Crave AL 2025
The Megamo Crave AL is the Spanish brand's aluminium full-suspension trail and enduro platform, built around 150 mm of rear travel, a 4-bar Horst Link layout and a 762 Wh integrated battery on a 29in chassis. Megamo lists a slack 64.3 degree head angle, a 73 degree effective seat angle and reach growing from 455 mm to 490 mm across S to M to L, which puts it in modern long-and-slack territory aimed at confident descending rather than tight, low-speed manoeuvring.
The range splits clearly by motor and budget. The AL 10 runs the full-power Shimano EP801 (85 Nm) with a RockShox 35 Silver fork, RockShox Deluxe shock and a SRAM SX Eagle 12-speed drivetrain. The AL 40 steps down to the Shimano EP6 mid-power unit, a Suntour XCR 34 E-Bike+ fork at 130 mm and a 10-speed Shimano CUES groupset, which is why it carries the lowest price in the line. Both share four-piston Shimano MT420 brakes on 203 mm rotors and a dropper post, so the core descending kit is consistent even at the entry point.
Across the builds the wheel and tyre package is geared towards grip, with 30 mm internal asymmetric rims and Maxxis rubber. Buyers prioritising outright motor power and fork performance should look at the EP801 builds, while the EP6-equipped AL 40 is the value entry to the platform for riders who want the same geometry and frame at a lower outlay.
| S | M | L | |
| Reach | 455 mm | 470 mm | 490 mm |
| Stack | 627 mm | 632 mm | 636 mm |
| Seattube | 410 mm | 460 mm | 510 mm |
| Chainstay | 451 mm | 451 mm | 451 mm |
| Headtube Angle | 64.3° | 64.3° | 64.3° |
| Seattube Angle (eff) | 73° | 73° | 73° |
| Wheelbase | 1246 mm | 1263 mm | 1285 mm |
| Headtube | 135 mm | 140 mm | 145 mm |
| BB Height | 361 mm | 361 mm | 361 mm |
| Front Centre | 795 mm* | 812 mm* | 834 mm* |
Trims · 2
AL 40 £3,444 | AL 10 | |
| Motor | Shimano EP6 (DU-EP600) · 85 Nm | Shimano EP801 · 85 Nm |
| Battery | Shimano BT-EN805 · 762 Wh · all trims | |
| Travel F/R | 150/150 mm · all trims | |
| Frame | Aluminium · all trims | |
| Fork | Suntour XCR 34 E-Bike+, travel 130 mm, Boost 15x110, mini-fender included | RockShox 35 Silver R 29" Boost 15x110 mm 160 mm E-MTB Tapered Steerer |
| Shock | Suntour Edge | RockShox Deluxe Select R 205x65 DebonAir Tune Trunnion |
| Headset | — | Acros AZX-706 ZS56 |
| Stem | 3D Forged Alloy, Ext. 60-70-90 mm, Rise +/-7 deg · all trims | |
| Handlebar | Alloy Butted 31.8 x 780 mm, Rise 12 mm, Back Sweep 6 deg · all trims | |
| Saddle | Selle Italia Model X | Selle Italia Model X Superflow |
| Seatpost | Megamo telescopic seat post, 30.9 mm, remote adjustment · all trims | |
| Brakes | Shimano MT420 hydraulic disc 4-piston, 203 mm · all trims | |
| Rear derailleur | Shimano CUES 10s | SRAM SX Eagle 12s |
| Crank | Shimano SM-CRE70 36t / FC-EM600 165 mm | Shimano 36t |
| Shifters | Shimano CUES 10s | SRAM SX Eagle 12s |
| Cassette | Shimano CUES 10s | SRAM SX Eagle 12s 11-50t |
| Drivetrain | Shimano CUES 10s; Shimano SM-CRE70 36t / FC-EM600 165 mm; Shimano CUES 10s; Shimano CUES 10s | SRAM SX Eagle 12s; Shimano 36t; SRAM SX Eagle 12s; SRAM SX Eagle 12s 11-50t |
| Wheels | 29 Asymmetric 15x110 12x148 Boost, width 30 mm, tubeless ready | Megamo 29 SL 30 ASY - HG, 30 mm tubeless ready aluminium rim |
| Tyres | Maxxis Rekon 29 x 2.60 EXO foldable | Maxxis Rekon 29 x 2.6 |
| Price | £3,444 | — |
Rides similarly
Spot a mistake?
