Bike Finder · Moustache
no image yet
Moustache
Samedi 27 Wide 2025
CurrentFull Power · Cross-CountryAgeing · 4.6/10iFreshness 4.6/10
Travel F/R
130/120mm
Wheels
27.5F / 27.5R
Frame
Aluminium
Weight
24.4 kg
Price
From £3,399
View the Moustache Samedi 27 Wide on Moustache’s site
Moustache Samedi 27 Wide 2025
From £3,399
EMTB Forums verdict
The Samedi 27 Wide is Moustache's comfort-focused alloy trail eMTB, pairing 130mm of front travel with 120mm at the rear over 27.5in wheels shod in plus-width Maxxis Rekon 2.80 tyres. It uses the brand's own Magic Grip Control air shock and the Bosch Performance Line CX Smart System motor with an 85Nm output and a 625Wh PowerTube battery, with claimed range of around 107 to 108km.
Two builds were offered for 2025 in the UK. The Wide 3 at £3,399 runs an SR Suntour XCR 34 fork, two-piston Shimano MT410 brakes and an 11-speed Shimano Deore drivetrain. The Wide 5 at £3,699 is the more capable pick for the £300 step up: it gains a Marzocchi Bomber Z2 fork, four-piston Shimano MT420 brakes for stronger stopping on plus-tyre weight, a 12-speed Shimano XT rear mech and the larger Kiox 300 display in place of the Wide 3's Intuvia 100.
Geometry is consistent and conservative across the four sizes, with a head angle of roughly 65.6 to 66 degrees, a 72.6 degree effective seat angle and a fixed 458mm rear centre. Reach runs from 382mm on the S to 454mm on the XL. The slacker-than-XC front end, plus tyres and short stays point to an easygoing, stable ride aimed at accessibility rather than aggressive descending.
Geometry read
Size
Descending
50
A solid all-round descender (66° head angle, 120mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
52
Size balance
71
Rear-long with a planted front in L (FC:RC 1.65) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
70
Climbs well — a 72.6° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Cross-Country bikes (from 98 bikes in the database)
Weight24.4 kg0.8 kg heavier than average
Battery625 Wh78 Wh below average
Motor torque85 Nm9 Nm below average
Value for money54/100from £3,399 · most Bosch Performance Line CX Gen 4 bikes ~£3,499
Bike geometry diagram
SMLXL
Reach382 mm409 mm432 mm454 mm
Stack611 mm622 mm635 mm641 mm
Chainstay458 mm458 mm458 mm458 mm
Headtube Angle65.6°65.9°66°66°
Seattube Angle (eff)72.6°72.6°72.6°72.6°
Wheelbase1161 mm1188 mm1215 mm1241 mm
Headtube130 mm140 mm150 mm160 mm
BB Height348 mm348 mm348 mm348 mm
Standover741 mm739 mm743 mm757 mm
Front Centre703 mm*730 mm*757 mm*783 mm*
FC:RC1.531.591.651.71
Trims · 2
Wide 3
£3,399
Wide 5
£3,699
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 625 · 625 Wh · all trims
Travel F/R130/120 mm · all trims
FrameAluminium · all trims
ForkSR Suntour, XCR 34, preload adjustment & lockout function, 130mm travelMarzocchi, Bomber Z2, RAIL, compression sweep adjust, 130mm travel, 15x110mm, Boost, 44mm offset
ShockMoustache, Magic Grip Control 120, specific Air Shock with 2-position platform and dynamic control of rebound, Trunnion mount, built-in 165x45mm, 120mm travel · all trims
HeadsetFSA, No 57B · all trims
StemMoustache, 3D forged Aluminum, 60mm · all trims
HandlebarMoustache, alloy, 740mm, 15mm rise, 9° backsweep, 5° upsweep · all trims
GripsSB3, Ergonomic · all trims
SaddleSelle Royal, Essenza Moderate Men · all trims
SeatpostEXA, 900i, dropper-post w/remote lever, 31.6mm, size-specific travel (150mm)EXA, 900i, dropper-post w/remote lever, 31.6mm, size-specific travel (100/125/150/150mm; 100mm on S)
BrakesShimano, MT410, hydraulic disc (front & rear)Shimano, MT420, hydraulic disc, 4 pistons (front & rear)
Rear derailleurShimano, Deore, RD-M5100-SGS, 11-speedShimano, XT, RD-M8100-SGS, 12-speed
CrankMoustache, forged aluminium, 165mm; FSA Narrow Wide 34T chainring · all trims
ShiftersShimano, Deore, SL-M5100-R, 11-speedShimano, Deore, SL-M6100, 12-speed
CassetteShimano, Deore, CS-M5100 11-speed, 11-51TSunrace, CSMZ8, 12-speed, 11-51T
ChainSram, PC1110, 11-speed, 120 linksShimano, CN-M6100, 12-speed, 120 links
DrivetrainShimano, Deore, RD-M5100-SGS, 11-speed; Moustache, forged aluminium, 165mm; FSA Narrow Wide 34T chainring; Shimano, Deore, SL-M5100-R, 11-speed; Shimano, Deore, CS-M5100 11-speed, 11-51T; Sram, PC1110, 11-speed, 120 linksShimano, XT, RD-M8100-SGS, 12-speed; Moustache, forged aluminium, 165mm; FSA Narrow Wide 34T chainring; Shimano, Deore, SL-M6100, 12-speed; Sunrace, CSMZ8, 12-speed, 11-51T; Shimano, CN-M6100, 12-speed, 120 links
WheelsMoustache, asymmetric, alloy 6061E, welded, double wall, 28 holes, 27.5'', internal width 35mm, mounted with Tubeless valves & flap · all trims
TyresMaxxis, Rekon, 27.5x2.80 · all trims
Weight24.7 kg24.4 kg
Price£3,399£3,699
Rides similarly
Spot a mistake?
