Bike Finder · Rotwild
Rotwild R.X275
Rotwild
R.X275 2025
CurrentLightweight eMTBMature · 6.1/10iFreshness 6.1/10
Motor
TQ HPR50 · 50Nm · 300W
Battery
Rotwild IPU275 · 252Wh
Travel F/R
130/120mm
Wheels
29F / 29R
Frame
Full carbon
Weight
15.3 kg
View the Rotwild R.X275 on Rotwild’s site
Rotwild R.X275 2025
EMTB Forums verdict
The Rotwild R.X275 is the German marque's lightweight TQ-powered trail eMTB, built around a handmade high-modulus carbon frame and the quiet, compact TQ HPR50 motor. With 130 mm of fork travel and 120 mm at the rear, plus a full 29in wheelset, it sits firmly in the light-and-lively category rather than the big-hitting enduro space. The headline figure is weight: the range tops out at a claimed 15.3 kg for the ULTRA, which makes it one of the lightest full-power-feel trail eMTBs available.
Geometry is measured rather than radical: a 66 degree head angle, 75.5 degree effective seat angle and short 437 mm chainstays across all four sizes point to an agile, climb-happy bike. Reach runs from 430 mm (S) to 510 mm (XL), so sizing is conventional. The 252 Wh integrated IPU275 battery and 50 Nm motor mean this is a bike that rewards a strong rider with eco-friendly assistance and an on-demand Boost button rather than one that flatters with raw grunt.
The three builds share the same frame, motor and geometry, so the choice is purely about kit. The CORE (EUR 7,990) runs a Shimano XT drivetrain, FOX Performance suspension and alloy wheels at a claimed 16.2 kg. The PRO (EUR 8,990) steps up to XTR shifting and brakes for a marginal weight change. The ULTRA (EUR 9,990) is where the weight tumbles, adding FOX Factory Kashima suspension, full XTR, DT Swiss carbon wheels, e*thirteen Race Carbon cranks and Rotwild's integrated RIC280 carbon cockpit to reach the headline 15.3 kg.
Note that Rotwild has no UK distributor, so prices are quoted in euros and a buyer would be importing. For riders chasing the lightest possible trail eMTB with a natural, rider-led power delivery, the R.X275 is a credible alternative to the likes of the TQ-powered Trek Fuel EXe and Scott Lumen.
Bike geometry diagram
SMLXL
Reach430 mm460 mm485 mm510 mm
Stack618 mm627 mm636 mm645 mm
Seattube400 mm430 mm460 mm490 mm
Chainstay437 mm437 mm437 mm437 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)75.5°75.5°75.5°75.5°
Wheelbase1174 mm1207 mm1237 mm1266 mm
Headtube110 mm120 mm130 mm140 mm
BB Height337.5 mm337.5 mm337.5 mm337.5 mm
Standover738 mm738 mm738 mm738 mm
Front Centre737 mm*770 mm*800 mm*829 mm*
Trims · 3
CORE
PRO
ULTRA
MotorTQ HPR50 · 50 Nm · all trims
BatteryRotwild IPU275 · 252 Wh · all trims
Travel F/R130/120 mm · all trims
FrameCarbon · all trims
ForkFOX 34 Float Performance Elite, 130 mm, FIT4, 44 mm offset, 110x15 mmFOX 34 Float Performance Elite, 130 mm, FIT4, 3-Pos AdjustFOX 34 Float Factory Kashima, 130 mm, FIT4, 3-Pos Adjust
ShockFOX Float DPS Performance, 190 x 45 mm, 3-PosFOX Float DPS Performance, 190 x 45 mm, 3-PosFOX Float DPS Factory Kashima, 190 x 45 mm, 3-Pos Adjust
HeadsetACROS RW375 1.5 · all trims
StemROTWILD S140ROTWILD S140, 35 mm, 50 mm, AL7075ROTWILD RIC280 Carbon, integrated stem and bar, 50 mm Length
HandlebarROTWILD B280ROTWILD B220 Carbon, 35 mm, 15 mm Rise, 780 mm WidthROTWILD RIC280 Carbon, integrated stem and bar, 15 mm Rise, 780 mm Width
GripsERGON GD10ERGON GD10 Slim Factory FrozenERGON GD10 Slim Factory Frozen
SaddleERGON SM SportERGON SM SportERGON SM Pro Carbon
SeatpostFOX Transfer SL Performance EliteFOX Transfer SL Performance Elite, 31.6 mm, up to 150 mm (XL)FOX Transfer SL Factory Kashima, 31.6 mm, up to 150 mm (XL)
BrakesSHIMANO XT 8120 (front) / SHIMANO XT 8110 (rear)SHIMANO XTR 9100 Fin Pad (front and rear)SHIMANO XTR 9100 Fin Pad (front) / SHIMANO XTR 9110 Flat Mount (rear)
Rear derailleurSHIMANO XT 8100, 12-SpeedSHIMANO XTR 9100 SGS, 12-Speed, Hyperglide+SHIMANO XTR 9100 SGS, 12-Speed, Hyperglide+
Cranke*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring, e*thirteen TRS chain guidee*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guidee*thirteen Race Carbon, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide
ShiftersSHIMANO XT 8100SHIMANO XTR 9100, I-Spec EVSHIMANO XTR 9100, I-Spec EV
CassetteSHIMANO CS 7100, 10-51 T, 12-SpeedSHIMANO CS 7100, 10-51 T, 12-SpeedSHIMANO CS 9100, 10-51 T, 12-Speed
ChainSHIMANO HG 7100, 12-Speed · all trims
DrivetrainSHIMANO XT 8100, 12-Speed; e*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring, e*thirteen TRS chain guide; SHIMANO XT 8100; SHIMANO CS 7100, 10-51 T, 12-Speed; SHIMANO HG 7100, 12-SpeedSHIMANO XTR 9100 SGS, 12-Speed, Hyperglide+; e*thirteen Plus, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide; SHIMANO XTR 9100, I-Spec EV; SHIMANO CS 7100, 10-51 T, 12-Speed; SHIMANO HG 7100, 12-SpeedSHIMANO XTR 9100 SGS, 12-Speed, Hyperglide+; e*thirteen Race Carbon, 165 mm (S) / 170 mm (M, L, XL), e*thirteen Direct Mount Chainring 34T, e*thirteen TRS chain guide; SHIMANO XTR 9100, I-Spec EV; SHIMANO CS 9100, 10-51 T, 12-Speed; SHIMANO HG 7100, 12-Speed
WheelsDT SWISS HX1700 LS Spline (30)DT SWISS HX1700 LS Spline (30)DT SWISS HXC1501 LS Spline1 Carbon, OS 30, Ratchet EXP
TyresSCHWALBE Nobby Nic Evo Super Ground Soft 29x2.4 (front) / SCHWALBE Wicked Will Evo Super Race Speed 29x2.4 (rear), TLESCHWALBE Nobby Nic Evo Super Ground Soft 29x2.4 (front) / SCHWALBE Wicked Will Evo Super Race Speed 29x2.4 (rear), TLESCHWALBE Nobby Nic Evo Super Ground Soft 29x2.4 Aerothan (front) / SCHWALBE Wicked Will Evo Super Race Speed 29x2.4 Aerothan (rear), TLE
Weight16.2 kg16.3 kg15.3 kg
Rides similarly
Spot a mistake?
