Bike Finder · Nicolai
Nicolai GT1 EBOXX
Nicolai
GT1 EBOXX 2022
DiscontinuedFull Power · EnduroLegacy · 1/10iFreshness 1/10
Overbuilt German alloy all-mountain bike prized for durability
Travel F/R
160/160mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
Price
From €8,399
View the Nicolai GT1 EBOXX on Nicolai’s site
Nicolai GT1 EBOXX 2022
EMTB Forums verdict
The Nicolai GT1 EBOXX is the touring-flavoured all-mountain member of Nicolai's hand-welded German aluminium EBOXX line, built to order in 7020-T6 alloy at the brand's own factory in Mehle, Lower Saxony. For 2022 Nicolai completely reworked the EBOXX frame, adding a fully CNC-machined head tube, a redesigned multi-chamber down tube to accept the larger 750 Wh battery and a hollow-milled chainstay yoke, saving around 500 g. The GT1 shares the EBOXX platform's 160 mm of Horst-Link travel, mullet 29/27.5 wheels and 64.25-degree head angle with the enduro G1, but uses the Geolution Tour geometry: a longer head tube and more upright front end for a more comfortable, versatile position across five sizes from S to XXL.
Two builds are documented here. The E14 (from 9,989 EUR) pairs the electronic Rohloff Speedhub E14 14-speed hub gear and Gates Carbon Drive belt with the 4th Gen Bosch Performance Line CX motor (85 Nm) and a 625 Wh PowerTube, using a Bosch Nyon display. The QLF (from 8,399 EUR) is the derailleur model, running a SRAM GX Eagle 12-speed drivetrain and the 5th Gen Bosch Performance Line CX Smart System with a 750 Wh PowerTube and Kiox 300 display. Both share a Fox Float 38 Factory GRIP2 fork, EXT e-Storia shock, Magura MT7 brakes on 203 mm rotors, Hope Fortus 35W wheels, Continental Der Baron tyres, a BikeYoke Divine dropper and SQlab finishing kit. A mechanical-Rohloff MR14 variant was also offered.
Chainstay length is adjustable via swappable MUTATOR elements and RADO sliding dropouts, and the optional Explorer Kit adds mudguards, rack and lights for commuting and touring. Nicolai backs the frame with a 5-year warranty and a 10-year spare-parts guarantee. This is a deliberately over-built, fully customisable machine whose appeal rests on durability, hub-gear or belt-drive low maintenance and made-to-order fit rather than light weight.
The 2022 GT1 EBOXX has since been discontinued, superseded by later GT1 EBOXX models on the same Geolution Tour platform with the Bosch CX drive.
Geometry read
Size
Descending
73
Slack 64.25° head angle, 160mm travel and a long 1336mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
36
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
53
Very front-long in L: 889mm front centre on 447mm stays (FC:RC 1.99). Rock-steady at speed, but you have to actively weight the front in flatter corners.
Technical climbing
49
Climbs well — a 77.9° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
Watch out forL runs front-long (FC:RC 1.99).
A 889mm front centre on 447mm stays means taller riders must actively weight the front to keep it gripping. The chainstay stays 447mm on every size, so L feels more front-long than the smaller sizes.
How it stacks up vs other Full Power · Enduro bikes (from 160 bikes in the database)
Battery750 Whabout average capacity
Motor torque85 Nm17 Nm below average
Bike geometry diagram
SMLXLXXL
Reach475 mm495 mm515 mm535 mm560 mm
Stack637 mm647 mm655 mm665 mm673 mm
Seattube415 mm460 mm485 mm505 mm525 mm
Chainstay447 mm447 mm447 mm447 mm447 mm
Headtube Angle64.25°64.25°64.25°64.25°64.25°
Seattube Angle (eff)77.6°77.7°77.9°78°78.2°
Wheelbase1292 mm1312 mm1336 mm1358 mm1385 mm
Headtube150 mm160 mm170 mm180 mm190 mm
Standover762 mm770 mm794 mm814 mm833 mm
Front Centre845 mm*865 mm*889 mm*911 mm*938 mm*
FC:RC1.891.941.992.042.10
Trims · 2
E14
€9,989
QLF
€8,399
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R160/160 mm · all trims
FrameAluminium (7020-T6 TIG-welded) · all trims
ForkFOX FLOAT 38 Factory, GRIP2 damper, Kashima coating, 44mm offset, 160mm · all trims
ShockEXT e-Storia, 230mm x 65mm · all trims
HeadsetACROS Block Lock · all trims
StemSQlab 80X, 50mm length · all trims
HandlebarSQlab 30X, aluminium, 780mm width, 45mm rise, 12 degree sweep · all trims
GripsSQlab 70X, M · all trims
SaddleSQlab 60X Ergowave active, 140mm width · all trims
SeatpostBikeYoke Divine dropper, 185mm drop · all trims
BrakesMagura MT7, 4-piston, 203mm rotorsMagura MT7, 4-piston, Magura HC 203mm rotors
Rear derailleurRohloff Speedhub E14 internally geared hub, 14-speed, electronic shifting, 526% rangeSRAM GX Eagle, 12-speed
CrankHope Tech eBike, 165mm length · all trims
ShiftersRohloff e-Trigger, 14-speed, electronicSRAM GX Eagle, 12-speed, single-click
CassetteGates Carbon Drive, single cog, 20 tooth (SM/XL/XXL), 22 tooth (MD/LG)SRAM NX Eagle PG-1230, 12-speed, 11-50 tooth
ChainGates Carbon Drive CDX belt, 128 toothSRAM NX Eagle, 12-speed
DrivetrainRohloff Speedhub E14 internally geared hub, 14-speed, electronic shifting, 526% range; Hope Tech eBike, 165mm length; Rohloff e-Trigger, 14-speed, electronic; Gates Carbon Drive, single cog, 20 tooth (SM/XL/XXL), 22 tooth (MD/LG); Gates Carbon Drive CDX belt, 128 toothSRAM GX Eagle, 12-speed; Hope Tech eBike, 165mm length; SRAM GX Eagle, 12-speed, single-click; SRAM NX Eagle PG-1230, 12-speed, 11-50 tooth; SRAM NX Eagle, 12-speed
WheelsHope Tech Fortus 35 W · all trims
TyresContinental Der Baron Projekt, ProTection Apex, 29" x 2.4" (front), 27.5" x 2.6" (rear) · all trims
Price€9,989€8,399
Rides similarly
Spot a mistake?
