Bike Finder · Megamo
Megamo Reason Air
Megamo
Reason Air 2027
CurrentTrail🔥 Hot · 10/10iFreshness 10/10
140mm Avinox M2S trail/all-mountain eMTB
Motor
Avinox M2S · 150Nm · 1300W
Battery
Avinox FP800 · 800Wh
Travel F/R
140/140mm
Wheels
29F/29R
Frame
Carbon front, aluminium rear
Weight
20.05 kg
Price
From £4,249
View the Megamo Reason Air on Megamo’s site
Megamo Reason Air 2027
From £4,249
EMTB Forums verdict
The Megamo Reason Air 2027 is the Spanish brand's full-carbon trail eMTB flagship: 140 mm of travel front and rear, the DJI Avinox M2S motor at 150 Nm of torque and 1500 W peak, an integrated 800 Wh IP56-rated battery, and a class-leading claimed 20.05 kg total weight. With nine size options across S–XL (some at two different head-angle settings), this is one of the most fit-flexible carbon trail eMTBs on sale. At €11,999 for the CRB 05 top trim it sits in premium territory and squares up against Pivot Shuttle SL, Specialized Levo SL Gen 2 and lightweight Avinox builds.
Drive system and range. Avinox M2S delivers 150 Nm of torque (130 Nm sustained, 150 Nm in Boost), 1500 W peak and a 2.63 kg unit weight — the most powerful current motor in this database. On a 20 kg trail platform with 140 mm travel that combination is properly transformative: @Rob Rides EMTB on the 160 mm Reason sibling described it as "a rocket" on the first ride. The 800 Wh battery is integrated (not removable) and IP56-rated for ingress protection. Real-world range on M2S with 800 Wh consistently lands at 1,500–2,200 m of climbing per charge depending on assistance and rider weight. The Reason's CRB 05 is the carbon-platform flagship; @empty notes that 2027-model Reason AL05 builds use the same M2S motor.
Geometry and handling. The Reason Air gives buyers an unusual luxury: two head-angle settings via flip-chip (63.5° or 64.5°) across multiple sizes. Reach is generous and well-progressed: 442 mm (S) through 481 mm (M), 511 mm (L) and 514 mm (XL), with sub-variants between. Chainstays grow proportionally from 449 mm (S) to 458 mm (L/XL) — a thoughtful nod to size-balanced rear-centre that many rivals miss. Wheelbase grows 1,223–1,334 mm. The 4-bar ASP suspension is Megamo's proven design. @Lawsoc picks out the Reason Air alongside Orbea Rise and Unno Mith as bikes with low standover, suitable for shorter riders.
Build and value. Only the €11,999 CRB 05 trim is gold-listed at the carbon flagship level: FOX 36 Float SL Performance fork (140 mm), FOX Float Performance shock, Shimano XT 4-piston brakes with 203 mm rotors, SRAM Transmission 12-speed (Eagle 90 or AXS). Rob notes the broader Reason line spans £4,999 alloy through £11,499 carbon top-end; the Reason Air carbon is positioned as the trail-focused version of the proven Reason platform. @garethld ordered a CRB03 (mechanical XT) at a meaningfully lower price.
Community-verified strengths. The Reason platform has impressed across the forum. @Toomanybikesnotenoughlegs calls the 160 mm Reason sibling capable enough "from single track and forest roads to Lake District and bike parks without feeling under-suspended" — the Air's 140 mm travel will trade some of that capability for sub-20 kg weight. @deertrackdoctor notes UK dealer presence is meaningfully growing — three Megamo dealers within 90 minutes drive at the time of his post, including Pedals in Dunfermline. The Avinox motor's seamless OTA-update ecosystem is well-regarded.
Caveats and known gripes. @Rob Rides EMTB identifies multiple cons that broadly apply across the Reason range: stock EXO casing tyres are too light for serious use, 35 mm stem is twitchy (50 mm is recommended), headset cable routing adds maintenance overhead, non-removable battery limits big-day workflows, the flip-chip geometry change is mild rather than transformative, 20 mm bar rise is short for larger sizes, and size Large runs more like XL. @Rando_12345 reports BB height is too low for technical climbing on rocky singletrack on the broader Reason platform. @simonali19 notes the bike weighs significantly more than comparable analogue full-suspension bikes (around 10 kg reference) and is harder to load into a vehicle. @Watty defends headset routing as a minor service issue. The 140 mm travel limits aggressive bike-park use.
