R.X275 2026
The Rotwild R.X275 is the brand's lightweight, app-controlled "Athletic" eMTB built around the compact TQ HPR50 harmonic-drive motor. With 130 mm of fork travel, 120 mm at the rear via a bearing-free flexstay carbon rear end, and a claimed 15.3 kg in top ULTRA spec, it is pitched at the downcountry-to-trail rider who wants subtle assistance rather than full power. The 252 Wh integrated IPU275 battery is small by class standards, supplemented by an optional range extender that lives in a bottle position.
All three builds share the same carbon frame, TQ motor, 252 Wh battery and Schwalbe Nobby Nic / Wicked Will tyre pairing, so the money buys suspension and drivetrain upgrades. The CORE (EUR 7,990) runs Shimano XT and FOX Performance Elite suspension at a claimed 16.2 kg. The PRO (EUR 8,990) steps up to XTR shifting and braking on the same alloy DT Swiss wheels and Performance Elite suspension. The ULTRA (EUR 9,990) adds FOX Factory Kashima fork and shock, carbon DT Swiss HXC1501 wheels, an e*thirteen Race Carbon crank and Rotwild's one-piece RIC280 carbon cockpit to hit the headline 15.3 kg.
Geometry is consistent and conservative for the category: a 66 degree head angle, 75.5 degree effective seat angle, short 437 mm chainstays across all four sizes and reach from 430 mm (S) to 510 mm (XL) on full 29 inch wheels. That points to an agile, climbing-focused machine rather than a slack descender. Note that Rotwild sells direct in euros and there is no UK GBP RRP; pricing here is the manufacturer EUR figure.
| S | M | L | XL | |
| Reach | 430 mm | 460 mm | 485 mm | 510 mm |
| Stack | 618 mm | 627 mm | 636 mm | 645 mm |
| Seattube | 400 mm | 430 mm | 460 mm | 490 mm |
| Chainstay | 437 mm | 437 mm | 437 mm | 437 mm |
| Headtube Angle | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 75.5° | 75.5° | 75.5° | 75.5° |
| Wheelbase | 1174 mm | 1207 mm | 1237 mm | 1266 mm |
| Headtube | 110 mm | 120 mm | 130 mm | 140 mm |
| BB Height | 337.5 mm | 337.5 mm | 337.5 mm | 337.5 mm |
| Standover | 738 mm | 738 mm | 738 mm | 738 mm |
| Front Centre | 737 mm* | 770 mm* | 800 mm* | 829 mm* |
Trims · 3
CORE | PRO | ULTRA | |
| Motor | TQ HPR50 · 50 Nm · all trims | ||
| Battery | Rotwild IPU275 · 252 Wh · all trims | ||
| Travel F/R | 130/120 mm · all trims | ||
| Frame | Carbon · all trims | ||
| Fork | FOX 34 Float Performance Elite, 130 mm / FIT4 / 3-Pos Adjust | FOX 34 Float Performance Elite, 130 mm / FIT4 / 3-Pos Adjust | FOX 34 Float Factory Kashima, 130 mm / FIT4 / 3-Pos Adjust |
| Shock | FOX Float DPS Performance, 190 x 45 mm / 3-Pos | FOX Float DPS Performance, 190 x 45 mm / 3-Pos | FOX Float DPS Factory Kashima, 190 x 45 mm / 3-Pos Adjust |
| Headset | ACROS RW375 1.5 · all trims | ||
| Stem | ROTWILD S140 | ROTWILD S140, 35 mm / 50 mm / AL7075 | ROTWILD RIC280 Carbon, integrated stem and bar / 50 mm |
| Handlebar | ROTWILD B280 | ROTWILD B220 Carbon, 35 mm / 15 mm Rise / 780 mm | ROTWILD RIC280 Carbon, integrated stem and bar / 15 mm Rise / 780 mm |
| Grips | ERGON GD10 | ERGON GD10 Slim Factory Frozen | ERGON GD10 Slim Factory Frozen |
| Saddle | ERGON SM Sport | ERGON SM Sport | ERGON SM Pro Carbon |
| Seatpost | FOX Transfer SL Performance Elite, 31.6 mm | FOX Transfer SL Performance Elite, 31.6 mm / up to 150 mm (XL) | FOX Transfer SL Factory Kashima, 31.6 mm / up to 150 mm (XL) |
| Brakes | SHIMANO XT 8120 (front) / XT 8110 (rear) | SHIMANO XTR 9100 Fin Pad (front and rear) | SHIMANO XTR 9100 Fin Pad (front) / XTR 9110 Flat Mount (rear) |
| Rear derailleur | SHIMANO XT 8100, 12-Speed | SHIMANO XTR 9100 SGS, 12-Speed / Hyperglide+ | SHIMANO XTR 9100 SGS, 12-Speed / Hyperglide+ |
| Crank | e*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide | e*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide | e*thirteen Race Carbon, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide |
| Shifters | SHIMANO XT 8100 | SHIMANO XTR 9100, I-Spec EV | SHIMANO XTR 9100, I-Spec EV |
| Cassette | SHIMANO CS 7100, 10-51T / 12-Speed | SHIMANO CS 7100, 10-51T / 12-Speed | SHIMANO CS 9100, 10-51T / 12-Speed |
| Chain | SHIMANO HG 7100, 12-Speed · all trims | ||
| Drivetrain | SHIMANO XT 8100, 12-Speed; e*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide; SHIMANO XT 8100; SHIMANO CS 7100, 10-51T / 12-Speed; SHIMANO HG 7100, 12-Speed | SHIMANO XTR 9100 SGS, 12-Speed / Hyperglide+; e*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide; SHIMANO XTR 9100, I-Spec EV; SHIMANO CS 7100, 10-51T / 12-Speed; SHIMANO HG 7100, 12-Speed | SHIMANO XTR 9100 SGS, 12-Speed / Hyperglide+; e*thirteen Race Carbon, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide; SHIMANO XTR 9100, I-Spec EV; SHIMANO CS 9100, 10-51T / 12-Speed; SHIMANO HG 7100, 12-Speed |
| Wheels | DT SWISS HX1700 LS Spline (30), alloy, front and rear | DT SWISS HX1700 LS Spline (30), alloy, front and rear | DT SWISS HXC1501 LS Spline1 Carbon, OS 30 / Ratchet EXP |
| Tyres | SCHWALBE Nobby Nic Evo 29x2.4 (front) / SCHWALBE Wicked Will Evo 29x2.4 (rear) | SCHWALBE Nobby Nic Evo Super Ground Soft TLE 29x2.4 (front) / SCHWALBE Wicked Will Evo Super Race Speed TLE 29x2.4 (rear) | SCHWALBE Nobby Nic Evo Super Ground Soft TLE Aerothan 29x2.4 (front) / SCHWALBE Wicked Will Evo Super Race Speed TLE Aerothan 29x2.4 (rear) |
| Weight | 16.2 kg | 16.3 kg | 15.3 kg |
Rides similarly
Spot a mistake?
