Bike Finder · Nicolai
Nicolai G1 Eboxx
Nicolai
G1 Eboxx 2025
CurrentEnduro eMTBAgeing · 4.6/10iFreshness 4.6/10
Travel F/R
160/160mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
27.2 kg
Price
£5,620
View the Nicolai G1 Eboxx on Nicolai’s site
Nicolai G1 Eboxx 2025
From £5,620
EMTB Forums verdict
The Nicolai G1 Eboxx is a German hand-welded aluminium enduro eMTB built around the brand's Geolution philosophy: a long wheelbase, a slack 64.7-degree head angle and a steep effective seat angle (78 to 79 degrees) across five sizes from S to XXL. The KLF is positioned as the most aggressive, lightest and fastest build in the Eboxx line-up, with 160 mm of travel front and rear, a mixed 29in front and 27.5in rear wheel setup, and a Horst-Link rear end.
Power comes from the Bosch Performance Line CX (Smart System) with 85 Nm and a 600 W peak, paired with a 750 Wh Bosch PowerTube battery, Kiox 300 display and LED Remote. The CX Race motor is offered as an option for riders chasing a sharper, race-focused tune. The published build leans on a 1x12 SRAM GX Eagle drivetrain, Schwalbe Eddy Current Evo tyres, a BikeYoke Divine dropper and SQlab grips, with the fork, shock and brakes selected to suit through Nicolai's bespoke ordering process.
At a claimed 27.2 kg it is a heavyweight, and the from-price of 9,499 euro reflects its small-batch, made-to-order nature rather than a value play. The reward is a frame built to be tuned to the rider: the Slide AFE dropouts allow chainstay length to be set, and the geometry is scaled per size rather than simply stretched. This is a bike for riders who want a durable alloy race chassis and are happy to spec it themselves.
Bike geometry diagram
SMLXLXXL
Reach480 mm497 mm515 mm535 mm550 mm
Stack649 mm667 mm667 mm686 mm686 mm
Seattube435 mm458 mm475 mm495 mm520 mm
Chainstay464 mm464 mm464 mm471 mm471 mm
Headtube Angle64.7°64.7°64.7°64.7°64.7°
Seattube Angle (eff)78°78.5°78.75°79°79°
Wheelbase1298 mm1323 mm1341 mm1364 mm1385 mm
Headtube150 mm170 mm170 mm190 mm190 mm
Standover775 mm775 mm775 mm795 mm818 mm
Front Centre834 mm*859 mm*877 mm*893 mm*914 mm*
Trims · 1
KLF
£5,620
MotorBosch Performance Line CX Gen 4 · 85 Nm
BatteryBosch PowerTube 750 · 750 Wh
Travel F/R160/160 mm
FrameAluminium
HeadsetACROS BlockLock
GripsSQlab 7OX
SeatpostBikeYoke Divine 30.9, 185 mm
Rear derailleurSRAM GX Eagle
CrankMiranda Kapa 160Q (160 mm), SRAM Bosch X-Sync 34T chainring
CassetteSRAM PG-1230 11-50
ChainSRAM NX Eagle
DrivetrainSRAM GX Eagle; Miranda Kapa 160Q (160 mm), SRAM Bosch X-Sync 34T chainring; SRAM PG-1230 11-50; SRAM NX Eagle
TyresFront: Schwalbe Eddy Current Front Evo, ST, TLE 29x2.6; Rear: Schwalbe Eddy Current Rear Evo, SG, TLE 27.5x2.6
Weight27.2 kg
Price£5,620
Rides similarly
Spot a mistake?
