Bike Finder · Norco
Norco Sight VLT TQ
Norco
Sight VLT TQ 2026
CurrentAll-Mountain eMTBCurrent · 8.9/10iFreshness 8.9/10
Lightweight high-pivot mid-power all-mountain eMTB with TQ HPR60 (60Nm, 350W peak) and 580Wh battery; sub-20kg builds
Travel F/R
160/150mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon
Weight
20.2 kg
Price
£7,699
View the Norco Sight VLT TQ on Norco’s site
Norco Sight VLT TQ 2026
From £7,699
EMTB Forums verdict
The Sight VLT TQ is Norco's lightest mid-power all-mountain eMTB, pairing the high-pivot VPSHP suspension and proven Sight geometry with the compact 1.92kg TQ HPR60 motor. It runs 160mm of fork travel over 150mm at the rear on a mixed 29in front / 27.5in rear wheel setup, with a 64-degree head angle, size-specific rear centres and seat angles, and a 580Wh internal battery that takes an optional 160Wh range extender. The carbon frame is shared across the range, so the three builds differ only on parts.
The C1 is the flagship at 10,599 US dollars, with Fox Factory 36 and Float X suspension, Shimano XT Di2 wireless shifting, XT four-piston brakes and Crank Bros Synthesis carbon wheels. The C2, the only build Norco brings to the UK at 7,699 pounds, keeps almost the same package but swaps to Fox Performance Elite suspension, Deore Di2 shifting and alloy Synthesis wheels, which is where most riders will find the value. The C3 at 6,999 US dollars moves to DVO Diamond and Topaz suspension, mechanical Deore and TRP Slate EVO brakes on WTB alloy rims.
With 60Nm and 350W on tap rather than the 85Nm-plus of a full-power system, this is aimed at riders who want a natural, near-silent pedal-bike feel with just enough assistance to extend the day. The short seat tubes, long droppers and high-pivot rearward axle path point to a bike built to descend hard while staying composed on the climbs.
OWNERS’ REPORT
Norco Sight VLT (Shimano-era / 2025 CX) — what owners actually know
1,379 posts · 292 owners · data through May 2026
14CX: sizing runs big-for-the-number, and the shared Range frame invites long-shock builds · typical onset: At purchase (sizing) and during the first owning months (build changes).
12LEGACY (Shimano-era VLT): carbon chainstay / rocker-link / frame damage · typical onset: Chainstay: after chain jams; rocker link: with age/wear
11LEGACY (Shimano-era VLT, 2019-2024): water / charge-port and wire-harness electrical shutdowns (the used-buyer headline) · typical onset: From new in some cases; far more common in wet seasons / after pressure-washing
First ride on the 2025 CX: a 20-mile / 3,000ft loop with 43% battery left, 'insanely quiet descending', the high pivot 'noticeably plush on sharp edge bumps'.
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
S1S2S3S4S5
Reach422 mm447 mm472 mm497 mm522 mm
Stack618 mm627 mm636 mm645 mm654 mm
Seattube385 mm395 mm415 mm445 mm475 mm
Chainstay432 mm432 mm436 mm440 mm444 mm
Headtube Angle64°64°64°64°64°
Seattube Angle (eff)77°77.25°77.5°77.75°78°
Wheelbase1193 mm1222 mm1255 mm1289 mm1322 mm
Headtube105 mm115 mm125 mm135 mm145 mm
BB Height349 mm349 mm349 mm349 mm349 mm
Standover700 mm701 mm711 mm714 mm729 mm
Front Centre
Trims · 3
C2
£7,699
C1
C3
MotorTQ HPR60 · 60 Nm · all trims
BatteryTQ HPR 580Wh · 580 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbon · all trims
ForkFox 36 Performance Elite GripX2, HSC/LSC/HSR/LSR, 160mm, 44mm Offset, Fender IncludedFox 36 Factory Grip X2 HSC/LSC/HSR/LSR 160mm, 44mm Offset, Fender IncludedDVO Diamond 36 D1, High/Low Speed Compression | Rebound, 160mm, 44mm Offset
ShockFox Float X Performance, 230x60mm Std, 2 positionFox Factory Float X, 230x60mm Std, 2 positionDVO Topaz Pro Gen 3, 230x60mm Std
HeadsetFSA No.55 Sealed Bearing, 1 1/8" - 1.8" Tapered, ( ZS44/28.6 | ZS56/40 ) · all trims
StemNorco Alloy, 40mm Length, 35mm Clamp · all trims
HandlebarNorco 6061 DB Alloy, 800mm, 25mm RiseRaceFace Era Carbon, 760mm - 20mm rise (S1,S2), 780mm - 20mm rise (S3,S4), 780mm - 40mm rise (S5)Norco 6061 DB Alloy, 800mm, 25mm Rise
GripsWTB Wavelength, 140mm Length · all trims
SaddleWTB Rocket Fusion Med, 142x250 mm · all trims
SeatpostTranzX YSI08 RAD+ Travel Adjust Dropper, 31.6mm, 125mm (S1) -150mm (S2) -170mm (S3) -200mm (S4, S5)TranzX YSI08 RAD+ Travel Adjust Dropper, 31.6mm, 125mm (S1) -150mm (S2) -170mm (S3) -200mm (S4, S5)TranzX YSI36KL, 31.6mm, 125mm (S1) -150mm (S2) -170mm (S3) -200mm (S4, S5)
BrakesShimano Deore M6120 4-P, Metallic pads (front and rear); Brake levers Shimano Deore M6100Shimano XT M8220 4-P, Metallic pads (front and rear); Brake levers Shimano XT BL-M8200TRP Slate EVO, Organic Pads (front and rear); Brake levers TRP Slate EVO
Rear derailleurShimano Deore Di2 RD-M6250, SGS, 12spShimano Deore XT Di2 RD-M8250, SGS, 12spShimano Deore RD-M6100, SGS, 12sp
Cranke*thirteen Helix Race Alloy TQ, 34T, 155mm (S1,S2) - 160mm (S3,S4,S5)e*thirteen Helix Race Alloy TQ, 34T, 155mm (S1,S2) - 160mm (S3,S4,S5)e*thirteen Alloy TQ, 34T, 155mm (S1,S2) - 160mm (S3,S4,S5)
ShiftersShimano Deore Di2 SW-M6250-IR, 12spShimano Deore XT Di2 SW-M8250-IR, 12spShimano Deore SL-M6100-R, 12sp
CassetteShimano Deore CS-M6100-12, 10-51T, 12spShimano Deore XT CS-M8200-12, 10-51T, 12spShimano Deore CS-M6100-12, 10-51T, 12sp
ChainShimano Deore CN-M6100, 12spShimano Deore XT CN-M8100, 12spShimano Deore CN-M6100, 12sp
DrivetrainShimano Deore Di2, 12spShimano Deore XT Di2, 12spShimano Deore, 12sp
WheelsCrank Bros. Synthesis hubs, Crank Bros. Synthesis Alloy Enduro rimsCrank Bros. Synthesis Enduro hubs, Crank Bros. Synthesis Carbon Enduro rimsBear Pawls hubs, WTB ST i30 TCS 2.0 rims
TyresFront: Continental Kryptotal-F, Enduro, Soft, 29" x 2.4", Foldable; Rear: Continental Xynotal, Enduro, Soft, 27.5" x 2.4", Foldable · all trims
Weight20.6 kg20.2 kg20.9 kg
Price£7,699
Rides similarly
Spot a mistake?
