Slack 63.5° head angle, 160mm travel and a long 1284mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
R.E375 2022
Light handmade carbon enduro with a small 375Wh battery for shorter loops
The Rotwild R.E375 was the lightweight full-power enduro eMTB from German brand Rotwild (ADP Engineering), pairing a handmade high-modulus carbon frame with a Shimano EP8 motor and a compact 375 Wh carbon battery. The 'E375' name signals the 375 Wh IPU battery, the light-assist sibling to the longer-range R.E750.
With 170 mm of front travel, 160 mm rear, a very slack 63.5 degree head angle and roomy reach (460 to 510 mm across M to XL), the geometry was purpose-built for steep, technical descents and high-speed control. Weight-saving trumped range: the small battery keeps the system light and lively, at the cost of outright capacity.
Two trims were offered. The Core (from 7,999 euro) ran Fox 36 Performance forks, a Float X Performance shock and Magura MT5 brakes, while the Pro (from 9,499 euro) stepped up to Fox Factory Kashima suspension, Shimano XT four-piston brakes and Crankbrothers Synthesis Enduro i9 wheels.
The R.E375 has since been discontinued from Rotwild's range. It remains a distinctive choice for riders who prioritised nimble handling and a low system weight over battery range in a full-power enduro eMTB.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Front-long in L: 839mm front centre on 445mm stays (FC:RC 1.89). Planted and composed; rewards a forward, attacking stance.
Climbs well — a 77° seat keeps the front planted. 500W of peak power and 85Nm of torque — a strong full-power motor.
Rewards commitment; it should feel calmer as the speed rises.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 160 bikes in the database)
| M | L | XL | |
| Reach | 460 mm | 485 mm | 510 mm |
| Stack | 625 mm | 636 mm | 641 mm |
| Seattube | 440 mm | 470 mm | 506 mm |
| Chainstay | 445 mm | 445 mm | 445 mm |
| Headtube Angle | 63.5° | 63.5° | 63.5° |
| Seattube Angle (eff) | 77° | 77° | 77° |
| Wheelbase | 1253 mm | 1284 mm | 1311 mm |
| Headtube | 110 mm | 125 mm | 130 mm |
| BB Height | 350 mm | 350 mm | 350 mm |
| Standover | 730 mm | 730 mm | 730 mm |
| Front Centre | 808 mm* | 839 mm* | 866 mm* |
| FC:RC | 1.82 | 1.89 | 1.95 |
Trims · 2
Core €7,999 | Pro €9,499 | |
| Motor | Shimano EP8 (DU-EP800) · 85 Nm · all trims | |
| Battery | Rotwild IPU375 · 360 Wh · all trims | |
| Travel F/R | 170/160 mm · all trims | |
| Frame | Full carbon (high modulus carbon fibre, handmade; carbon linkage and shock yoke) · all trims | |
| Fork | FOX 36 FLOAT PERFORMANCE 170 MM / 3-POS FIT GRIP / MICRO ADJUST / E-TUNED | FOX 36 FLOAT FACTORY KASHIMA 170 MM / FIT4 3-POS ADJUST / E-TUNED |
| Shock | FOX FLOAT X PERFORMANCE 3-POS 230X60 | FOX FLOAT X FACTORY KASHIMA 3-POS ADJUST / 230 X 60 |
| Headset | ACROS RW375 1.5 HEADSET W/ BLOCKLOCK · all trims | |
| Stem | E*THIRTEEN PLUS Ø35 MM / 50 MM / AL7050 I.C.R. · all trims | |
| Handlebar | E*THIRTEEN PLUS Ø35 mm / 20 MM RISE / 780 MM WIDTH / AL7050 I.C.R · all trims | |
| Grips | ERGON GD10 SLIM FACTORY FROZEN · all trims | |
| Saddle | ERGON SM · all trims | |
| Seatpost | E*THIRTEEN VARIO COVERT INFINITE INDIVIDUAL UP TO 260 MM (XL) · all trims | |
| Brakes | MAGURA MT5 HC-W SHIFT MIX | SHIMANO XT 8120 FIN PAD |
| Rear derailleur | SHIMANO XT 8100 12-Speed · all trims | |
| Crank | E*THIRTEEN PLUS 160 mm (M) / 165 mm (L, XL) · all trims | |
| Shifters | SHIMANO XT I-SPEC EV · all trims | |
| Cassette | SHIMANO CS 6100 10-51 T. / 12-SPEED | SHIMANO CS 7100 10-51T. 12-SPEED |
| Drivetrain | SHIMANO XT 8100 12-Speed; E*THIRTEEN PLUS 160 mm (M) / 165 mm (L, XL); SHIMANO XT I-SPEC EV; SHIMANO CS 6100 10-51 T. / 12-SPEED | SHIMANO XT 8100 12-Speed; E*THIRTEEN PLUS 160 mm (M) / 165 mm (L, XL); SHIMANO XT I-SPEC EV; SHIMANO CS 7100 10-51T. 12-SPEED |
| Wheels | CRANKBROTHERS SYNTHESIS ENDURO (31.5/29.5) / 110-15/148-12 TAS / 6-BOLT | CRANKBROTHERS SYNTHESIS ENDURO I9 (31.5/29.5) / 110-15/148-12 TAS / CL |
| Tyres | SCHWALBE MAGIC MARY / HANS DAMPF EVO SUPER GROUND / TRAIL TLE SOFT 29x2.40 · all trims | |
| Price | €7,999 | €9,499 |
Rides similarly
Spot a mistake?
