Steeper 69° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Thundra 2023
Aggressive alloy hardtail with long geometry and a big 720Wh battery
The 2023 Mondraker Thundra is a now-discontinued full-power hardtail eMTB built on Mondraker's STEALTH 6061 Xtralite aluminium frame with the brand's Forward Geometry. It runs a Shimano EP600 drive unit with a 720Wh internal Simplo battery, which a 360Wh external range extender can lift to a substantial 1,080Wh. A 120mm RockShox Recon Silver RL fork, 29in wheels and 2.6in Maxxis Rekon trail tyres mark it out as a genuine off-road hardtail rather than a path-and-towpath machine.
It was sold as a single build at GBP 3,799. The spec is honest entry-to-mid hardtail: SRAM SX Eagle 1x12 drivetrain with an 11-50T cassette, SRAM Level T two-piston brakes on 200/180mm rotors, in-house Onoff alloy cockpit and a rigid 400mm Onoff seatpost (no dropper at this price). Claimed weight is 22.0kg. Five sizes run from XS to XL.
Geometry is moderate by modern trail standards: a 69-degree head angle, 73.5-degree effective seat angle and 455mm chainstays across the range, with reach growing 410mm to 505mm. That makes it an approachable, climbing-friendly all-day trail hardtail rather than an aggressive descender. Note that the urban-spec Thundra X sibling (100mm fork, semi-slick Maxxis Grifter tyres, narrow urban cockpit) is a commuter and sits outside the trail-eMTB remit covered here. The Thundra has since been discontinued from Mondraker's line-up. No verified owner or long-term reliability data is included.
Short 455mm rear and a lighter build — easy to pop, manual and throw around.
Rear-long with a planted front in L (FC:RC 1.66) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Shimano EP6 (DU-EP600) and a steep 73.5° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
Easy to throw around; happiest when you're active on the bike.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
| XS | S | M | L | XL | |
| Reach | 410 mm | 425 mm | 455 mm | 480 mm | 505 mm |
| Stack | 640 mm | 640 mm | 640 mm | 658 mm | 658 mm |
| Seattube | 380 mm | 390 mm | 430 mm | 470 mm | 510 mm |
| Chainstay | 455 mm | 455 mm | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 69° | 69° | 69° | 69° | 69° |
| Seattube Angle (eff) | 73.5° | 73.5° | 73.5° | 73.5° | 73.5° |
| Wheelbase | 1138 mm | 1153 mm | 1183 mm | 1210 mm | 1240 mm |
| Headtube | 110 mm | 110 mm | 110 mm | 130 mm | 130 mm |
| BB Height | 317 mm | 317 mm | 317 mm | 317 mm | 317 mm |
| Front Centre | 683 mm* | 698 mm* | 728 mm* | 755 mm* | 785 mm* |
| FC:RC | 1.50 | 1.53 | 1.60 | 1.66 | 1.73 |
Trims · 1
Base £3,799 | |
| Motor | Shimano EP6 (DU-EP600) · 85 Nm |
| Battery | Simplo internal battery · 720 Wh |
| Travel F/R | 120/? mm |
| Frame | Aluminium (Thundra 6061 Xtralite Full Butted Alloy) |
| Fork | RockShox Recon Silver RL 29, 120mm, Motion control, Solo Air, tapered steerer tube, Boost 15x110mm axle, 32mm steel stanchions, 42mm offset. Settings: compression adjustment at low-speed to lock, rebound, air preload |
| Headset | Onoff Saturn tapered for 1-1/8" to 1-1/2" head tube, ACB sealed bearings, top 41x30.2x7x45degx45deg, bottom 51.9x40x8x45degx45deg |
| Stem | Onoff Sulfur FG 30mm 0deg, 6061 forged alloy, 31.8mm barbore |
| Handlebar | Onoff Sulfur 1.0 double butted 6061 alloy, rise: 20mm, width: 800mm, 9deg backsweep, 5deg upsweep, 31.8mm barbore |
| Grips | Onoff Twin, 1 lock-on, 135mm |
| Saddle | MDK ebike black |
| Seatpost | Onoff Sulfur 0-R, 6061 T6 Alloy, 3D forged, diameter 31.6mm, length 400mm (rigid, not dropper) |
| Brakes | Front: SRAM Level T, 2 piece caliper, Centerline 200mm IS 6 bolts one-piece rotor, steel-backed organic pad; Rear: SRAM Level T, 2 piece caliper, Centerline 180mm IS 6 bolts one-piece rotor, steel-backed organic pad |
| Rear derailleur | SRAM SX Eagle, Type 3 roller bearing clutch, cage lock, long cage, 1x12s, X-actuation 1:1 |
| Crank | FSA Shimano EP8, 165mm, Rings: SRAM X-Sync 2 Eagle 34T, steel, narrow-wide, 104 BCD |
| Shifters | SRAM Trigger SX Eagle, 12s, X-Actuation 1:1, single click |
| Cassette | SRAM PG-1210, 11-50T, 12s |
| Chain | SRAM SX Eagle, 12s, Powerlock |
| Drivetrain | SRAM SX Eagle, Type 3 roller bearing clutch, cage lock, long cage, 1x12s, X-actuation 1:1; FSA Shimano EP8, 165mm, Rings: SRAM X-Sync 2 Eagle 34T, steel, narrow-wide, 104 BCD; SRAM Trigger SX Eagle, 12s, X-Actuation 1:1, single click; SRAM PG-1210, 11-50T, 12s; SRAM SX Eagle, 12s, Powerlock |
| Wheels | MDK-HP1 29, 30mm internal width, tubeless ready, 32 spokes (Formula DC711 front / Formula EHL148 Boost rear hubs) |
| Tyres | Front: Maxxis Rekon 29x2.6, tubeless ready, dual compound, EXO protection, 60TPI, folding bead; Rear: Maxxis Rekon 29x2.6, tubeless ready, dual compound, EXO protection, 60TPI, folding bead |
| Weight | 22 kg |
| Price | £3,799 |
Rides similarly
Spot a mistake?
