A solid all-round descender (65° head angle, 160mm) — capable in the rough and steep without being an all-out bruiser.
Crave CRB 2022
Carbon all-rounder with matched 160mm travel and EP8 drive
The Megamo Crave CRB is the carbon-framed full-suspension all-mountain/enduro eMTB from Spanish brand Megamo, built on its Full Carbon FSC Technology frame with a carbon swingarm. For 2022 it ran a Shimano EP8 motor (85 Nm) fed by an integrated Shimano 630 Wh battery, with 160 mm of rear travel on 29in wheels and 29 x 2.6 tyre clearance. Geometry is shared across both trims and every size: a 65 degree head angle, 76 degree seat angle and 455 mm chainstays, with reach growing 435 / 459 / 489 mm across S/M/L.
The 2022 carbon line consisted of just two trims on that common frame, motor and battery. The CRB 05 (6,199 euros) paired a 150 mm Fox 34 Rhythm fork with a Fox Float DPS shock, a full Shimano Deore 12-speed drivetrain and Shimano MT520 four-piston brakes. The CRB 03 (7,299 euros) stepped up to a 160 mm Fox 38 Factory Kashima fork and Fox Float X Factory shock, with a mixed Shimano XT/Deore drivetrain, Shimano XT M8020 four-piston brakes and a Fox Transfer Kashima dropper. Both roll on 29 x 2.6 Maxxis Minion DHF/DHR II tyres and use the same integrated cockpit and internal cable routing.
This is a discontinued 2022 model. Note that the 2022 CRB used the earlier Shimano EP8 motor with a 630 Wh battery, where the later 2023-2024 Crave CRB moved to the Shimano EP801 motor and a larger 762 Wh pack. The CRB (carbon) badge distinguishes it from the alloy Crave AL, which is a separate frame and canonical entry. Pricing is given in euros as the manufacturer's launch recommended retail price from Megamo's own 2022 model pages; no UK retailer RRP was found, so the pound price is left blank rather than converted. No owner ride or reliability data was gathered for this dossier.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Balanced front-to-rear in L (FC:RC 1.82) — weight sits evenly between the wheels.
Climbs well — a 76° seat keeps the front planted. 500W of peak power and 85Nm of torque — a strong full-power motor.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 160 bikes in the database)
| S | M | L | |
| Reach | 435 mm | 459 mm | 489 mm |
| Stack | 615 mm | 625 mm | 647 mm |
| Seattube | 400 mm | 420 mm | 480 mm |
| Chainstay | 455 mm | 455 mm | 455 mm |
| Headtube Angle | 65° | 65° | 65° |
| Seattube Angle (eff) | 76° | 76° | 76° |
| Wheelbase | 1215 mm | 1244 mm | 1284 mm |
| Headtube | 100 mm | 110 mm | 135 mm |
| Front Centre | 760 mm* | 789 mm* | 829 mm* |
| FC:RC | 1.67 | 1.73 | 1.82 |
Trims · 2
03 €7,299 | 05 €6,199 | |
| Motor | Shimano EP8 (DU-EP800) · 85 Nm · all trims | |
| Battery | Integrated Shimano 630Wh · 630 Wh · all trims | |
| Travel F/R | 160/160 mm · all trims | |
| Frame | Carbon · all trims | |
| Fork | Fox 38 Factory e-bike+, Kashima 29, 160mm, grip 2, 15QRx110, 44mm rake | FOX 34 Rhythm e-Bike, Float 29, 150mm, grip, sweep-adj, 15QRx110 Boost, 44mm rake |
| Shock | Fox FLOAT X, Factory Series, Kashima 2pos-adj, Trunnion, Evol LV, 205x65 | FOX Float DPS, Performance Series, 3pos, Trunnion, Evol LV, 205x65 |
| Headset | Integrated Full Internal Cable Routing · all trims | |
| Stem | 3D Forged Alloy, Ext.: 60-70-90 mm, Rise: +/-7deg · all trims | |
| Handlebar | Alloy Butted 31,8x780 mm, Rise: 12 mm, Back Sweep: 6deg · all trims | |
| Saddle | Selle Italia Model X · all trims | |
| Seatpost | Fox Transfer Kashima 31,6mm telescopic seat post, remote adjustment | Megamo 31,6mm telescopic seat post, remote adjustment |
| Brakes | Shimano XT M8020 Hydraulic disc 4-Piston, 203mm | Shimano MT520 hydraulic disc 4-Piston, 203mm |
| Rear derailleur | Shimano XT 12s | Shimano Deore 12s |
| Crank | Shimano 36t · all trims | |
| Shifters | Shimano Deore 12s · all trims | |
| Cassette | Shimano Deore 12s 10-51t · all trims | |
| Drivetrain | Shimano XT 12s; Shimano 36t; Shimano Deore 12s; Shimano Deore 12s 10-51t | Shimano Deore 12s; Shimano 36t; Shimano Deore 12s; Shimano Deore 12s 10-51t |
| Wheels | 29 Asymmetric 15x110 12x148 Boost Wide:30mm Tubeless Ready · all trims | |
| Tyres | Front: 29x2,6 Maxxis Minion DHF, Rear: 29x2,6 Maxxis Minion DHR II, Tubeless Ready, EXO Protection / Pirelli Scorpion Enduro S HardWALL · all trims | |
| Price | €7,299 | €6,199 |
Rides similarly
Spot a mistake?
