Slack 64° head angle, 160mm travel and a long 1277mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Wild 2023
The all-new 2023 Orbea Wild is the Spanish brand's full-power enduro e-MTB, and a complete ground-up redesign that replaced the older Wild FS. It runs 160 mm of rear travel from a linkage-driven single pivot with a concentric CB2 rear-axle pivot, paired to a 160 mm fork as standard (170 mm on the flagship), on full 29in wheels. Power comes from the Bosch Performance Line CX Gen 4 Smart System at 85 Nm, fed by a Bosch PowerTube battery of 750 Wh on most trims or 625 Wh on the lightest builds, with the System Controller neatly integrated into the top tube.
Orbea split the range into a carbon OMR M-series and an aluminium Hydro H-series, all configurable through the MyO programme. UK pricing ran from the alloy H30 at 5,299 GBP up through the H20, H10, carbon M20, M10 and M-Team, to the M-LTD at 10,999 GBP. The M-LTD is the standout: a Bosch Performance Line CX Race motor with its exclusive Race mode, a 170 mm Fox 38 Factory fork, Float X2 shock, Shimano XTR throughout and OQUO carbon wheels, with a claimed weight around 22.6 kg for a size large.
The geometry borrows heavily from Orbea's Rallon enduro bike: a slack 64 degree head angle, a steep 77.5 degree seat angle, a short 448 mm chainstay fixed across all four sizes, and reach growing from 435 mm on the S to 505 mm on the XL. Compared with the outgoing Wild FS the reach grew 25 mm and the wheelbase about 45 mm, giving a longer, lower and more descent-focused machine that still keeps the front wheel weighted on steep climbs.
This 2023 model is discontinued, later superseded by updated Wild generations. As a fully integrated, removable-battery full-power enduro bike spanning a broad alloy-to-carbon price ladder, it remains a strong used option for riders who want a 29er e-enduro that handles like its analogue Rallon sibling.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Balanced front-to-rear in L (FC:RC 1.85) — weight sits evenly between the wheels.
Climbs well — a 77.5° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Rewards commitment; it should feel calmer as the speed rises.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 136 bikes in the database)
| S | M | L | XL | |
| Reach | 435 mm | 455 mm | 480 mm | 505 mm |
| Stack | 621 mm | 630 mm | 639 mm | 648 mm |
| Seattube | 415 mm | 415 mm | 435 mm | 460 mm |
| Chainstay | 448 mm | 448 mm | 448 mm | 448 mm |
| Headtube Angle | 64° | 64° | 64° | 64° |
| Seattube Angle (eff) | 77.5° | 77.5° | 77.5° | 77.5° |
| Wheelbase | 1223 mm | 1247 mm | 1277 mm | 1306 mm |
| Headtube | 110 mm | 120 mm | 130 mm | 140 mm |
| BB Height | 347 mm | 347 mm | 347 mm | 347 mm |
| Standover | 730 mm | 730 mm | 730 mm | 730 mm |
| Front Centre | 775 mm* | 799 mm* | 829 mm* | 858 mm* |
| FC:RC | 1.73 | 1.78 | 1.85 | 1.92 |
Trims · 7
H30 £5,299 | H20 £5,899 | H10 £6,499 | M20 £6,999 | M10 £7,999 | M-Team £8,999 | M-LTD £10,999 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm | Bosch Performance Line CX Race · 85 Nm |
| Battery | Bosch PowerTube 750 · 750 Wh · all trims | ||||||
| Travel F/R | 160/160 mm · all trims | ||||||
| Frame | Orbea Wild Hydro aluminium | Orbea Wild Hydro aluminium | Orbea Wild Hydro aluminium | Orbea Wild OMR carbon | Orbea Wild OMR carbon | Orbea Wild OMR carbon | Orbea Wild OMR carbon |
| Fork | RockShox 35 Silver TK, 160 mm | RockShox 35 Silver TK, 160 mm | Fox 38 Float Performance GRIP, 160 mm | RockShox 35 Silver TK, 160 mm | Fox 38 Float Performance GRIP, 160 mm | Fox 38 Float Factory GRIP2, 160 mm | Fox 38 Float Factory GRIP2, 170 mm |
| Shock | Fox Float DPS Performance EVOL, custom tune (205 x 65 mm) | Fox Float DPS Performance EVOL, custom tune (205 x 65 mm) | Fox Float X Performance, custom tune (205 x 65 mm) | Fox Float DPS Performance EVOL, custom tune (205 x 65 mm) | Fox Float X Performance, custom tune (205 x 65 mm) | Fox Float X2 Factory, custom tune (205 x 65 mm) | Fox Float X2 Factory, custom tune (205 x 65 mm) |
| Stem | OC Mountain Control MC20, 0 deg | OC Mountain Control MC20, 0 deg | OC Mountain Control MC20, 0 deg | OC Mountain Control MC20, 0 deg | OC Mountain Control MC20, 0 deg | OC Mountain Control MC10 ALU SL, 0 deg | OC Mountain Control MC10 ALU SL, 0 deg |
