Bike Finder · Nicolai
no image yet
Nicolai
GT1 EBOXX 2023
DiscontinuedFull Power · EnduroLegacy · 1/10iFreshness 1/10
Travel F/R
160/160mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
27.2 kg
Price
View the Nicolai GT1 EBOXX on Nicolai’s site
Nicolai GT1 EBOXX 2023
EMTB Forums verdict
The Nicolai GT1 EBOXX is the touring-flavoured all-mountain member of Nicolai's hand-welded German aluminium EBOXX line, built in 7020-T6 to order at the brand's factory in Mehle, Lower Saxony. The GT1 shares the EBOXX platform's 160mm of Horst-Link travel and 64.25-degree head angle with the enduro G1, but uses the Geolution Tour geometry: a raised, more upright front end for a comfortable, versatile position rather than the race-focused riding position of the G1. All builds run a Bosch Performance Line CX Smart System motor (85 Nm, 600 W peak) on a mullet 29/27.5 wheel setup across five sizes from S to XXL covering 1.55m to 2.10m riders.
For 2023 the GT1 EBOXX came in three builds. The QLF (from 8,999 EUR) is the derailleur model, running a SRAM GX Eagle 12-speed drivetrain, EXT e-Storia shock, Magura MT7 brakes and a RockShox Reverb AXS dropper on a 700 Wh PowerTube. The E14 (from 10,499 EUR) swaps the cassette for a Rohloff Speedhub E14 electronic 14-speed hub gear and Gates Carbon Drive belt, also on a 700 Wh pack. The newest 3x3 (from 10,499 EUR, marketed as the EWB) uses the EFFIGEAR-derived 3x3 NINE 9-speed grease-lubricated gear hub with a Gates belt, paired with a Fox 38 fork, Fox DHX coil shock and the larger 750 Wh battery, pitched as a lower-maintenance alternative to the Rohloff.
Common to all three is Nicolai's TIG-welded, fully machined construction, Fox 38 GRIP2 Factory fork, Hope Fortus wheels, Continental Der Baron tyres and SQlab finishing kit, plus a 5-year frame warranty and 10-year spare-parts guarantee. The optional Explorer Kit (mudguards, rack, lights) extends the bike to commuting and touring duty. At a claimed 27.2kg it is a heavy, deliberately over-built machine whose appeal rests on durability, hub-gear or belt-drive low maintenance and full customisation rather than light weight.
This 2023 GT1 EBOXX has since been discontinued and replaced by the current GT1 EBOXX NST, which carries the same Geolution Tour platform and Bosch CX drive with a Rohloff E14 belt-drive build.
Geometry read
Size
Descending
72
Slack 64.25° head angle, 160mm travel and a long 1336mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
28
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
53
Very front-long in L: 889mm front centre on 447mm stays (FC:RC 1.99). Rock-steady at speed, but you have to actively weight the front in flatter corners.
Technical climbing
49
Climbs well — a 77.9° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
Watch out forL runs front-long (FC:RC 1.99).
A 889mm front centre on 447mm stays means taller riders must actively weight the front to keep it gripping. The chainstay stays 447mm on every size, so L feels more front-long than the smaller sizes.
How it stacks up vs other Full Power · Enduro bikes (from 137 bikes in the database)
Weight27.2 kg3.4 kg heavier than average
Battery750 Whabout average capacity
Motor torque85 Nm18 Nm below average
Bike geometry diagram
SMLXLXXL
Reach475 mm495 mm515 mm535 mm560 mm
Stack637 mm647 mm655 mm665 mm673 mm
Seattube415 mm460 mm485 mm505 mm525 mm
Chainstay447 mm447 mm447 mm447 mm447 mm
Headtube Angle64.25°64.25°64.25°64.25°64.25°
Seattube Angle (eff)77.6°77.7°77.9°78°78.2°
Wheelbase1292 mm1312 mm1336 mm1358 mm1385 mm
Headtube150 mm160 mm170 mm180 mm190 mm
Standover762 mm770 mm794 mm814 mm833 mm
Front Centre845 mm*865 mm*889 mm*911 mm*938 mm*
FC:RC1.891.941.992.042.10
Trims · 3
3x3
E14
QLF
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R160/160 mm · all trims
FrameAluminium (7020-T6) · all trims
ForkFOX RACING SHOX 38 Float 160mm GRIP2 Factory · all trims
ShockFOX RACING SHOX DHX Performance 2POS 230-65 2022EXT e-Storia 230x65mmEXT e-Storia 230x65mm
HeadsetACROS BlockLock · all trims
StemSQlab 80X Vorbau 35mmSQlab 80X 50mmSQlab 80X 50mm
HandlebarSQlab 30X Alu high 780x45mm 12 degrees · all trims
GripsSQlab 70X · all trims
SaddleSQlab 60X Ergowave Active · all trims
SeatpostBIKEYOKE DIVINE 185mmROCKSHOX Reverb AXS 30.9 175mm
BrakesMAGURA MT7, HC 203MAGURA MT7, HC 203
Rear derailleur3x3 NINE hub gearROHLOFF Speedhub E14SRAM GX EAGLE
CrankMIRANDA Kapa 160Q:16 RF PRTM 160 mm blackHOPE eBike Crankset 165mm blackHOPE eBike Crankset 165mm black
Shifters3x3 NINE GripshifterROHLOFF e-TRIGGERSRAM GX EAGLE single click
CassetteSRAM PG-1230 11-50
ChainGATES CDX 130T beltGATES CDX 128T beltSRAM NX EAGLE
Drivetrain3x3 NINE hub gear; MIRANDA Kapa 160Q:16 RF PRTM 160 mm black; 3x3 NINE Gripshifter; GATES CDX 130T beltROHLOFF Speedhub E14; HOPE eBike Crankset 165mm black; ROHLOFF e-TRIGGER; GATES CDX 128T beltSRAM GX EAGLE; HOPE eBike Crankset 165mm black; SRAM GX EAGLE single click; SRAM PG-1230 11-50; SRAM NX EAGLE
WheelsHOPE FORTUS 30WHOPE FORTUS 35WHOPE FORTUS 35W
TyresCONTINENTAL Der Baron Project ProTection Apex 29x2.4" front / CONTINENTAL Der Baron Project ProTection Apex 27.5x2.6" rear · all trims
Weight27.2 kg · all trims
Rides similarly
Spot a mistake?