Verdict. The Megamo Reason Air is one of the most desirable lightweight carbon trail eMTBs of 2027: sub-20 kg, Avinox M2S power, flip-chip geometry adjustability, and nine size options including dual head-angle settings. It will suit riders who want the latest 150 Nm Avinox punch in a manageable 140 mm trail package and value Megamo's growing UK dealer network. Buyers wanting longer travel, removable batteries, lighter stock tyres, or established big-brand dealer support should look at Trek Fuel EXe, Specialized Levo SL Gen 2 or the Megamo Reason 160 mm sibling. Production status: current.
💬 Forum discussion
Megamo Reason - Avinox 160mm Travel eMTB
118 replies · 23.9k views · last reply 2 months ago
Join the discussion →
“Just got this one in. 160mm front and rear travel, 800wh battery, quoted weight is 20.3 KG. 63.5 head angle, 500mm reach in L, 457mm chainstay, 4 bar horst link suspension, super slim. Trail / Light enduro use (takes a 170mm in 38 if…”
— Rob Rides EMTB · ♥ 23 · most-liked post
Frame
Full-carbon AIR frame, 140mm front and rear travel, alloy variants also offered; 800Wh Avinox battery with IP56 ingress protection.
Bike geometry diagram
SMLXL
Toptube581 mm614 mm648 mm662 mm
Reach453 mm481 mm511 mm523 mm
Stack608 mm626 mm644 mm655 mm
Seattube400 mm420 mm455 mm460 mm
Chainstay449 mm453 mm457 mm457 mm
Headtube Angle64.5°64.5°64.5°64.5°
Seattube Angle (eff)78°78°78°78°
BB Drop33 mm33 mm33 mm33 mm
Wheelbase1223 mm1264 mm1307 mm1324 mm
Headtube100 mm120 mm140 mm152 mm
BB Height345 mm345 mm345 mm345 mm
Front Centre774 mm811 mm850 mm867 mm
Trims · 6
AL 07
£4,249
AL 05
£5,099
CRB 07
£5,099
CRB 05
£5,439
CRB 03 AXS
£7,224
CRB 00
£10,199
MotorAvinox M2S · 150 Nm · all trims
BatteryAvinox FP800 · 800 Wh · all trims
Travel F/R140/140 mm · all trims
Framecarbon_or_alloy · all trims
ForkFOX 34 Float AWL, 140 mm Travel, Rail 2.0, Sweep-Adjust, Kabolt Axle 110, 1.5 Tapered, 44mm offsetFox 36 Float SL Performance, 140 mm Travel, GripFOX 34 Float AWL, 140 mm Travel, Rail 2.0, Sweep-Adjust, Kabolt Axle 110, 1.5 Tapered, 44mm offsetFox 36 Float SL Performance, 140 mm Travel, GripFox 36 Float SL Factory, 140mm Travel, Grip XFox 36 Float SL Factory, 140mm Travel, Grip X
ShockFox Float Rhythm, Evol LV, 210x47,5mm, 2 PositionFox Float Performance, 210x47,5 mm, Evol LV, Low Speed Rebound, 2 PositionFox Float Rhythm, Evol LV, 210x47,5mm, 2 PositionFox Float Performance, 210x47,5 mm, Evol LV, Low Speed Rebound, 2 PositionFox Float Factory, 210x47,5 mm, Evol LV, Low Speed Rebound, 2 PositionFox Float Factory, 210x47,5 mm, Evol LV, Low Speed Rebound, 2 Position
HeadsetAcros AZA-288R2 ZS56 blocklock 135° · all trims
StemSatori Ursa, 35 x 35 mm · all trims
HandlebarMegamo Alloy Butted 35 x 800 mm, 12 mm Rise, 6º Back SweepMegamo Alloy Butted 35 x 800 mm, 12 mm Rise, 6º Back SweepMegamo Alloy Butted 35 x 800 mm, 12 mm Rise, 6º Back SweepMegamo Alloy Butted 35 x 800 mm, 12 mm Rise, 6º Back SweepCarbon Race Face ERA 35x800, Rise 20mmCarbon Race Face ERA 35x800, Rise 20mm
