Bike Finder · Norco
Norco Range VLT
Norco
Range VLT 2024
CurrentEnduro eMTBAgeing · 3.4/10iFreshness 3.4/10
Bosch Performance CX 750Wh high-pivot enduro eMTB
Travel F/R
180/170mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium / Carbon front, aluminium rear
Weight
26.2 kg
Price
£6,999
View the Norco Range VLT on Norco’s site
Norco Range VLT 2024
From £6,999
EMTB Forums verdict
The 2024 Norco Range VLT is the brand's full-power enduro e-MTB and the long-travel flagship of the VLT family. This third-generation bike switched to a Bosch Performance Line CX Smart System motor (85Nm) with a 750Wh PowerTube battery, paired with 180mm front and 170mm rear travel on Norco's VPSHP high-pivot idler suspension. It runs an MX wheel setup (29in front, 27.5in rear) across all five frame sizes.
Three builds were offered. The carbon-front C1 is the halo spec with a RockShox Zeb Ultimate fork, Vivid Select+ shock, SRAM GX Eagle AXS T-Type wireless shifting and Code RSC brakes on 220/200mm rotors, with a claimed 26.2kg in size 3. The C2 shares the carbon-front frame but steps down to a Zeb Select+, mechanical GX Eagle and DB8 brakes. The aluminium A1 (UK RRP £6,999) keeps the same motor, battery, geometry and 180mm fork travel but uses a Zeb Select, SRAM NX/SX Eagle drivetrain and a narrower-range 11-50T cassette, making it the value entry point.
Geometry is firmly gravity-focused: a 63 degree head angle, size-specific seat angles from 76.5 to 77.5 degrees, size-specific rear centres growing from 428mm to 444mm, and a 359mm bottom bracket height. Reach spans 417.5mm (S1) to 517.5mm (S5) with wheelbases from 1202mm to 1336mm, so it is set up to be stable and planted at speed rather than playful.
This 2024 model is discontinued. Norco has since replaced it with the Range VLT CX line, which carries the platform forward under a revised naming scheme. Buyers looking at the 2024 bike today are almost always finding remaining clearance stock rather than current inventory.
💬 Forum discussion
Norco Range VLT Gen 4 2026
124 replies · 8.7k views · last reply 3 days ago
Join the discussion →
“Couple dad sends today on the local... YouTube”
— Blownoutrides · ♥ 7 · most-liked post
Frame
Carbon front triangle with alloy chainstays and seatstays, 170mm rear travel, high-pivot VPS-HP four-bar suspension, mullet 29in/27.5in wheels, Bosch PowerTube 750Wh integration, Ride Aligned design system.
Bike geometry diagram
S1S2S3S4S5
Reach417 mm442 mm467 mm492 mm517 mm
Stack621 mm630 mm639 mm648 mm657 mm
Seattube385 mm395 mm415 mm445 mm475 mm
Chainstay428 mm432 mm436 mm440 mm444 mm
Headtube Angle63°63°63°63°63°
Seattube Angle (eff)76.5°76.75°77°77.25°77.5°
Wheelbase1243 mm1256 mm1269 mm1295 mm1321 mm
Headtube100 mm110 mm120 mm130 mm140 mm
BB Height359 mm359 mm359 mm359 mm359 mm
Standover720 mm726 mm734 mm745 mm756 mm
Front Centre815 mm824 mm833 mm855 mm877 mm
Trims · 3
A1
£6,999
C1
C2
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R180/170 mm · all trims
FrameButted AluminumCarbon front triangle, alloy chainstay and seatstayCarbon front triangle, alloy chainstay and seatstay
ForkRockShox Zeb Select, 180mm Travel, E-MTB Rated, Fender IncludedRockShox Zeb Ultimate, 180mm Travel, E-MTB Rated, Fender IncludedRockShox Zeb Select+, 180mm Travel, E-MTB Rated, Fender Included
ShockRockShox Vivid Base, 230x65mmRockShox Vivid Select+, 230x65mmRockShox Vivid Select+, 230x65mm
HeadsetFSA No. 55 Sealed Bearing, 1 1/8" - 1.8" Tapered · all trims
Stem6061 Alloy, 40mm Length, 35mm Clamp · all trims
HandlebarButted 6061 Alloy, 800mm, 25mm Rise · all trims
GripsWTB Wavelength · all trims
SaddleSDG Bel Air V3 Lux Alloy · all trims
SeatpostTranzX YS134 Dropper, 34.9mm, 150mm (S1), 170mm (S2, S3), 200mm (S4, S5)TranzX YSI08FL RAD+ Travel Adjust Dropper, 34.9mm, 125mm (S1), 150mm (S2), 170mm (S3), 200mm (S4, S5)TranzX YSI08FL RAD+ Travel Adjust Dropper, 34.9mm, 125mm (S1), 150mm (S2), 170mm (S3), 200mm (S4, S5)
BrakesSRAM DB8 4 Piston, Sintered Pads (front and rear); SRAM DB8 leversSRAM Code RSC 4 Piston, Sintered Pads (front and rear); SRAM Code RSC leversSRAM DB8 4 Piston, Sintered Pads (front and rear); SRAM DB8 levers
Rear derailleurSRAM NX EagleSRAM GX Eagle AXS T-TypeSRAM GX Eagle
Cranke*Thirteen e*Plus 165mm · all trims
ShiftersSRAM NX Eagle MMXSRAM AXS POD Controller, Discrete ClampSRAM GX Eagle
CassetteSRAM PG1210 Eagle 11-50TSRAM 1275 T-Type 10-52TSRAM 1275 Eagle, 10-52T
ChainSRAM SX EagleSRAM GX Eagle T-TypeSRAM GX Eagle
DrivetrainSRAM NX Eagle; e*Thirteen e*Plus 165mm; SRAM NX Eagle MMX; SRAM PG1210 Eagle 11-50T; SRAM SX EagleSRAM GX Eagle AXS T-Type wireless 12-speedSRAM GX Eagle; e*Thirteen e*Plus 165mm; SRAM GX Eagle; SRAM 1275 Eagle, 10-52T; SRAM GX Eagle
WheelsWTB HTZ Trail 32H, 27.5"/29"Crank Brothers Synthesis E-Bike wheelset, 32H (27.5"/29")WTB HTZ Trail 32H, 27.5"/29"
TyresFront: Continental Kryptotal-F Enduro 29" x 2.4", Foldable; Rear: Continental Kryptotal Enduro 27.5" x 2.4", Foldable · all trims
Weight26.2 kg
Price£6,999
Rides similarly
Spot a mistake?
