A solid all-round descender (65° head angle, 160mm) — capable in the rough and steep without being an all-out bruiser.
Crave CRB 2024
The Megamo Crave CRB is the carbon-framed sibling of the alloy Crave AL, built around Megamo's Full Carbon FSC Technology frame with a carbon swingarm. It is a full-power all-mountain eMTB on 29in wheels, with 160mm of rear travel and a Shimano EP801 motor (85 Nm) fed by a 762 Wh integrated battery. Geometry is identical across the range, with a 65 degree head angle, 76 degree seat angle and 455mm chainstays at every size.
The 2024 line spans five trims sharing that frame, motor and battery but differing on kit. The CRB 05 (5,649 EUR) runs a 150mm Fox 36 Rhythm with a mixed Shimano XT/Deore drivetrain and MT520 brakes; the CRB 03 (6,899 EUR) and CRB 02 (7,149 EUR) step up to a 160mm Fox 38 Factory fork with Fox Float X shock and XT four-piston brakes, the 02 adding a Shimano CUES AUTO Di2 electronic shift and DT Swiss wheels. The flagship ALL-MTN (9,449 EUR) and ENDURO (9,849 EUR) pair the Fox 38 Factory with SRAM XX Eagle AXS T-Type wireless shifting and DT Swiss 1501 wheels, the ENDURO upgrading to a Fox Float X2 shock. All five roll on 29 x 2.6 Maxxis Minion DHF/DHR II tyres.
This is a discontinued 2024 model and is no longer listed on megamo.com. Note the CRB (carbon) badge distinguishes it from the alloy Crave AL, which is a separate frame. Pricing is given in euros from the official Spanish manufacturer pages, as no UK retailer listing was found.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Balanced front-to-rear in L (FC:RC 1.82) — weight sits evenly between the wheels.
Climbs well — a 76° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 140 bikes in the database)
| S | M | L | |
| Reach | 435 mm | 459 mm | 489 mm |
| Stack | 615 mm | 625 mm | 647 mm |
| Seattube | 400 mm | 420 mm | 480 mm |
| Chainstay | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 65° | 65° | 65° |
| Seattube Angle (eff) | 76° | 76° | 76° |
| Wheelbase | 1215 mm | 1244 mm | 1284 mm |
| Headtube | 100 mm | 110 mm | 135 mm |
| Front Centre | 760 mm* | 789 mm* | 829 mm* |
| FC:RC | 1.67 | 1.73 | 1.82 |
Trims · 5
CRB 02 €7,149 | CRB 03 €6,899 | CRB 05 €5,649 | CRB ALL-MTN €9,449 | CRB ENDURO €9,849 | |
| Motor | Shimano EP801 · 85 Nm · all trims | ||||
| Battery | Integrated 762Wh · 762 Wh · all trims | ||||
| Travel F/R | 160/160 mm · all trims | ||||
| Frame | Carbon · all trims | ||||
| Fork | Fox 38 Factory e-bike+, Kashima 29, 160mm, grip 2, 15QRx110, 44mm rake | Fox 38 Factory e-bike+, Kashima 29, 160mm, grip 2, 15QRx110, 44mm rake | Fox 36 Rhythm E-Bike, FLOAT 29, 150mm, Grip, Sweep-Adj, 15QRx110 Boost, 44mm Rake | Fox 38 Factory e-bike+, Kashima 29, 160mm, grip 2, 15QRx110, 44mm rake | Fox 38 Factory e-bike+, Kashima 29, 160mm, grip 2, 15QRx110, 44mm rake |
