Bike Finder · Rotwild
Rotwild R.X375
Rotwild
R.X375 2022
DiscontinuedFull Power · TrailLegacy · 0.4/10iFreshness 0.4/10
Trim carbon all-mountain bike with a small battery and light feel
Motor
Shimano EP8 (DU-EP800) · 85Nm · 500W
Battery
Rotwild IPU375 375 · 375Wh
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Full carbon
Weight
Price
From €7,499
View the Rotwild R.X375 on Rotwild’s site
Rotwild R.X375 2022
EMTB Forums verdict
The Rotwild R.X375 was the German brand's lightweight all-mountain eMTB for 2022, built around a handmade high-modulus carbon frame, a Shimano EP8 motor and a compact 375 Wh IPU375 carbon battery. Rotwild pitched it as the king of the trail: 150 mm of fork travel and 140 mm out back on 29in wheels, with a low weight and lively handling aimed at riders who want an analogue mountain bike feel with just a bit of assistance.
Geometry is modern-trail rather than radical, with a 66.5 degree head angle, 75.5 degree effective seat angle, a consistent 450 mm chainstay and reach spanning 430 to 500 mm across S to XL. The quick-release carbon battery drops out tool-free for easy charging or swapping.
Three trims covered a wide spread: the Core (7,499 EUR) on FOX Performance suspension with Magura MT5 brakes, the Pro (8,999 EUR) stepping up to a full Shimano XT drivetrain and I9 wheels, and the flagship Ultra (11,999 EUR) with FOX Factory Kashima, Shimano XTR and Crankbrothers Synthesis carbon wheels.
The R.X375 is now discontinued. Rotwild has since revised its lightweight line, but the original 2022 R.X375 remains a genuinely light, short-travel carbon eMTB for riders who prize agility over outright range.
Geometry read
Size
Descending
53
A solid all-round descender (66.5° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
51
Size balance
93
Rear-long with a planted front in L (FC:RC 1.75) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
75
Shimano EP8 (DU-EP800) and a steep 75.5° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Trail bikes (from 271 bikes in the database)
Battery375 Wh329 Wh below average
Motor torque85 Nm13 Nm below average
Bike geometry diagram
SMLXL
Reach430 mm450 mm475 mm500 mm
Stack618 mm620 mm636 mm645 mm
Seattube410 mm440 mm470 mm506 mm
Chainstay450 mm450 mm450 mm450 mm
Headtube Angle66.5°66.5°66.5°66.5°
Seattube Angle (eff)75.5°75.5°75.5°75.5°
Wheelbase1184 mm1205 mm1237 mm1266 mm
Headtube110 mm110 mm130 mm140 mm
BB Height345 mm345 mm345 mm345 mm
Standover730 mm730 mm730 mm730 mm
Front Centre734 mm*755 mm*787 mm*816 mm*
FC:RC1.631.681.751.81
Trims · 3
Core
€7,499
Pro
€8,999
Ultra
€11,999
MotorShimano EP8 (DU-EP800) · 85 Nm · all trims
BatteryRotwild IPU375 375 · 360 Wh · all trims
Travel F/R150/140 mm · all trims
FrameCarbon · all trims
ForkFOX 36 FLOAT PERFORMANCE 150 MM / FIT GRIP 3-POS MICRO ADJUST / E-TUNEDFOX 36 FLOAT PERFORMANCE 150 MM / FIT GRIP 3-POS MICRO ADJUST / E-TUNEDFOX 36 FLOAT FACTORY KASHIMA 150 MM / FIT4 3-POS ADJUST / E-TUNED
ShockFOX FLOAT DPS PERFORMANCE 210 X 50 MM / 3-POSFOX FLOAT DPS PERFORMANCE 210 X 50 MM / 3-POSFOX FLOAT DPS FACTORY KASHIMA 210 X 50 MM / 3-POS
HeadsetACROS RW375 1.5 HEADSET W/ BLOCKLOCK · all trims
StemROTWILD S140 AL7075 Ø35 MM / 50 MM · all trims
HandlebarROTWILD B280 AL7075 Ø35 MM / 15 MM RISE / 780 MM WIDTHROTWILD B220 CARBON Ø35 MM / 15 MM RISE / 780 MM WIDTHROTWILD B220 CARBON Ø35 MM / 15 MM RISE / 780 MM WIDTH
GripsERGON GD10 SLIM FACTORY FROZEN · all trims
SaddleERGON SM · all trims
SeatpostE*THIRTEEN VARIO COVERT INFINITE INDIVIDUAL UP TO 260 MM (XL)EIGHTPINS H01 Ø34.9 mm / 25 mm OFFSET / 145 mm (S) / 160 mm (M) / 180 mm (L) / 200 mm (XL)EIGHTPINS NGS 2 Ø34.9 MM / 25 mm OFFSET / 170 mm (S) / 190 mm (M) / 210 mm (L) / 230 mm (XL)
BrakesMAGURA MT5 HC-W SHIFT MIXSHIMANO XT 8120 FIN PADSHIMANO XTR 9120 FIN PAD
Rear derailleurSHIMANO XT 8100 12-SpeedSHIMANO XT 8100 12-SpeedSHIMANO XTR 9100 12-Speed
CrankE*THIRTEEN PLUS 160 mm (S) / 165 mm (M, L) / 170 mm (XL)E*THIRTEEN PLUS 160 mm (S) / 165 mm (M, L) / 170 mm (XL)E*THIRTEEN RACE CARBON 160 mm (S) / 165 mm (M, L) / 170 mm (XL)
ShiftersSHIMANO XT I-SPEC EV · all trims
CassetteSHIMANO CS 6100 10-51 T. / 12-SPEEDSHIMANO CS 7100 10-51T. 12-SPEEDSHIMANO XTR 9100 10-51T. 12-SPEED
DrivetrainSHIMANO XT 8100 12-Speed; E*THIRTEEN PLUS 160 mm (S) / 165 mm (M, L) / 170 mm (XL); SHIMANO XT I-SPEC EV; SHIMANO CS 6100 10-51 T. / 12-SPEEDSHIMANO XT 8100 12-Speed; E*THIRTEEN PLUS 160 mm (S) / 165 mm (M, L) / 170 mm (XL); SHIMANO XT I-SPEC EV; SHIMANO CS 7100 10-51T. 12-SPEEDSHIMANO XTR 9100 12-Speed; E*THIRTEEN RACE CARBON 160 mm (S) / 165 mm (M, L) / 170 mm (XL); SHIMANO XT I-SPEC EV; SHIMANO XTR 9100 10-51T. 12-SPEED
WheelsCRANKBROTHERS SYNTHESIS ENDURO (31.5/29.5) / 110-15/148-12 TAS / 6-BOLTCRANKBROTHERS SYNTHESIS ENDURO I9 (31,5/29,5) / 110-15/148-12 TAS / CLCRANKBROTHERS SYNTHESIS ENDURO I9 CARBON (31.5/29.5) / 110-15/148-12 TAS / CL
TyresSCHWALBE NOBBY NIC EVO SUPER GROUND TLE SPEEDGRIP 29x2.4 · all trims
Price€7,499€8,999€11,999
Rides similarly
Spot a mistake?
