A solid all-round descender (68° head angle, 100mm) — capable in the rough and steep without being an all-out bruiser.
Keram MTB 2023
Straightforward full-power hardtail for everyday trails and commuting
The Orbea Keram MTB was the Spanish brand's entry-level hardtail e-bike, sitting well below the trail-focused Wild and Rise platforms. It is built around a hydroformed 6061 aluminium frame with Orbea's Hide-out internal battery, an SR Suntour X1 100mm coil fork, fast-rolling Kenda K1153 cross-country tyres and a conservative geometry (67 to 68 degree head angle, 73 degree seat angle, 475mm chainstays). The S size rolls on 27.5in wheels while M, L and XL move to 29in.
Two trims were offered. The Keram 10 (£2,999) ran a full-power 85Nm Bosch Performance Line CX motor with a 500Wh battery in the UK, a Shimano Deore 10-speed drivetrain and Shimano MT200 hydraulic brakes. The cheaper Keram 30 (£2,399) shared the same chassis and finishing kit but dropped to the low-torque 40Nm Bosch Active motor and a 400Wh pack, making it the gentler, more leisure-minded option.
Orbea pitched the Keram as easy and confidence-inspiring for riders of any experience level rather than as an aggressive off-roader, and the modest fork, narrow 740mm bar and basic two-piston brakes reflect that brief. It comes with no rack, mudguards, lights or kickstand as standard, so it is a genuine if entry-level cross-country hardtail eMTB, best suited to fire roads and light singletrack.
The Keram MTB is discontinued and the model name is no longer current, so stock is limited to remaining dealer inventory.
Rear-long with a planted front in L (FC:RC 1.47) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Bosch Performance Line CX Gen 4 and a steep 73° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
| M | L | |
| Reach | 375 mm | 402 mm |
| Stack | 636 mm | 659 mm |
| Seattube | 405 mm | 457 mm |
| Chainstay | 475 mm | 475 mm |
| Headtube Angle | 67° | 68° |
| Seattube Angle (eff) | 73° | 73° |
| Wheelbase | 1149 mm | 1173 mm |
| Headtube | 114 mm | 133 mm |
| BB Height | 313 mm | 313 mm |
| Standover | 825 mm | 861 mm |
| Front Centre | 674 mm* | 698 mm* |
| FC:RC | 1.42 | 1.47 |
Trims · 2
Keram 30 £2,399 | Keram 10 £2,999 | |
| Motor | Bosch Active Line · 85 Nm | Bosch Performance Line CX Gen 4 · 85 Nm |
| Battery | Bosch PowerTube 500 · 500 Wh · all trims | |
| Travel F/R | 100/? mm · all trims | |
| Frame | Aluminium (hydroformed 6061) · all trims | |
| Fork | SR Suntour X1 Coil LO 100mm QR · all trims | |
| Stem | Alloy, 7 degrees · all trims | |
| Handlebar | Alloy, 31.8mm, Flat, 740mm, Sweep 9 · all trims | |
| Saddle | Selle Royal 2077 DRN · all trims | |
| Seatpost | Alloy, 31.6mm, Setback 0 · all trims | |
| Brakes | Shimano MT200 Hydraulic Disc · all trims | |
| Rear derailleur | Shimano Deore M5120 SGS Shadow Plus · all trims | |
| Crank | PW EB04-NW34 G3 | PW EB04-NW32 G4 |
| Shifters | Shimano Deore M4100 · all trims | |
| Cassette | Shimano CS-M4100 11-46t 10-Speed · all trims | |
| Chain | KMC e10 Turbo Silver · all trims | |
| Drivetrain | Shimano Deore M5120 SGS Shadow Plus; PW EB04-NW34 G3; Shimano Deore M4100; Shimano CS-M4100 11-46t 10-Speed; KMC e10 Turbo Silver | Shimano Deore M5120 SGS Shadow Plus; PW EB04-NW32 G4; Shimano Deore M4100; Shimano CS-M4100 11-46t 10-Speed; KMC e10 Turbo Silver |
| Wheels | Alloy, Tubeless, 36H (29in; S size 27.5in) | Alloy, Tubeless, 32H (29in; S size 27.5in) |
| Tyres | Kenda K1153 2.35in 22TPI | Kenda K1153 2.35in 30TPI |
| Price | £2,399 | £2,999 |
Rides similarly
Spot a mistake?
