Bike Finder · Rose
Rose Bonero Plus
Rose
Bonero Plus 2025
CurrentLightweight Hardtail eMTBAgeing · 4.4/10iFreshness 4.4/10
Carbon TQ HPR50 lightweight hardtail eMTB
Travel F/R
140mm / —
Wheels
29F/29R
Frame
Full carbon
Weight
16.9 kg
Price
From £3,399
View the Rose Bonero Plus on Rose’s site
Rose Bonero Plus 2025
From £3,399
EMTB Forums verdict
The Rose Bonero Plus 2025 is the German brand's lightweight carbon hardtail eMTB, built around the TQ HPR50 motor (50 Nm torque, 250 W rated, 300 W manufacturer-claimed peak, 1.85 kg) and a 360 Wh integrated battery. 140 mm front fork on a carbon hardtail frame. Single base trim at €4,499, claimed weight just 16.9 kg. Four sizes from S to XL, reach 425-515 mm, head angle 65.0 degrees flat, chainstays 446 mm. The community read in one line: a properly considered lightweight carbon hardtail eMTB at sub-17 kg with the silent TQ HPR50 motor, sitting in a niche between an analogue trail hardtail and a full-suspension SL eMTB.
Drive system and range. The TQ HPR50 is the same coaxial Harmonic Pin Ring drive used by Trek Fuel EXe and Mondraker Neat — virtually silent under load, ultra-natural delivery, 1.85 kg motor weight. 50 Nm torque is modest by full-power standards but well-matched to a hardtail's lower drag and faster cadence. The 360 Wh battery is integrated into the downtube and typically not user-removable on TQ-equipped bikes. A 160 Wh range extender is available, pushing total to 520 Wh for serious days. Real-world range will sit in the 30 to 50 km territory on Trail/Eco mode, with the range extender enabling 50 to 80 km.
Geometry and handling. Trail-friendly hardtail. 65 degree head angle is sensible for a trail hardtail (slacker than typical XC, steeper than full-suspension enduro). Reach progresses 425 mm (S), 455 mm (M), 485 mm (L) and 515 mm (XL) — a generous reach range, especially the XL at 515 mm for tall riders. Chainstays held at 446 mm flat across all four sizes, with wheelbase 1186 to 1291 mm. Full 29er. The hardtail format means simple maintenance, no rear shock service, and the lightest possible weight at the travel point.
Build and value. Single base trim at €4,499 (16.9 kg). At this price expect a 140 mm RockShox or Fox 34 Performance class fork, four-piston brakes with 180-203 mm rotors, and a Shimano SLX or XT 12-speed drivetrain. €4,499 for a sub-17 kg carbon TQ HPR50 hardtail is genuinely competitive value — most TQ-equipped full-suspension bikes start at €7,500+.
Caveats and known gripes.
  • Hardtail format means no rear suspension. Riders coming from full-suspension bikes will find rough trails punishing.
  • 50 Nm torque is modest. Steep climbing remains legs-dependent.
  • 360 Wh battery is small. Range extender is worth budgeting for if you want all-day capability.
  • TQ battery typically not user-removable on this generation of bike. Charging happens on the bike via a discreet port.
  • Single trim limits buyer choice — no upgrade ladder within the model line.
  • Very limited community forum data. No detailed long-term reliability or ownership reports available yet.
Verdict. The Rose Bonero Plus 2025 is a thoughtful lightweight carbon hardtail eMTB for buyers who want the silent TQ HPR50 motor at the sharpest possible weight (16.9 kg) and a sensible price. It suits riders who already have a non-electric full-suspension bike and want a lightweight hardtail eMTB for fast/dry XC and trail use, particularly those who appreciate Rose's direct-to-consumer pricing and German engineering. Look elsewhere if you need rear suspension, full-power motor torque, or stronger international warranty support outside Germany. Production status: current, single base trim, four sizes.
Bike geometry diagram
SMLXL
Toptube582 mm611 mm644 mm678 mm
Reach425 mm455 mm485 mm515 mm
Stack632 mm633 mm646 mm664 mm
Seattube400 mm430 mm460 mm500 mm
Chainstay446 mm446 mm446 mm446 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)76°76°76°76°
BB Drop60 mm60 mm60 mm60 mm
Wheelbase1186 mm1215 mm1253 mm1291 mm
Headtube100 mm100 mm115 mm135 mm
Front Centre740 mm769 mm807 mm845 mm
Trims · 3
£3,399
£3,824
£4,504
MotorTQ HPR50 · 50 Nm · all trims
Battery360 Wh · all trims
Travel F/R140/? mm · all trims
FrameCarbon · all trims
ForkRockShox Lyrik Base 140mm 29" Boost, 44mm OffsetRockShox Lyrik Select 140mm 29" Boost, 44mm OffsetRockShox Lyrik Select Plus 29" Boost, 140mm, 44mm Offset
HandlebarE13 Base 800mm 35mm RiseE13 Base 800mm 35mm RiseE13 Plus 800mm 35mm Rise
GripsErgon GE10 Evo · all trims
SaddleRose Edition by Selle Italia · all trims
Seatposte*thirteen Vario Infinite Dropper Post, aluminium 31.6mme*thirteen Vario Infinite Dropper Post 31.6mme*thirteen Vario Infinite Dropper Post 31.6mm
BrakesShimano Deore 4-piston (BL-M6100/BR-M6120)Shimano SLXSRAM Code Bronze
Rear derailleurShimano Deore RD-M6100Shimano XT RD-M8100 SGS, 12-speedSRAM GX Eagle AXS Transmission
CrankE13 Crank BOSCH Gen4-TQ-Brose 170mm, e*thirteen Direct Mount Ring 34TE13 Crank BOSCH Gen4-TQ-Brose 170mm, e*thirteen Direct Mount Ring 34TSRAM GX Eagle, 170 mm
ShiftersShimano Deore SL-M6100-IR, 12-speedShimano Deore XT SL-M8100, 12-speedSRAM AXS POD Controller
CassetteShimano Deore CS-M6100-12, 12-speed, 10-51Shimano Deore XT CS-M8100-12, 12-speed, 10-51SRAM GX XS1275 T-Type, 10-52
ChainShimano Deore CN-M6100, 12-speedShimano SLX CN-M7100, 12-speedSRAM GX Transmission Flattop
DrivetrainShimano Deore 6100 12-speedShimano, TQ HPR50 motor, 360WhSRAM GX Eagle AXS Transmission 1x12
WheelsNewmen Performance 30 base 29"DT Swiss HX1700 Spline 29"Newmen Beskar 30 29"
TyresFront Schwalbe Nobby Nic Evo Super Trail 29x2.4, Rear Schwalbe Wicked Will Evo Super Trail SpeedGrip 29x2.4Schwalbe Nobby Nic Evo Super Trail Addix Soft 29x2.4 front / Schwalbe Wicked Will Evo Super Trail Addix SpeedGrip 29x2.4 rearFront Schwalbe Wicked Will Evo Super Trail 29x2.4, Rear Schwalbe Nobby Nic Evo 29x2.4
Weight16.9 kg
Price£3,399£3,824£4,504
Rides similarly
Spot a mistake?
