R.E735 2026
The Rotwild R.E735 is the German brand's full-power carbon enduro, built around a mullet wheel layout with 170 mm of fork travel and 148 mm at the rear. The handmade high-modulus carbon frame, a slack 64.5 degree head angle and short 440 mm chainstays across every size point clearly at high-speed, technical descending while keeping the back end agile.
Both trims run the Shimano EP801 motor (up to 85 Nm) and the brand's own 720 Wh IPU735 carbon-housed, quick-release battery, so the difference between them is purely component grade rather than drivetrain or geometry. The Core at 7,990 euros uses Fox Performance suspension, Magura MT5 brakes and alloy Crankbrothers Synthesis Enduro wheels. The Ultra at 11,490 euros steps up to Fox Factory Kashima damping, Shimano XT 8120 brakes, carbon Crankbrothers Synthesis I9 wheels and e*thirteen Race Carbon cockpit and cranks, trimming claimed weight from 22.2 kg to 21.6 kg in size L.
Geometry is consistent across the four sizes with a 74 degree effective seat angle and reach growing from 420 mm on the S to 490 mm on the XL. The 1,253 mm wheelbase in L and identical 440 mm chainstays give the sizing a stable yet maneuverable footprint typical of a modern mullet enduro platform.
| S | M | L | XL | |
| Reach | 420 mm | 440 mm | 465 mm | 490 mm |
| Stack | 633 mm | 633 mm | 651 mm | 661 mm |
| Seattube | 410 mm | 440 mm | 470 mm | 506 mm |
| Chainstay | 440 mm | 440 mm | 440 mm | 440 mm |
| Headtube Angle | 64.5° | 64.5° | 64.5° | 64.5° |
| Seattube Angle (eff) | 74° | 74° | 74° | 74° |
| Wheelbase | 1199 mm | 1219 mm | 1253 mm | 1282 mm |
| Headtube | 110 mm | 110 mm | 130 mm | 140 mm |
| BB Height | 353 mm | 353 mm | 353 mm | 353 mm |
| Standover | 737 mm | 737 mm | 737 mm | 737 mm |
| Front Centre | 759 mm* | 779 mm* | 813 mm* | 842 mm* |
Trims · 2
Core | Ultra | |
| Motor | Shimano EP801 · 85 Nm · all trims | |
| Battery | Rotwild IPU735 · 720 Wh · all trims | |
| Travel F/R | 170/148 mm · all trims | |
| Frame | Carbon · all trims | |
| Fork | FOX 36 Float Performance | FOX 36 Float Factory Kashima |
| Shock | FOX Float X2 Performance | FOX Float X2 Factory Kashima |
| Headset | ACROS RW735 1.5 · all trims | |
| Stem | e*thirteen Plus · all trims | |
| Handlebar | e*thirteen Plus | e*thirteen Race Carbon |
| Grips | ERGON GD10 · all trims | |
| Saddle | ERGON SM Enduro Comp · all trims | |
| Seatpost | 8PINS H01 · all trims | |
| Brakes | MAGURA MT5 | SHIMANO XT 8120 |
| Rear derailleur | SHIMANO XT 8100 · all trims | |
| Crank | e*thirteen Plus | e*thirteen Race Carbon |
| Shifters | SHIMANO XT 8100 · all trims | |
| Cassette | SHIMANO CS 6100 | SHIMANO CS 7100 |
| Chain | SHIMANO HG 7100 · all trims | |
| Drivetrain | SHIMANO XT 8100; e*thirteen Plus; SHIMANO XT 8100; SHIMANO CS 6100; SHIMANO HG 7100 | SHIMANO XT 8100; e*thirteen Race Carbon; SHIMANO XT 8100; SHIMANO CS 7100; SHIMANO HG 7100 |
| Wheels | CRANKBROTHERS Synthesis Enduro | CRANKBROTHERS Synthesis Enduro I9 Carbon |
| Tyres | SCHWALBE Magic Mary (front) / SCHWALBE Hans Dampf Evo (rear) · all trims | |
| Weight | 22.2 kg | 21.6 kg |
Rides similarly
Spot a mistake?
