Bike Finder · Megamo
Megamo Reason Air
Megamo
Reason Air 2026
CurrentTrail eMTBCurrent · 7.6/10iFreshness 7.6/10
Motor
Avinox M1 · 120Nm · 1000W
Battery
Avinox FP800 · 800Wh
Travel F/R
140/140mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Price
From £4,999
View the Megamo Reason Air on Megamo’s site
Megamo Reason Air 2026
From £4,999
EMTB Forums verdict
The Reason Air is the shorter-travel, trail-focused sibling in Megamo's Avinox-powered Reason line. With 140mm of travel front and rear, a full 800 Wh DJI Avinox battery and the M1 motor rated at 120Nm and 1000W in Boost, it pairs serious power and range with a comparatively light chassis, available in either alloy or full carbon.
The trim spread is wide. The alloy AL 15 at GBP 4,999 leans on a Fox 34 AWL fork, Fox Float Rhythm shock, Shimano XT four-piston brakes on 203mm rotors and a mixed XT shifting/Deore cassette package on alloy wheels. At the top, the carbon CRB 00 at GBP 11,999 steps up to a Fox 36 Factory fork, Float Factory Kashima shock, SRAM XX Eagle Transmission AXS, XTR brakes and DT Swiss carbon wheels. That is a large jump, so most riders chasing value will find the alloy builds the sensible entry point into the platform.
Geometry is adjustable through a flip chip that shifts the head angle between roughly 64.3 and 64.5 degrees and the seat angle between 77.8 and 78 degrees. Reach runs from 451mm on the small to 509mm on the large in the low setting, with a 1265mm wheelbase and 454mm chainstays on the medium. The numbers read as a balanced modern trail bike rather than an outright enduro rig, which suits its 140mm intent.
💬 Forum discussion
Megamo Reason - Avinox 160mm Travel eMTB
118 replies · 23.8k views · last reply 2 months ago
Join the discussion →
“Just got this one in. 160mm front and rear travel, 800wh battery, quoted weight is 20.3 KG. 63.5 head angle, 500mm reach in L, 457mm chainstay, 4 bar horst link suspension, super slim. Trail / Light enduro use (takes a 170mm in 38 if…”
— Rob Rides EMTB · ♥ 23 · most-liked post
Bike geometry diagram
SML
Reach453 mm481 mm511 mm
Stack608 mm626 mm644 mm
Seattube420 mm
Chainstay454 mm
Headtube Angle64.5°64.5°64.5°
Seattube Angle (eff)78°78°78°
Wheelbase1265 mm
Headtube100 mm
BB Height336 mm
Front Centre
Trims · 3
AL 15
£4,999
CRB 00
£11,999
CRB 10
MotorAvinox M1 · 120 Nm · all trims
BatteryAvinox FP800 · 800 Wh · all trims
Travel F/R140/140 mm · all trims
FrameAluminiumCarbonCarbon
ForkFOX 34 Float AWL, 140 mm travel, Rail 2.0, Sweep-Adjust, Kabolt Axle 110, 1.5 tapered, 44mm offset, air springFox 36 Float SL Factory, 140mm travel, Grip X, air springFOX 34 Float AWL, 140mm, Rail 2.0, Kabolt axle
ShockFox Float Rhythm, Evol LV, 210x47.5mm, 2 Position, 140mm travelFOX Float Factory Kashima, 210x47.5 mm, Evol LV, Low Speed Rebound, 2 Position, 140mm travel
HeadsetAcros AZX-589 ZS56 blocklock 150 degreeAcros AZX-589 ZS56 blocklock 150 degree
StemMegamo 3D Forged Alloy, +/-7 degree rise, S 60mm / M 60mm / L 70mm
HandlebarMegamo Alloy Butted 35 x 800 mm, 12 mm rise, 6 degree back sweepFull integrated carbon handlebar, S/M 60 x 760 mm, L/XL 80 x 760 mm
SaddleSelle Royal SRX OpenFizik Ridon X1
SeatpostMegamo telescopic dropper 31.6mm, remote adjustment, S 125mm / M 150mm / L 170mm dropFox Transfer Kashima SL 31.6mm telescopic dropper, remote adjustment, S 100mm / M,L 125mm / L 150mm dropMegamo telescopic dropper (size-specific drop)
BrakesShimano XT BR-M8220, hydraulic disc 4-pistonShimano XTR BR-M9920, hydraulic disc 4-pistonShimano XT BR-M8220 hydraulic disc 4-piston
Rear derailleurShimano XT M8100, Shadow Plus 12-SpeedSRAM XX Eagle AXS T-Type 12-speedShimano XT M8100, Shadow Plus 12-Speed
CrankForged AL6061/T6 165mm, bead blasted anodized black, 34T chainring BCD 104mmForged AL6061/T6 165mm, bead blasted anodized black, 34T chainring BCD 104mm
ShiftersShimano Deore 6100 Rapidfire Plus 12-SpeedSRAM XX AXS controller
CassetteShimano Deore 6100 10-51TSRAM XX Eagle T-Type 10-52T
DrivetrainShimano XT M8100, Shadow Plus 12-Speed; Forged AL6061/T6 165mm, bead blasted anodized black, 34T chainring BCD 104mm; Shimano Deore 6100 Rapidfire Plus 12-Speed; Shimano Deore 6100 10-51TSRAM XX Eagle AXS T-Type 12-speed; Forged AL6061/T6 165mm, bead blasted anodized black, 34T chainring BCD 104mm; SRAM XX AXS controller; SRAM XX Eagle T-Type 10-52TShimano XT M8100, Shadow Plus 12-Speed
WheelsMegamo 29 SL 30 ASY, aluminium rim, 15x110 / 12x148 mmDT Swiss HXC 1200 Carbon e-bike SP 29 CL 30Megamo 29 SL 30 ASY
TyresFront: Pirelli Scorpion 29x2.4 MTB scM Trail ProWALL SmartGRIP / Rear: Pirelli Scorpion 29x2.4 MTB scR Trail ProWALL SmartGRIPFront: Pirelli Scorpion 29x2.4 MTB scM Trail ProWALL SmartGRIP / Rear: Pirelli Scorpion 29x2.4 MTB scR Trail ProWALL SmartGRIPPirelli Scorpion Trail 29x2.4
Price£4,999£11,999
Rides similarly
Spot a mistake?
