Bike Finder · Pivot
Pivot Shuttle AM
Pivot
Shuttle AM 2023
DiscontinuedFull Power · TrailLegacy · 0.4/10iFreshness 0.4/10
Premium full-carbon all-mountain bike carrying a very high price
Travel F/R
160/140mm
Wheels
29F / 29R
Frame
Full carbon
Weight
Price
£12,400
View the Pivot Shuttle AM on Pivot’s site
Pivot Shuttle AM 2023
From £12,400
EMTB Forums verdict
The 2023 Pivot Shuttle AM was the brand's original full-power eMTB, built around a full-carbon hollow-core chassis with Pivot's dw-link suspension giving 140mm of rear travel through a metric Fox shock, matched to a 160mm Fox 38 fork. Power came from a Shimano EP8 (DU-EP800) drive unit rated at 85Nm, fed by a 726Wh battery with a two-bolt release system, and the frame was also compatible with smaller 635Wh and 508Wh packs.
The bike ran modern all-mountain numbers across four sizes: a 64.3 degree head angle, a 74.0 degree effective seat angle, 441mm chainstays and reach growing from 420mm on the Small to 485mm on the XL, with 29in wheels front and rear and Maxxis Assegai and Minion DHR II rubber. The premium Team XTR build paired Fox Factory 38 GRIP2 and Float X suspension with a full Shimano XTR transmission and brakes, DT Swiss EB 1535 wheels, a Fox Transfer Factory dropper and a Pivot Pro E-Bike saddle, listed in the UK at 12,400 pounds in Treeline Green.
This model is discontinued. In 2023 Pivot replaced it with an all-new Shuttle AM built on the Bosch Performance Line CX (and limited-edition CX Race) platform, with a 750Wh battery and a 148mm-travel dw-link rear end, ending the Shimano EP8 era for this model.
As a research dossier this entry records the published specification and geometry only and makes no claim about long-term ride feel or reliability.
Geometry read
Size
Descending
63
A solid all-round descender (64.3° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
64
Size balance
95
Balanced front-to-rear in L (FC:RC 1.80) — weight sits evenly between the wheels.
Technical climbing
66
Climbs well — a 74° seat keeps the front planted. 500W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Trail bikes (from 271 bikes in the database)
Battery726 Whabout average capacity
Motor torque85 Nm13 Nm below average
Value for money5/100from £12,400 · most Shimano EP8 (DU-EP800) bikes ~£5,610
💬 Forum discussion
2024 Pivot Shuttle AM
119 replies · 32.6k views · last reply 13 months ago
Join the discussion →
“Jumping on the band wagon here. I got the XO package with the T-Type drivetrain, an upgraded X2 shock, and 200mm seatpost for my long legs. I'm really enjoying the bike. The suspension is a little more "lively" than my old Heckler.…”
— RustyIron · ♥ 6 · most-liked post
Bike geometry diagram
SMDLXL
Reach420 mm440 mm460 mm485 mm
Stack614 mm624 mm633 mm642 mm
Seattube395 mm424 mm458 mm496 mm
Chainstay441 mm441 mm441 mm441 mm
Headtube Angle64.3°64.3°64.3°64.3°
Seattube Angle (eff)74°74°74°74°
Wheelbase1187 mm1214 mm1235 mm1264 mm
Headtube110 mm120 mm130 mm140 mm
BB Height358 mm358 mm358 mm358 mm
Standover715 mm715 mm723 mm723 mm
Front Centre746 mm*773 mm*794 mm*823 mm*
FC:RC1.691.751.801.87
Trims · 1
Team XTR
£12,400
MotorShimano EP8 (DU-EP800) · 85 Nm
BatteryShimano 726Wh · 726 Wh
Travel F/R160/140 mm
FrameFull-carbon (hollow-core moulded carbon fibre)
ForkFox Factory 38 GRIP2 fork, 44mm offset, 160mm of travel
ShockMetric-sized Fox Factory Float X shock with Kashima coating, 140mm of rear travel
StemPhoenix Team Enduro/Trail
HandlebarPhoenix Team Low Rise Carbon
SaddlePivot Pro E-Bike
SeatpostFox Transfer Factory Series
BrakesShimano XTR M9120 4-piston calliper
Rear derailleurShimano XTR SGS 12-Speed
CrankShimano XT M8150 w/ Shimano E-MTB 34t
ShiftersShimano XTR M9100 12-Speed
CassetteShimano XT M8100 10-51t
DrivetrainShimano XTR SGS 12-Speed; Shimano XT M8150 w/ Shimano E-MTB 34t; Shimano XTR M9100 12-Speed; Shimano XT M8100 10-51t
WheelsDT Swiss EB 1535, 30mm - 29"; 15x110 F / 12x157 R
TyresMaxxis Assegai front, Maxxis Minion DHR II rear
Price£12,400
Rides similarly
Spot a mistake?