SaddleSelle Royal SRX OpenSelle Royal SRX OpenFizik Ridon X5Fizik Ridon X5Fizik Ridon X5Fizik Ridon X1, 145 mm
SeatpostMegamo Ø31.6 mmMegamo Ø31.6 mmMegamo Ø31.6 mmMegamo Ø31.6 mmFox Transfer Factory Ø31.6 mm, S size 150 mm Drop / M size 180 mm Drop / L and XL size 210 mm DropFox Transfer Factory Ø31.6 mm, S size 150 mm Drop / M size 180 mm Drop / L and XL size 210 mm Drop
BrakesShimano XT M8220, Hydraulic Disc 4-Piston, RT-CL800 203 mmShimano XT M8220, Hydraulic Disc 4-Piston, SM-RT86 203 mmShimano XT M8220, Hydraulic Disc 4-Piston, RT-CL800 203 mmShimano XT M8220, Hydraulic Disc 4-Piston, SM-RT86 203 mmShimano XT M8220, Hydraulic Disc 4-Piston, RT-CL800 203 mmShimano XTR M9220 Hydraulic Disc 4-Piston, RT-CL900 203/203mm
Rear derailleurShimano XT M8100, Shadow Plus 12-SpeedSram 90 EAGLE T-TYPE, 12-SpeedShimano XT M8100, Shadow Plus 12-SpeedSram 90 EAGLE T-TYPE, 12-SpeedSram S1000 EAGLE AXS T-TYPE, 12-SpeedSram XX EAGLE AXS T-TYPE, 12-Speed
CrankAvinox Chainring 36T 12-Speed, Crankset 160mmSram EAGLE T-TYPE Avinox Chainring 36T 12-Speed, Crankset 160mmAvinox Chainring 36T 12-Speed, Crankset 160mmSram EAGLE T-TYPE Avinox Chainring 36T 12-Speed, Crankset 160mmSram EAGLE T-TYPE Avinox Chainring 36T 12-Speed, Crankset 160mmSram XX EAGLE T-TYPE Avinox Chainring 36T 12-Speed, Sram XX EAGLE Crankset 165mm
ShiftersShimano XT 8100, 12-SpeedSram 90 EAGLE T-TYPEShimano XT 8100, 12-SpeedSram 90 EAGLE T-TYPESram AXS PODSram AXS POD Ultimate
CassetteShimano XT M8100, 10-51TSram XS 1270 T-TYPE, 10-52TShimano XT M8100, 10-51TSram XS 1270 T-TYPE, 10-52TSram XS 1270 T-TYPE, 10-52TSram XX Eagle T-TYPE 10-52T
DrivetrainShimano XT M8100, Shadow Plus 12-Speed; Avinox Chainring 36T 12-Speed, Crankset 160mm; Shimano XT 8100, 12-Speed; Shimano XT M8100, 10-51TSram 90 EAGLE T-TYPE, 12-Speed; Sram EAGLE T-TYPE Avinox Chainring 36T 12-Speed, Crankset 160mm; Sram 90 EAGLE T-TYPE; Sram XS 1270 T-TYPE, 10-52TShimano XT 12-speedSRAM Eagle 90 T-Type or AXS, 12-speed (36T / 10-52T)Sram S1000 EAGLE AXS T-TYPE, 12-Speed; Sram EAGLE T-TYPE Avinox Chainring 36T 12-Speed, Crankset 160mm; Sram AXS POD; Sram XS 1270 T-TYPE, 10-52TSram XX EAGLE AXS T-TYPE, 12-Speed; Sram XX EAGLE T-TYPE Avinox Chainring 36T 12-Speed, Sram XX EAGLE Crankset 165mm; Sram AXS POD Ultimate; Sram XX Eagle T-TYPE 10-52T
WheelsMegamo 29 SL 30 ASY, Aluminium Rim, 15x110/12x148 mmMegamo 29 SL 30 ASY, Aluminium Rim, 15x110/12x148 mmMegamo 29 SL 30 ASY, Aluminium Rim, 15x110/12x148 mmMegamo 29 SL 30 ASY, Aluminium Rim, 15x110/12x148 mmDT Swiss H 1900 SPLINE, 30mm Tubeless ready Aluminium rim, 370 Ratchet LN 18DT Swiss HXC 1200 Carbon e-bike SP 29 CL 30
TyresMaxxis New Dissector 29.4 EXO+ 3C MaxxGrip / Maxxis New Dissector 29.4 DD 3C MaxxTerra · all trims
Weight20.05 kg
Price£4,249£5,099£5,099£5,439£7,224£10,199
Rides similarly
Spot a mistake?
