Bike Finder · Moustache
Moustache Game 150
Moustache
Game 150 2026
CurrentTrail/Enduro eMTBCurrent · 8.5/10iFreshness 8.5/10
Travel F/R
160/150mm
Wheels
29F / 29R
Frame
Aluminium
Weight
23.6 kg
Price
From £4,499
View the Moustache Game 150 on Moustache’s site
Moustache Game 150 2026
From £4,499
EMTB Forums verdict
The Moustache Game 150 is the more trail-oriented sibling in the new-frame Game family, pairing 150mm of rear travel with a 160mm fork and the Bosch Performance Line CX motor. With the latest Smart System update it now delivers up to 120 Nm of torque and 600 per cent assistance, fed by a 600Wh or 750Wh PowerTube and expandable with the optional 250Wh PowerMore range extender. The Game 160 shares the same chassis but runs more travel for harder enduro use.
The aluminium frame uses Moustache's Magic Grip Control shock under a lowered top tube, and the geometry leans towards composure rather than aggression: a 64.7 degree head angle, long 462mm chainstays across all four sizes (S to XL) and a moderate seat angle. Reach runs from 437mm on the S to 510mm on the XL, with a consistent 349mm bottom bracket height.
Across the four trims the frame, motor and Maxxis Assegai tyres stay constant, so the spend buys suspension and drivetrain. The 150.5 at £4,499 runs a Marzocchi Z2 fork, Magura MT5 brakes and Shimano CUES, while the 150.6 steps up to a 160mm Marzocchi Z1 and Shimano XT mech. The 150.7 at £5,399 adds a Fox 36 Performance fork and Shimano XT brakes. The flagship 150.8 at £6,299 brings a Fox 36 Factory fork, wireless SRAM GX AXS T-Type shifting and a carbon bar, making it the natural pick for riders who want the lighter-action electronic drivetrain and top-tier damper.
Bike geometry diagram
SMLXL
Reach437 mm465 mm485 mm510 mm
Stack621 mm632 mm648 mm657 mm
Chainstay462 mm462 mm462 mm462 mm
Headtube Angle64.7°64.7°64.7°64.7°
Seattube Angle (eff)76.3°76.3°76.3°76.3°
Wheelbase1228 mm1260 mm1289 mm1316 mm
Headtube100 mm112 mm130 mm140 mm
BB Height349 mm349 mm349 mm349 mm
Standover830 mm830 mm830 mm830 mm
Front Centre766 mm*798 mm*827 mm*854 mm*
Trims · 4
150.5
£4,499
150.6
£4,899
150.7
£5,399
150.8
£6,299
MotorBosch Performance Line CX Gen 5 · 120 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R160/150 mm · all trims
FrameAluminium · all trims
ForkMarzocchi, Bomber Z2, RAIL, compression sweep adjust, 150mm travel, 15x110mm, Boost, 44mm offsetMarzocchi, Bomber Z1, RAIL 2.0, compression sweep adjust, 160mm travel, 15x110mm, Boost, 44mm offsetFOX, 36 Performance, GRIP, 3-position w/Micro Adjust lever, 160mm travel, 15x110mm, Boost, 44mm Offset, mini-fender mountedFOX, 36 Factory, Kashima coating, GRIP X2 w/ HSC/LSC/HSR/LSR, 160mm travel, 15x110mm, Boost, 44mm Offset, mini-fender mounted
ShockMoustache, Magic Grip Control 150, specific Air Shock w/ 2-position platform and dynamic control of rebound, build-in 230x60mm, 150mm travel · all trims
HeadsetAcros, AZF-725, sealed bearings, internal routing, integrated multi-tool · all trims
StemMoustache, alloy, 3D forged, 40mmMoustache, alloy, 3D forged, 40mmMoustache, alloy, 3D forged, 40mmMoustache, alloy, CNC, 40mm
