Bike Finder · Mondraker
Mondraker Crusher
Mondraker
Crusher 2025
CurrentFull-power enduro eMTBAgeing · 3.1/10iFreshness 3.1/10
Travel F/R
160/150mm
Wheels
29F / 29R
Frame
Carbon front, aluminium rear
Weight
23.4 kg
Price
From £6,199
View the Mondraker Crusher on Mondraker’s site
Mondraker Crusher 2025
From £6,199
Bike geometry diagram
SMLXL
Reach450 mm470 mm490 mm510 mm
Stack622 mm622 mm640 mm640 mm
Seattube380 mm420 mm450 mm490 mm
Chainstay455 mm455 mm455 mm455 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)77°77°77°77°
BB Drop25 mm25 mm25 mm25 mm
Wheelbase1227 mm1247 mm1267 mm1387 mm
Front Centre772 mm*792 mm*812 mm*932 mm*
Trims · 3
Crusher
£6,199
Crusher R
£7,499
Crusher RR
£8,799
MotorShimano EP801 · 85 Nm · all trims
BatterySimplo 720Wh G3 · 720 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbon front triangle / alloy rear triangle · all trims
ForkFox 38 29 Float FIT GRIP EVOL Performance, 160mm, e-bike tuned, 44mm offsetOhlins RXF 38 M.2 29, 160mm, TTX18 Twin Tube cartridge, 44mm offsetOhlins RXF 38 M.2 29, 160mm, TTX18 Twin Tube cartridge, 44mm offset
ShockFox Float-X LV Performance, 205x65mmOhlins TTX Air 205x65mm, climb modeOhlins TTX Air, climb mode
HeadsetACROS AZF-601 R1, Block Lock 120 rotation limiter, ZS44/28.6 top, ZS56/40 bottomACROS AZF-601 R1, Block Lock 120 rotation limiter, ZS44/28.6 top, ZS56/40 bottomACROS AZF-601 R1, Block Lock 120 rotation limiter
StemONOFF Sulfur FG, 6061 forged alloy, 30mmONOFF Krypton FG, CNC alloy, 30mmONOFF Krypton FG, CNC alloy, 30mm
HandlebarONOFF Sulfur 1.0, double-butted 6061 alloy, 800mm, 20mm riseONOFF Krypton 1.0, 800mm, 25mm riseONOFF Krypton Carbon 1.0, 800mm, 25mm rise
GripsONOFF Desert, 135mm lock-on · all trims
Saddlefizik Terra Aidon X5, 145mm · all trims
SeatpostONOFF Pija dropper · all trims
BrakesSRAM DB8, 4-piston, 200mm Centerline rotorsSRAM Code Bronze Stealth, 4-piston, 200mm Centerline rotorsShimano Deore XT M8120, 4-piston, ICE TECH rotors (203mm)
Rear derailleurSRAM GX Eagle, 12-speedSRAM X01 Eagle, 12-speedShimano Deore XT Di2 M8150, 12-speed wired electronic (with FREE SHIFT / XT Di2 chainset)
CrankShimano STEPS EM600 alloy, 165mmShimano STEPS EM600 alloy, 165mmShimano STEPS Deore XT M8150 alloy, 165mm
ShiftersSRAM NX Eagle, 12-speedSRAM GX Eagle, 12-speedShimano Deore XT Di2 M8150, 12-speed, wired electronic
CassetteSRAM SX Eagle PG-1210, 12-speed, 11-50TSRAM GX Eagle XG-1275, 12-speed, 10-52TShimano Deore XT M8100, 12-speed, 10-51T
ChainSRAM SX Eagle, 12-speedSRAM NX Eagle, 12-speedShimano Deore XT M8100, 12-speed
DrivetrainSRAM GX Eagle, 12-speed; Shimano STEPS EM600 alloy, 165mm; SRAM NX Eagle, 12-speed; SRAM SX Eagle PG-1210, 12-speed, 11-50T; SRAM SX Eagle, 12-speedSRAM X01 Eagle, 12-speed; Shimano STEPS EM600 alloy, 165mm; SRAM GX Eagle, 12-speed; SRAM GX Eagle XG-1275, 12-speed, 10-52T; SRAM NX Eagle, 12-speedShimano Deore XT Di2 M8150, 12-speed wired electronic (with FREE SHIFT / XT Di2 chainset); Shimano STEPS Deore XT M8150 alloy, 165mm; Shimano Deore XT Di2 M8150, 12-speed, wired electronic; Shimano Deore XT M8100, 12-speed, 10-51T; Shimano Deore XT M8100, 12-speed
WheelsMavic E-Deemax alloy, 30mm inner width, welded, PFP, 28h, tubeless readyMavic E-Deemax alloy, 30mm inner width, welded, PFP, 28h, tubeless readyMavic E-Deemax S alloy, 30mm inner width, Mavic hubs with ID360 Ratchet freehub
TyresMaxxis Minion DHF / DHR II 29x2.6, 3C MaxxTerra, EXO+ · all trims
Weight24.6 kg24.1 kg23.4 kg
Price£6,199£7,499£8,799
Rides similarly
Spot a mistake?
