Bike Finder · Mondraker
Mondraker Neat
Mondraker
Neat 2026
CurrenttrailLegacy · 2.6/10iFreshness 2.6/10
Full Stealth Air Carbon lightweight eMTB, TQ HPR-50 motor, 360Wh integrated battery
Travel F/R
160/150mm
Wheels
29F/29R
Frame
Full carbon
Weight
17.9 kg
Price
From £6,499
View the Mondraker Neat on Mondraker’s site
Mondraker Neat 2026
From £6,499
EMTB Forums verdict
The Mondraker Neat 2026 is the Spanish brand's lightweight trail eMTB platform, built around the TQ HPR50 motor (50 Nm torque, 250 W rated, 300 W manufacturer-claimed peak, 1.85 kg motor weight) on a carbon Zero suspension chassis. Travel is 140 mm front and 130 mm rear on full 29 inch wheels. Three trims from £6,499 to £10,499. Head angle 64.5 degrees flat, chainstays 450 mm, reach 450-515 mm. The community read in one line: a genuinely refined lightweight eMTB that rides like a normal bike with assistance rather than a heavy full-power eMTB, and reportedly the best-handling SL/lightweight platform in the segment per multiple owner comparisons.
Drive system and range. The TQ HPR50 is the gold-standard ultra-quiet, ultra-natural-feeling lightweight eMTB motor — the same drive used on the Trek Fuel EXe. 50 Nm torque is modest, 1.85 kg makes it the lightest production drive unit on the market, and the integrated coaxial Harmonic Pin Ring layout means it is whisper-quiet under load. The battery integrates into the downtube and is not user-removable on most TQ-equipped bikes. @az2au ranked the Neat RR SL above the Levo SL 2022, Pivot Shuttle LT, Transition Relay and Repeater PT in a multi-bike SL comparison: "Mondraker Neat RR SL (2024) is best — TQ motor is virtually silent." Real-world range will sit in the 30 to 50 km territory on Trail/Eco mode depending on terrain.
Geometry and handling. Modern trail geometry. 64.5 degree head angle is bang on the trail/all-mountain norm. Reach steps cleanly: 450 mm (S), 470 mm (M), 495 mm (L), 515 mm (XL). Chainstays held at 450 mm flat across all four sizes — the one notable compromise on what is otherwise a modern platform. Wheelbase scales 1235 to 1295 mm. Mondraker's Zero suspension layout (their licensed/branded variation of the Horst Link/4-bar concept) is well-developed and delivers consistent small-bump compliance.
Build and value. Three trims, well-spaced. R at £6,499 is the entry point and lands you the lightweight TQ HPR50 motor in a carbon chassis — significant value at this price. RR at £8,499 steps up suspension and drivetrain. RR SL at £10,499 is the no-compromise top trim. @Youfirst documented buying a Neat SL for under $5,000 in December 2025 — well below the original $10,000+ launch price — so closeout opportunities on prior-year stock are real.
Community-verified strengths.
  • @az2au ranks the Neat RR SL above multiple SL platforms (Levo SL 2022, Pivot Shuttle LT, Transition Relay, Repeater PT) — the TQ motor being "virtually silent" is the standout.
  • Bike-rides-like-a-bike characteristic. The 1.85 kg motor weight and 50 Nm of measured torque means the Neat feels like a normal trail bike with discreet assistance, not a heavy eMTB.
  • @Youfirst sizing data: at 5'6" coming off a medium Scott Hightower (acoustic), went with small Neat — reach and top tube nearly identical to the acoustic bike. Sizing maps cleanly to non-electric trail bikes.
Caveats and known gripes.
  • 50 Nm torque is properly modest. Riders coming off full-power bikes will find climbing on steeper trails much more legs-dependent.
  • Integrated TQ battery is typically not user-removable — charging happens on the bike via a discreet port.
  • @az2au notes motor connectivity to Garmin head units works but the data fidelity may be limited. Not a deal-breaker but worth knowing for data-focused riders.
  • Fixed 450 mm chainstays across all sizes is the one geometry compromise.
  • Three-trim ladder all carbon — no aluminium budget option at this canonical entry.
Verdict. The Mondraker Neat 2026 is one of the most polished lightweight/SL eMTBs on the market and the ride quality genuinely puts it ahead of the much-praised Trek Fuel EXe and Specialized Levo SL platforms per owner comparisons. It suits intermediate-to-advanced trail riders who want bike-rides-like-a-bike feel with discreet assistance, who value the TQ motor's silence and natural delivery, and who don't mind the 50 Nm torque ceiling. Look elsewhere if you want full-power assistance, removable batteries, or maximum range. Production status: current, three trims, four sizes.
💬 Forum discussion
Mondraker Zendit Avinox
351 replies · 31.1k views · last reply today
Join the discussion →
“No. Mondraker’s Wildest eBike Yet? lVxHD8XPcbc”
— Rob Rides EMTB · ♥ 9 · most-liked post
Bike geometry diagram
SMLXL
Toptube595 mm615 mm640 mm660 mm
Reach450 mm470 mm495 mm515 mm
Stack626 mm626 mm642 mm650 mm
Seattube380 mm420 mm450 mm490 mm
Chainstay450 mm450 mm450 mm450 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)76.5°76.5°76.5°76.5°
BB Drop25 mm25 mm25 mm25 mm
Wheelbase1235 mm1255 mm1275 mm1295 mm
Headtube110 mm110 mm130 mm140 mm
BB Height348 mm348 mm348 mm348 mm
Front Centre785 mm805 mm825 mm845 mm
Trims · 3
R
£6,499
RR
£8,499
RR SL
£10,499
MotorTQ HPR50 · 50 Nm · all trims
Travel F/R160/150 mm · all trims
FrameCarbon · all trims
Weight18.9 kg18.4 kg17.9 kg
Price£6,499£8,499£10,499
Rides similarly
Spot a mistake?
