Bike Finder · Nicolai
Nicolai S16 MGU
Nicolai
S16 MGU 2025
CurrentFull Power · EnduroAgeing · 4/10iFreshness 4/10
German-made 7020-T6 aluminium Pinion MGU enduro
Motor
Pinion MGU (E1.12) · 85Nm · 600W
Battery
FIT TubePack 800 · 800Wh
Travel F/R
160/160mm
Wheels
29F / 29R or MX
Frame
Aluminium
Weight
Price
From £9,856
View the Nicolai S16 MGU on Nicolai’s site
Nicolai S16 MGU 2025
From £9,856
EMTB Forums verdict
The Nicolai S16 MGU 2025 is the German specialist's gearbox-equipped enduro eMTB, built around the Pinion MGU (E1.12) motor and gearbox unit (85 Nm torque, 250 W rated, 600 W manufacturer-claimed peak, 4.1 kg) and a 720 Wh FIT Tubepack battery. Travel is 160 mm front and 160 mm rear on a hand-welded aluminium chassis with Horst Link suspension. Five sizes from S to XXL, reach 468 to a properly stretched 550 mm, head angle 64.5 degrees flat, chainstays 459 mm. Single base trim at £9,300, claimed weight 28.5 kg. The community read in one line: an obsessively-engineered German enduro on the most innovative motor-gearbox unit in the industry, sold to riders who appreciate the Pinion MGU's belt-drive simplicity but accept it's a V1.0 platform with documented teething issues.
Drive system and range. The Pinion MGU E1.12 is the headline of the bike — a combined motor and 12-speed internal gearbox in a single unit, eliminating the rear derailleur and cassette in favour of a sealed gearbox with a belt drive. 85 Nm torque, 600 W peak, 4 times assistance ratio. @zizajaun confirms the spec. The 720 Wh battery is removable; an 800 Wh option is also available. Real-world range will sit in the 45 to 65 km territory depending on terrain. Reliability is the open question — see Caveats.
Geometry and handling. Properly Nicolai: long, sensible head angle, hand-welded TIG aluminium. 64.5 degree head angle is bang on the enduro norm. Reach is generous — 468 mm (S) through to 550 mm (XXL) — among the longest size range in the entire eMTB market and well-suited to very tall riders who struggle to find genuinely-long platforms. Chainstays held at 459 mm flat is the one geometry compromise. Wheelbase scales from 1283 to a stretched 1380 mm.
Build and value. Single base trim at £9,300 (28.5 kg). The 28.5 kg claimed weight is class-leading heavy for an eMTB and reflects the 4.1 kg Pinion MGU plus aluminium chassis. At this price expect Ohlins or RockShox Zeb Ultimate suspension at 160 mm front (longer fork option to 170 mm), high-end coil or air shock, Intent Trinity or Magura MT7 brakes, and the integrated Pinion shifter (no rear derailleur). Pricing is German-specialist territory rather than mainstream.
Community-verified strengths.
  • @emonty documented 4,000 km of mostly off-road riding in dirt, slob, rain and snow. MGU replaced at 3,000 km under 2-year warranty, snapped belt replaced in 5 minutes. "I love this bike, gives me a big grin every time I ride it. Nicolai's service is top notch."
  • Hand-built German aluminium frame with proper engineering pedigree. Lifetime potential with the right support.
  • Belt drive plus internal gearbox means no chain stretch, no derailleur hangers, no cassette wear, and shifting under load with the bike stationary — properly different from a regular eMTB.
Caveats and known gripes.
  • @monkeynuts documented multiple issues: 800 Wh battery failed twice (faulty batch from manufacturer), motor developed a whistling/squeaking noise from a seal not getting lubrication. Motor was exchanged under warranty and the issues resolved post-update.
  • 28.5 kg claimed weight is properly heavy. This is the heaviest production eMTB at this travel category by a noticeable margin.
  • Pinion MGU is V1.0 technology. @slickrock calls it "an early-adopter product" rather than beta. Buyers need to understand the long-term reliability story is still being written.
  • Belt tensioner location on the underside of the bike is vulnerable to rock strike damage.
  • £9,300 is premium pricing for a single base trim with no upgrade path within the model line.
Verdict. The Nicolai S16 MGU 2025 is a properly considered, hand-built German enduro for early adopters of the Pinion MGU gearbox-motor concept. It suits riders who value engineering craftsmanship, who appreciate Pinion's internal gearbox approach for low maintenance and shifting flexibility, and who accept that the MGU is still developing through firmware and component revisions. Look elsewhere if you want a proven mainstream drivetrain, sub-26 kg weight, or wider brand support outside central Europe. Production status: current, single base trim, five sizes from S to XXL.
Geometry read
Size
Descending
68
A solid all-round descender (64.5° head angle, 160mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
11
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
73
Front-long in L: 873mm front centre on 459mm stays (FC:RC 1.90). Planted and composed; rewards a forward, attacking stance.
Technical climbing
56
Climbs well — a 77.4° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 132 bikes in the database)
Battery800 Wh64 Wh above average
Motor torque85 Nm18 Nm below average
Value for money5/100from £9,856 · comparable bikes ~£5,154
Bike geometry diagram
SMLXLXXL
Reach468 mm490 mm510 mm530 mm550 mm
Stack643 mm652 mm660 mm670 mm670 mm
Chainstay459 mm459 mm459 mm459 mm459 mm
Headtube Angle64.5°64.5°64.5°64.5°64.5°
Seattube Angle (eff)77.4°77.4°77.4°77.4°77.4°
Wheelbase1283 mm1307 mm1332 mm1355 mm1380 mm
Front Centre824 mm848 mm873 mm896 mm921 mm
FC:RC1.801.851.901.952.01
Trims · 2
S16 MGU 800Wh
£9,856
S16 MGU 1060Wh
£10,029
MotorPinion MGU (E1.12) · 85 Nm · all trims
BatteryFIT TubePack 800 · 800 Wh · all trims
Travel F/R160/160 mm · all trims
FrameAluminium · all trims
ForkFOX 38 Factory GRIP2 160mm · all trims
ShockFOX DHX Factory 205x65mm · all trims
HeadsetACROS BlockLock ZS56/28,6 ZS56/40 · all trims
Steme*thirteen TRS Base 40mm · all trims
HandlebarBikeYoke Barmate AL7050 D35 800x25mm · all trims
GripsSQlab 7OX 2.0 · all trims
SaddleSQlab 6OX Ergowave Active · all trims
SeatpostBikeYoke Divine 30.9 · all trims
BrakesMagura MT7 · all trims
ShiftersPinion TE1 · all trims
ChainGates Carbon Drive CDX 125T belt · all trims
DrivetrainPinion E1.12 MGU 12-speed gearbox, Gates Carbon Drive belt · all trims
WheelsDT Swiss HX 1700 29" · all trims
TyresSchwalbe Eddy Current Evo 29x2.6" (front ST / rear SG), TLE · all trims
Price£9,856£10,029
Rides similarly
Spot a mistake?
