A solid all-round descender (65.5° head angle, 160mm) — capable in the rough and steep without being an all-out bruiser.
Wild FS 2023
The Orbea Wild FS was the brand's outgoing full-power enduro eMTB, an OMR carbon (or hydroformed alloy on H-models) 29er running 160mm of travel front and rear, driven by the Bosch Performance Line CX Gen 4 motor and the then-new Bosch Smart System. It was sold from autumn 2022 and carried as a model-year 2023 machine before Orbea replaced it in early 2023 with the all-new, redesigned Wild.
Geometry is comfortably modern for its era without chasing extremes: a 65.5 degree head angle, a 76 degree effective seat angle and a long 455mm chainstay across all sizes, with reach growing from 430mm on the S/M to 485mm on the XL. The frame was offered in three sizes (S/M, L, XL) rather than a four-size range, which is a notable quirk when sizing against rivals.
Trim value spans a wide ladder. The carbon M-Team headlines with Fox 38 Factory and Float X2 Factory suspension, a full Shimano XT 1x12 transmission, an e*thirteen Plus Alu crank and OQUO carbon wheels; the M10 keeps the carbon frame on Performance-level Fox; and the alloy H20 and entry H30 bring the platform down to RockShox 35 forks and Shimano Deore shifting, with the H30 dropping to the smaller 625Wh battery. All M and most H models use the 750Wh Bosch PowerTube.
As the predecessor to the current Wild, the Wild FS still makes sense for a buyer chasing a discounted, proven 160mm Bosch CX platform, provided they accept the three-size frame range and the older Gen 4 motor rather than the newer Wild's revised chassis.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Rear-long with a planted front in L (FC:RC 1.71) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Bosch Performance Line CX Gen 4 and a steep 76° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Strong up and composed down — a do-it-all, not a specialist.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 137 bikes in the database)
| S | L | XL | |
| Reach | 430 mm | 455 mm | 485 mm |
| Stack | 621 mm | 630 mm | 644 mm |
| Chainstay | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 65.5° | 65.5° | 65.5° |
| Seattube Angle (eff) | 76° | 76° | 76° |
| Wheelbase | 1203 mm | 1232 mm | 1268 mm |
| BB Height | 345 mm | 345 mm | 345 mm |
| Standover | 725 mm | 740 mm | 765 mm |
| Front Centre | 748 mm* | 777 mm* | 813 mm* |
| FC:RC | 1.64 | 1.71 | 1.79 |
Trims · 5
M10 £7,099 | M-Team £8,099 | H20 | H30 | M20 | |
| Motor | Bosch Performance Line CX Gen 4 · 85 Nm · all trims | ||||
| Battery | Bosch PowerTube 750 · 750 Wh · all trims | ||||
| Travel F/R | 160/160 mm · all trims | ||||
| Frame | Carbon (Orbea OMR) | Carbon (Orbea OMR) | Hydroformed Alloy | Hydroformed Alloy | Carbon (Orbea OMR) |
| Fork | Fox 38 Float Performance, Grip2, 160mm Boost | Fox 38 Float Factory, Grip2, Kashima, 160mm Boost | RockShox 35 Silver TK Q15x110 Solo Air 160mm | RockShox 35 Silver TK Q15x110 Solo Air 160mm | RockShox 35 Silver TK Solo Air 160mm |
| Shock | Fox Float X Performance Trunnion 2-Position Adjust, Custom tune | Fox Float X2 Factory Trunnion 2-Position Adjust Kashima custom tune | Fox Float DPS Performance Trunnion 3-Position Evol LV | Fox Float DPS Performance Trunnion 3-Position Evol LV custom tune 205x65mm | Fox Float DPS Performance, custom tune, 3-position lockout, Trunnion mount |
| Headset | Alloy 1-1/2", Black Oxidated Bearing | Alloy 1-1/2", Black Oxidated Bearing | FSA 1-1/2" Integrated Aluminium Cup | FSA 1-1/2" Integrated Aluminium Cup | Alloy 1-1/2", Black Oxidated Bearing |