HandlebarMoustache, alloy, 780mm, 31.8mm, 12mm rise, 9 backsweep, 4 upsweepMoustache, alloy, 780mm, 31.8mm, 12mm rise, 9 backsweep, 4 upsweepMoustache, alloy, 760mm, 31.8mm, 12mm rise, 9 backsweep, 5 upsweepMoustache, Just_Carbon, 780mm, 31.8mm, 12mm rise, 9 backsweep, 4 upsweep
GripsSB3, Race · all trims
SaddleMoustache, Sport, steel railsSelle Royal, SRXSelle Royal, SRXFizik, Terra Aidon X5
SeatpostEXA, 900i, dropper-post w/remote lever, 31.6mm, 170mmEXA, 900i, dropper-post w/remote lever, 31.6mm, 170mmKS, Rage-i, dropper-post w/ Shimano remote lever, 31.6mm, 150mmKS, Rage-i, dropper-post w/ Shimano remote lever, 31.6mm, 190mm
BrakesMagura, MT5, hydraulic disc, 4 pistons (front and rear)Magura, MT5, hydraulic disc, 4 pistons (front and rear)Shimano, XT, BR-M8120, hydraulic disc, 4 pistons (front and rear)Shimano, XT, BR-M8120, hydraulic disc, 4 pistons (front and rear)
Rear derailleurShimano, CUES, RD-U6000-GS, 10/11-speedShimano, XT, RD-M8100-SGS, 12-speedShimano, XT, RD-M8100-SGS, 12-speedSRAM, GX AXS T-Type, 12-speed, electronic
CrankFSA, aluminum, 165mm; Narrow-Wide chainring 34 teethFSA, aluminum, 165mm; Narrow-Wide chainring 34 teethFSA, aluminum, 165mm; Narrow-Wide chainring 34 teethFSA, forged + CNC aluminium, 165mm; SRAM T-Type Narrow Wide chainring 36 teeth
ShiftersShimano, CUES, SL-U6000-11R, 11-speedShimano, Deore, SL-M6100, 12-speedShimano, SLX, SL-M7100, 12-speedSRAM, AXS Pod, 12-speed
CassetteShimano, CUES, CS-LG400 11-speed, 11-50TShimano, Deore, CS-M6100 12-speed, 10-51TShimano, SLX, CS-M7100 12-speed, 10-51TSRAM, XS-1270 12-speed, 10-52T
ChainShimano, LG500, 120 linksShimano, CN-M6100, 12-speed, 120 linksShimano, CN-M6100, 12-speed, 120 linksSRAM, GX T-Type, 12-speed, 122 links
DrivetrainShimano, CUES, RD-U6000-GS, 10/11-speed; FSA, aluminum, 165mm; Narrow-Wide chainring 34 teeth; Shimano, CUES, SL-U6000-11R, 11-speed; Shimano, CUES, CS-LG400 11-speed, 11-50T; Shimano, LG500, 120 linksShimano, XT, RD-M8100-SGS, 12-speed; FSA, aluminum, 165mm; Narrow-Wide chainring 34 teeth; Shimano, Deore, SL-M6100, 12-speed; Shimano, Deore, CS-M6100 12-speed, 10-51T; Shimano, CN-M6100, 12-speed, 120 linksShimano, XT, RD-M8100-SGS, 12-speed; FSA, aluminum, 165mm; Narrow-Wide chainring 34 teeth; Shimano, SLX, SL-M7100, 12-speed; Shimano, SLX, CS-M7100 12-speed, 10-51T; Shimano, CN-M6100, 12-speed, 120 linksSRAM, GX AXS T-Type, 12-speed, electronic; FSA, forged + CNC aluminium, 165mm; SRAM T-Type Narrow Wide chainring 36 teeth; SRAM, AXS Pod, 12-speed; SRAM, XS-1270 12-speed, 10-52T; SRAM, GX T-Type, 12-speed, 122 links
WheelsMoustache, asymmetric, alloy 6061E, welded, double wall, 28 holes, 29'', internal width 30mm, tubeless ready · all trims
TyresMaxxis, Assegai, 29x2.50, foldable, EXO/TR (Tubeless Ready), front and rearMaxxis, Assegai, 29x2.50, foldable, EXO/TR (Tubeless Ready), front and rearMaxxis, Assegai, 29x2.50, foldable, EXO/TR (Tubeless Ready), front and rearMaxxis, Assegai, 29x2.50, foldable, 3C MaxxTerra / EXO+ / TR (Tubeless Ready), front and rear
Weight24.9 kg23.6 kg24.7 kg24.8 kg
Price£4,499£4,899£5,399£6,299
Rides similarly
Spot a mistake?
