Bike Finder · Pivot
Pivot Shuttle SL
Pivot
Shuttle SL 2026
CurrentLightweight Trail eMTBMature · 6.1/10iFreshness 6.1/10
Motor
Fazua Ride 60 · 60Nm · 450W
Battery
Fazua Energy 430 · 430Wh
Travel F/R
150/132mm
Wheels
29F / 29R
Frame
Full carbon
View the Pivot Shuttle SL on Pivot’s site
Pivot Shuttle SL 2026
EMTB Forums verdict
The Pivot Shuttle SL is a lightweight trail e-MTB built around the 60Nm Fazua Ride 60 motor and a 430Wh integrated battery, paired with 132mm of dw-link rear travel and a 150mm Fox 36 fork. Pivot positions it as a trail bike first and an e-bike second, with the motor and battery sat low and central to keep the handling lively. The full carbon Hollow Core frame takes a full-size bottle inside the front triangle and runs a flip chip for High and Low bottom-bracket settings.
Geometry is moderately progressive rather than radical. In the Low BB setting the head angle sits at 65 degrees with a 76 degree effective seat angle across S to L, steepening to 76.8 on the XL, and reach runs from 435mm (S) to 500mm (XL). The flip chip lifts the BB by roughly 5mm and steepens the head angle half a degree in the High setting, useful for pedal clearance on technical ground. Size-specific chainstays grow from 432mm to 438mm to keep the balance consistent as frames get longer.
All three builds share the same frame, motor, Float X trunnion shock and Maxxis Dissector tyres, so the differences are in the drivetrain and fork tier. The Ride Eagle 70/90 is the value entry on a Fox 36 Performance fork, the Pro steps up to SRAM X0 Eagle Transmission, and the Team tops the range with XX Eagle Transmission and a Fox 36 Factory fork. Pivot quotes a sub-17kg (36.25 lb) World Cup build, marking this out as one of the lighter mid-power options in the class.
💬 Forum discussion
2023 Pivot Shuttle SL - Super Light
331 replies · 122k views · last reply 22 months ago
Join the discussion →
“Pivot Shuttle SL. Lightweight. Seen in new EMBN video. Looks neat, Fazua 60Nm motor, 430Wh battery.”
— Drippy · ♥ 22 · most-liked post
Bike geometry diagram
SMLXL
Reach435 mm465 mm478 mm500 mm
Stack610 mm626 mm630 mm642 mm
Seattube368 mm394 mm432 mm470 mm
Chainstay432 mm432 mm434 mm438 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)76°76°76°76.8°
Wheelbase1186 mm1223 mm1240 mm1272 mm
Headtube95 mm112 mm117 mm130 mm
BB Height347 mm347 mm347 mm347 mm
Standover665 mm668 mm674 mm678 mm
Front Centre754 mm*791 mm*806 mm*834 mm*
Trims · 3
Pro X0 Eagle Transmission
Ride Eagle 70/90
Team XX Eagle Transmission
MotorFazua Ride 60 · 60 Nm · all trims
BatteryFazua Energy 430 · 430 Wh · all trims
Travel F/R150/132 mm · all trims
FrameCarbon · all trims
ForkFOX 36 Factory, 150mmFOX 36 Performance, 150mmFOX 36 Factory, 150mm
ShockFOX Float X (trunnion mount) · all trims
Rear derailleurSRAM X0 Eagle TransmissionSRAM Eagle 70/90 TransmissionSRAM XX Eagle Transmission
DrivetrainSRAM X0 Eagle TransmissionSRAM Eagle 70/90 TransmissionSRAM XX Eagle Transmission
TyresMaxxis Dissector · all trims
Rides similarly
Spot a mistake?
