 mm (L) / 200 mm (XL)Eightpins NGS 2, 34.9 mm / 25 mm Offset / 170 mm (S) / 190 mm (M) / 210 mm (L) / 230 mm (XL)
BrakesMAGURA MT5 HC-W; rotors: MAGURA MDR-P, 203 mm / 180 mmSHIMANO XT 8120, Fin Pad; rotors: SHIMANO RT800/810, Sensor ICE 203/180SHIMANO XTR 9120, Fin Pad; rotors: SHIMANO RT900/910, Sensor ICE 203/180
Rear derailleurShimano XT 8100, 12-Speed / SGS / Hyperglide+Shimano XT 8100, 12-Speed / SGS / Hyperglide+Shimano XTR 9100, 12-Speed / Hyperglide+
Cranke*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); e*thirteen Direct Mount Chainring 34 t.; e*thirteen TRS chain guidee*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); e*thirteen Direct Mount Chainring 34 t.; e*thirteen TRS chain guidee*thirteen Race Carbon, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); e*thirteen Direct Mount Chainring 34 t.; e*thirteen TRS chain guide
ShiftersSHIMANO XT, I-Spec EV · all trims
CassetteSHIMANO CS 6100, 10-51 t. / 12-SpeedSHIMANO CS 7100, 10-51 T. / 12-SpeedSHIMANO XTR 9100, 10-51 T. / 12-Speed
ChainSHIMANO HG 7100, 12-Speed · all trims
DrivetrainShimano XT 8100, 12-Speed / SGS / Hyperglide+; e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); e*thirteen Direct Mount Chainring 34 t.; e*thirteen TRS chain guide; SHIMANO XT, I-Spec EV; SHIMANO CS 6100, 10-51 t. / 12-Speed; SHIMANO HG 7100, 12-SpeedShimano XT 8100, 12-Speed / SGS / Hyperglide+; e*thirteen Plus, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); e*thirteen Direct Mount Chainring 34 t.; e*thirteen TRS chain guide; SHIMANO XT, I-Spec EV; SHIMANO CS 7100, 10-51 T. / 12-Speed; SHIMANO HG 7100, 12-SpeedShimano XTR 9100, 12-Speed / Hyperglide+; e*thirteen Race Carbon, 160 mm (S) / 165 mm (M, L) / 170 mm (XL); e*thirteen Direct Mount Chainring 34 t.; e*thirteen TRS chain guide; SHIMANO XT, I-Spec EV; SHIMANO XTR 9100, 10-51 T. / 12-Speed; SHIMANO HG 7100, 12-Speed
WheelsCrankbrothers Synthesis Enduro (31.5/29.5) / 110-15/148-12 TAS / 6-BoltCrankbrothers Synthesis Enduro I9 (31.5/29.5) / 110-15/148-12 TAS / CLCrankbrothers Synthesis Enduro I9 Carbon (31.5/29.5) / 110-15 / 148-12 TAS / CL
TyresSCHWALBE Nobby Nic Evo, TLE / 29 x 2.4 / Super Ground / Speedgrip or Soft & SpeedgripSCHWALBE Nobby Nic Evo, TLE / 29 x 2.4 / Super Ground / Speedgrip or Soft & SpeedgripSCHWALBE Nobby Nic Evo, TLE / 29 x 2.4 / Super Ground / Speedgrip
Weight19.1 kg
Price€8,499€9,499€12,499
Rides similarly
Spot a mistake?