| Handlebar | OC Mountain Control MC30, 800 mm, 20 mm rise | OC Mountain Control MC30, 800 mm, 20 mm rise | OC Mountain Control MC20 ALU SL, 800 mm, 20 mm rise | OC Mountain Control MC30, 800 mm, 20 mm rise | OC Mountain Control MC20 ALU SL, 800 mm, 20 mm rise | OC Mountain Control MC10 Carbon, 800 mm, 20 mm rise | OC Mountain Control MC10 Carbon, 800 mm, 20 mm rise |
| Saddle | Selle Royal Vivo | Selle Royal Vivo | Fizik Aidon | Selle Royal Vivo | Fizik Aidon | Fizik Aidon | Fizik Terra Aidon X1 |
| Seatpost | OC Mountain Control MC20 dropper, 31.6 mm | OC Mountain Control MC20 dropper, 31.6 mm | OC Mountain Control MC20 dropper, 31.6 mm | OC Mountain Control MC20 dropper, 31.6 mm | OC Mountain Control MC20 dropper, 31.6 mm | OC Mountain Control MC20 dropper, 31.6 mm | Fox Factory Transfer dropper, 31.6 mm |
| Brakes | Shimano MT410 hydraulic disc, front | rear | SRAM DB8 4-piston hydraulic disc, front | rear | Shimano M6120 4-piston hydraulic disc, front | rear | SRAM DB8 4-piston hydraulic disc, front | rear | Shimano M6120 4-piston hydraulic disc, front | rear | Shimano XT M8120 4-piston hydraulic disc, front | rear | Shimano XTR M9120 4-piston hydraulic disc, front | rear |
| Rear derailleur | Shimano XT M8100 SGS Shadow Plus, 12-speed | Shimano XT M8100 SGS Shadow Plus, 12-speed | Shimano XT M8100 SGS Shadow Plus, 12-speed | Shimano XT M8100 SGS Shadow Plus, 12-speed | Shimano XT M8100 SGS Shadow Plus, 12-speed | Shimano XT M8100 SGS Shadow Plus, 12-speed | Shimano XTR M9100 SGS Shadow Plus, 12-speed |
| Crank | e*thirteen Plus ALU, 34T, 160 mm | e*thirteen Plus ALU, 34T, 160 mm | e*thirteen Plus ALU, 34T, 160 mm | e*thirteen Plus ALU, 34T, 160 mm | e*thirteen Plus ALU, 34T, 160 mm | e*thirteen Plus ALU, 34T, 160 mm | e*thirteen Race Carbon, 34T, 160 mm |
| Shifters | Shimano Deore M6100, 12-speed | Shimano Deore M6100, 12-speed | Shimano Deore M6100, 12-speed | Shimano Deore M6100, 12-speed | Shimano SLX M7100, 12-speed | Shimano XT M8100, 12-speed | Shimano XTR M9100, 12-speed |
| Cassette | Shimano CS-M6100, 10-51T, 12-speed | Shimano CS-M7100, 10-51T, 12-speed | Shimano CS-M7100, 10-51T, 12-speed | Shimano CS-M7100, 10-51T, 12-speed | Shimano CS-M7100, 10-51T, 12-speed | Shimano CS-M8100, 10-51T, 12-speed | Shimano XTR M9100, 10-51T, 12-speed |
| Chain | Shimano M6100 | Shimano M6100 | Shimano M6100 | Shimano M6100 | Shimano M6100 | Shimano M8100 | Shimano CN-9100 |
| Drivetrain | Shimano XT M8100 SGS Shadow Plus, 12-speed; e*thirteen Plus ALU, 34T, 160 mm; Shimano Deore M6100, 12-speed; Shimano CS-M6100, 10-51T, 12-speed; Shimano M6100 | Shimano XT M8100 SGS Shadow Plus, 12-speed; e*thirteen Plus ALU, 34T, 160 mm; Shimano Deore M6100, 12-speed; Shimano CS-M7100, 10-51T, 12-speed; Shimano M6100 | Shimano XT M8100 SGS Shadow Plus, 12-speed; e*thirteen Plus ALU, 34T, 160 mm; Shimano Deore M6100, 12-speed; Shimano CS-M7100, 10-51T, 12-speed; Shimano M6100 | Shimano XT M8100 SGS Shadow Plus, 12-speed; e*thirteen Plus ALU, 34T, 160 mm; Shimano Deore M6100, 12-speed; Shimano CS-M7100, 10-51T, 12-speed; Shimano M6100 | Shimano XT M8100 SGS Shadow Plus, 12-speed; e*thirteen Plus ALU, 34T, 160 mm; Shimano SLX M7100, 12-speed; Shimano CS-M7100, 10-51T, 12-speed; Shimano M6100 | Shimano XT M8100 SGS Shadow Plus, 12-speed; e*thirteen Plus ALU, 34T, 160 mm; Shimano XT M8100, 12-speed; Shimano CS-M8100, 10-51T, 12-speed; Shimano M8100 | Shimano XTR M9100 SGS Shadow Plus, 12-speed; e*thirteen Race Carbon, 34T, 160 mm; Shimano XTR M9100, 12-speed; Shimano XTR M9100, 10-51T, 12-speed; Shimano CN-9100 |
| Wheels | RaceFace AR 30C wheelset | RaceFace AR 30C wheelset | OQUO Mountain Control MC32TEAM eBike wheelset | RaceFace AR 30C wheelset | OQUO Mountain Control MC32TEAM eBike wheelset | OQUO Mountain Control MC32TEAM eBike wheelset | OQUO Mountain Control MC32LTD carbon wheelset |
| Tyres | Maxxis Minion DHF (front) / Maxxis Minion DHR II (rear), 29 x 2.60 in, 120 TPI, 3C MaxxTerra, EXO+ · all trims | ||||||
| Weight | — | — | — | — | — | — | 22.56 kg |
| Price | £5,299 | £5,899 | £6,499 | £6,999 | £7,999 | £8,999 | £10,999 |
Rides similarly
Spot a mistake?