| Shock | Fox FLOAT X, Factory Series, Kashima 2pos-adj, Trunnion, Evol LV, 205x65 | Fox FLOAT X, Factory Series, Kashima 2pos-adj, Trunnion, Evol LV, 205x65 | FOX Float DPS, Performance Series, 3pos, Trunnion, Evol LV, 205x65 | Fox FLOAT X, Factory Series, Kashima 2pos-adj, Trunnion, Evol LV, 205x65 | Fox Float X2, Factory Series, Kashima 2pos-adj, Trunnion, Evol LV, 205x65 |
| Headset | Integrated, Full Internal Cable Routing · all trims | ||||
| Stem | 3D Forged Alloy, Ext.: 60-70-90 mm, Rise: +/-7deg | 3D Forged Alloy, Ext.: 60-70-90 mm, Rise: +/-7deg | 3D Forged Alloy, Ext.: 60-70-90 mm, Rise: +/-7deg | Race Face Aeffect | Race Face Aeffect |
| Handlebar | Alloy Butted 31,8x780 mm, Rise: 12 mm, Back Sweep: 6deg | Alloy Butted 31,8x780 mm, Rise: 12 mm, Back Sweep: 6deg | Alloy Butted 31,8x780 mm, Rise: 12 mm, Back Sweep: 6deg | Race Face Turbine R | Race Face Turbine R |
| Saddle | Selle Italia Model X | Selle Italia Model X | Selle Italia Model X | Selle San Marco GrouND Short Open-fit Titanium | Selle San Marco GrouND Short Open-fit Titanium |
| Seatpost | Fox Transfer Kashima 31,6mm telescopic seat post, remote adjustment | Fox Transfer Kashima 31,6mm telescopic seat post, remote adjustment | Megamo 31,6mm telescopic seat post, remote adjustment | Fox Transfer Kashima 31,6mm telescopic seat post, remote adjustment | Fox Transfer Kashima 31,6mm telescopic seat post, remote adjustment |
| Brakes | Shimano XT M8020 Hydraulic disc 4-Piston (203mm) | Shimano XT M8020 Hydraulic disc 4-Piston (203mm) | Shimano MT520 hydraulic disc 4-Piston (203mm) | Shimano XT M8020 Hydraulic disc 4-Piston (203mm) | Shimano XT M8020 Hydraulic disc 4-Piston (203mm) |
| Rear derailleur | Shimano CUES AUTO Di2 11s | Shimano XT 12s | Shimano XT 12s | Sram XX Eagle AXS T-Type 12s | Sram XX Eagle AXS T-Type 12s |
| Crank | Shimano 36t | Shimano 36t | Shimano 36t | Sram E-Bike 36t | Sram E-Bike 36t |
| Shifters | Shimano CUES AUTO Di2 11s | Shimano Deore 12s | Shimano Deore 12s | Sram XX Eagle AXS 12s | Sram XX Eagle AXS 12s |
| Cassette | Shimano CUES AUTO Di2 11s | Shimano Deore 12s 10-51t | Shimano Deore 12s 10-51t | Sram XX Eagle AXS T-Type 10-52 12s | Sram XX Eagle AXS T-Type 10-52 12s |
| Drivetrain | Shimano CUES AUTO Di2 11s; Shimano 36t; Shimano CUES AUTO Di2 11s; Shimano CUES AUTO Di2 11s | Shimano XT 12s; Shimano 36t; Shimano Deore 12s; Shimano Deore 12s 10-51t | Shimano XT 12s; Shimano 36t; Shimano Deore 12s; Shimano Deore 12s 10-51t | Sram XX Eagle AXS T-Type 12s; Sram E-Bike 36t; Sram XX Eagle AXS 12s; Sram XX Eagle AXS T-Type 10-52 12s | Sram XX Eagle AXS T-Type 12s; Sram E-Bike 36t; Sram XX Eagle AXS 12s; Sram XX Eagle AXS T-Type 10-52 12s |
| Wheels | DT Swiss 1700 HX 30 - Mspline | 29 Asymmetric 15x110 12x148 Boost Wide:30mm Tubeless Ready | 29 Asymmetric 15x110 12x148 Boost Wide:30mm Tubeless Ready | DT Swiss 1501 HXC 30 | DT Swiss 1501 HXC 30 - XD |
| Tyres | Front: 29x2,6 Maxxis Minion DHF, Rear: 29x2,6 Maxxis Minion DHR II, Tubeless Ready, EXO Protection / Pirelli Scorpion Enduro S HardWALL · all trims | ||||
| Price | €7,149 | €6,899 | €5,649 | €9,449 | €9,849 |
Rides similarly
Spot a mistake?