| Stem | OC Mountain Control MC20, 0º | OC Mountain Control MC10 Alu SL, 0º | OC Mountain Control MC20, 0º | OC Mountain Control MC20, 0º | OC Mountain Control MC20, 0º |
| Handlebar | OC Mountain Control MC20 Alu SL, Rise20, Width 800 | OC Mountain Control MC10 Carbon, Rise 20, Width 800 | OC Mountain Control MC30, Rise20, Width 800 | OC Mountain Control MC30, Rise20, Width 800 | OC Mountain Control MC30, Rise20, Width 800 |
| Saddle | Fizik Aidon, magnesium rails | Fizik Aidon 208x145mm manganese rail | Selle Royal Vivo 145x269mm | Selle Royal Vivo 145x269mm | Selle Royal Vivo |
| Seatpost | OC Mountain Control MC20, 31.6mm, Dropper · all trims | ||||
| Brakes | Shimano M6120 Hydraulic disc brakes | Shimano XT M8120 Hydraulic disc brakes | SRAM DB8 Black Hydraulic Disc | Shimano M410 Hydraulic Disc Brakes | SRAM DB8 Black Hydraulic Disc |
| Rear derailleur | Shimano XT M8100, ShadowPlus, 12-Speed | Shimano XT M8100, ShadowPlus, 12-Speed | Shimano XT M8100, SGS ShadowPlus, 12-Speed | Shimano XT M8100 SGS, ShadowPlus, 12-Speed | Shimano XT M8100, ShadowPlus, 12-Speed |
| Crank | — | e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T Boost chainring) | e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T chainring) | e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T chainring) | e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T chainring) |
| Shifters | Shimano SLX M7100, 12-Speed | Shimano XT M8100, 12-Speed | Shimano Deore M6100, 12-Speed | Shimano Deore M6100 I-Spec EV, 12-Speed | Shimano Deore M6100, 12-Speed |
| Cassette | Shimano SLX M7100, 10-51t, 12-Speed | Shimano XT M8100, 10-51t, 12-Speed | Shimano CS-M7100 10-51t 12-Speed | Shimano CS-M6100 10-51t 12-Speed | Shimano CS-M7100 10-51t 12-Speed |
| Chain | Shimano M6100, 12-Speed | KMC e12 Turbo 12-Speed | Shimano M6100 12-Speed | Shimano M6100 12-Speed | Shimano M6100 12-Speed |
| Drivetrain | Shimano XT M8100, ShadowPlus, 12-Speed; Shimano SLX M7100, 12-Speed; Shimano SLX M7100, 10-51t, 12-Speed; Shimano M6100, 12-Speed | Shimano XT M8100, ShadowPlus, 12-Speed; e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T Boost chainring); Shimano XT M8100, 12-Speed; Shimano XT M8100, 10-51t, 12-Speed; KMC e12 Turbo 12-Speed | Shimano XT M8100, SGS ShadowPlus, 12-Speed; e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T chainring); Shimano Deore M6100, 12-Speed; Shimano CS-M7100 10-51t 12-Speed; Shimano M6100 12-Speed | Shimano XT M8100 SGS, ShadowPlus, 12-Speed; e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T chainring); Shimano Deore M6100 I-Spec EV, 12-Speed; Shimano CS-M6100 10-51t 12-Speed; Shimano M6100 12-Speed | Shimano XT M8100, ShadowPlus, 12-Speed; e*thirteen Plus Alu, 160mm length (e*thirteen e*spec Direct Mount 34T chainring); Shimano Deore M6100, 12-Speed; Shimano CS-M7100 10-51t 12-Speed; Shimano M6100 12-Speed |
| Wheels | OQUO Mountain Control MC32TEAM eBIKE | OQUO Mountain Control MC32TEAM eBIKE | Race Face AR 30c Tubeless Ready | Race Face AR 30c Tubeless Ready | Race Face AR 30c Tubeless Ready |
| Tyres | Maxxis Minion DH, Maxx Terra Exo+, 2.6" | Maxxis Minion DHF/DHR II, Maxx Terra Exo+, 2.6" | Maxxis Minion DH, Maxx Terra Exo+, 2.6" | Maxxis Minion DHF/DHR II, Maxx Terra Exo+, 2.6" | Maxxis Minion DH, Maxx Terra Exo+, 2.6" |
| Weight | 23 kg | 23 kg | — | 25 kg | 23 kg |
| Price | £7,099 | £8,099 | — | — | — |
Rides similarly
Spot a mistake?
