Bike Finder · Rotwild
Rotwild R.X1000
Rotwild
R.X1000 2024
DiscontinuedFull Power · TrailLegacy · 1.8/10iFreshness 1.8/10
Motor
Pinion MGU (E1.12) · 85Nm · 600W
Battery
FIT IPU1000 Ultracore 960 · 960Wh
Travel F/R
150/150mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
Price
From €9,999
View the Rotwild R.X1000 on Rotwild’s site
Rotwild R.X1000 2024
EMTB Forums verdict
The 2024 Rotwild R.X1000 was the German brand's flagship full-power all-mountain eMTB and its most unconventional bike, built entirely around Pinion's E1.12 Motor-Gearbox-Unit (MGU). The MGU houses motor and 12-speed electronic gearbox together at the bottom bracket, so the R.X1000 runs no rear derailleur or cassette: power reaches a 27.5in rear wheel through a single Pinion X1 Longlife chain. Rotwild quotes 85 Nm and up to 600 W, a 960 Wh FIT IPU1000 Ultracore battery and four support levels with SMART.SHIFT electronic shifting.
It is a handmade high-modulus carbon frame with a 29in front / 27.5in rear mullet layout, 150 mm of travel front and rear, and short 445 mm chainstays across all four sizes thanks to Rotwild's Open Bridge Triangle rear end. Geometry is all-mountain rather than enduro: a 66 degree head angle, 74 degree seat angle and reach running 405 mm (S) to 500 mm (XL), with a tall 350 mm bottom bracket and 1172 to 1270 mm wheelbase aimed at climbing and big-day touring.
Two trims were offered. The Pro (from 9,999 euro) ran Fox 36 / Float X Performance suspension, an alloy bar and DT Swiss H1900 wheels; the Ultra (from 11,999 euro) stepped up to Fox Factory Kashima suspension, a Rotwild carbon bar, Ergon SM Pro saddle and DT Swiss HX1501 wheels. Both shared Magura MT5 HC-W brakes on 203 mm rotors and Schwalbe Magic Mary / Hans Dampf rubber.
The R.X1000 is discontinued. Rotwild has since moved its R.X1000 line onto the FS designation for 2025, so this Pinion-MGU generation is best understood as the original first-generation R.X1000.
Geometry read
Size
Descending
55
A solid all-round descender (66° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
63
Size balance
98
Rear-long with a planted front in L (FC:RC 1.78) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
66
Climbs well — a 74° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Trail bikes (from 238 bikes in the database)
Battery960 Wh254 Wh above average
Motor torque85 Nm13 Nm below average
Bike geometry diagram
SMLXL
Reach405 mm437 mm468 mm500 mm
Stack610 mm617 mm637 mm648 mm
Seattube413 mm444 mm473 mm509 mm
Chainstay445 mm445 mm445 mm445 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)74°74°74°74°
Wheelbase1172 mm1198 mm1236 mm1270 mm
Headtube110 mm110 mm130 mm140 mm
BB Height350 mm350 mm350 mm350 mm
Standover750 mm750 mm750 mm750 mm
Front Centre727 mm*753 mm*791 mm*825 mm*
FC:RC1.631.691.781.85
Trims · 2
Pro
€9,999
Ultra
€11,999
MotorPinion MGU (E1.12) · 85 Nm · all trims
BatteryFIT IPU1000 Ultracore 960 · 960 Wh · all trims
Travel F/R150/150 mm · all trims
FrameCarbon · all trims
ForkFox 36 Float Performance, 150 mm, Grip 3-Pos Micro Adjust, E-Optimized, OD-CrownFox 36 Float Factory Kashima, 150 mm, FIT4 3-Pos Adjust, E-Optimized, OD-Crown
ShockFox Float X Performance, 2-Pos, Evol LV (150 mm)Fox Float X Factory Kashima, 2-Pos Adjust, Evol LV (150 mm)
HeadsetAcros RW750 1.5 headset with Blocklock · all trims
StemRotwild S140 AL7075, 35 mm, 50 mm, Monkeylink Interface · all trims
HandlebarRotwild B280 AL7075, 35 mm, 15 mm rise, 780 mm widthRotwild B220 Carbon, 35 mm, 15 mm rise, 780 mm width
GripsErgon GD10 Slim · all trims
SaddleErgon SM SportErgon SM Pro
SeatpostCrankbrothers Highline, 34.9 mm, up to 150 mm (XL) · all trims
BrakesMagura MT5 HC-W (front and rear), Magura MDR-P 203 mm rotors front and rear (rear with sensor) · all trims
Rear derailleurNone (Pinion E1.12 MGU integrated gearbox, 12 gears) · all trims
CrankPinion, 165 mm (S, M) / 170 mm (L, XL), Direct Mount Chainring 30TPinion CNC, 165 mm (S, M) / 170 mm (L, XL), Direct Mount Chainring 30T
ShiftersPinion TE1 electronic gear lever · all trims
CassettePinion 24T (rear sprocket) · all trims
ChainPinion X1 Longlife (single-speed chain) with Rotwild R.1000 chain guide · all trims
DrivetrainNone (Pinion E1.12 MGU integrated gearbox, 12 gears); Pinion, 165 mm (S, M) / 170 mm (L, XL), Direct Mount Chainring 30T; Pinion TE1 electronic gear lever; Pinion 24T (rear sprocket); Pinion X1 Longlife (single-speed chain) with Rotwild R.1000 chain guideNone (Pinion E1.12 MGU integrated gearbox, 12 gears); Pinion CNC, 165 mm (S, M) / 170 mm (L, XL), Direct Mount Chainring 30T; Pinion TE1 electronic gear lever; Pinion 24T (rear sprocket); Pinion X1 Longlife (single-speed chain) with Rotwild R.1000 chain guide
WheelsDT Swiss H1900 Spline (30), Ratchet SS, 110-15 mm front / 148-12 mm rear, TAS, CenterlockDT Swiss HX1501 Spline1 (30), Ratchet SS, 110-15 mm front / 148-12 mm rear, TAS, Centerlock
TyresSchwalbe Magic Mary 29 x 2.40 Super Ground Soft TLE (front) / Schwalbe Hans Dampf Evo 27.5 x 2.60 Super Trail Soft TLE (rear) · all trims
Price€9,999€11,999
Rides similarly
Spot a mistake?
