Bike Finder · Marin
Marin Rift Zone EL
Marin
Rift Zone EL 2025
Currentlightweight (SL) trail eMTBMature · 5.4/10iFreshness 5.4/10
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Aluminium
Weight
21.5 kg
Price
From £3,899
View the Marin Rift Zone EL on Marin’s site
Marin Rift Zone EL 2025
From £3,899
💬 Forum discussion
What's next for Marin and EMTB's?
27 replies · 915 views · last reply today
Join the discussion →
Bike geometry diagram
SMLXL
Reach445 mm465 mm485 mm515 mm
Stack607 mm614 mm625 mm634 mm
Seattube390 mm400 mm425 mm435 mm
Chainstay440 mm440 mm440 mm440 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)77°77°77°77°
Wheelbase1198 mm1223 mm1247 mm1281 mm
Standover694 mm696 mm710 mm720 mm
Front Centre758 mm*783 mm*807 mm*841 mm*
Trims · 3
Rift Zone EL1
£3,899
Rift Zone EL2
£4,899
Rift Zone EL XR
£5,799
MotorBosch Performance Line SX · 55 Nm · all trims
BatteryBosch CompactTube 400Wh · 400 Wh · all trims
Travel F/R150/140 mm · all trims
FrameAluminium · all trims
ForkMarzocchi Bomber Z1, 150mm, 29in, 110x15 KaboltFox 36 Performance, 150mm, 29in, 110x15 Kabolt, 44mm offsetFox 36 Performance Elite, 150mm, 29in, 110x15 Kabolt, 44mm offset
ShockMarzocchi Bomber Air Inline, Custom Tune, 210x55mmFox Float X Performance, EVOL Air, Climb Switch, Custom Tune, 210x55mmFox Float X Performance Elite, EVOL Air, Climb Switch, Custom Tune, 210x55mm
HeadsetFSA Custom Headset, Adjustable HTA Design · all trims
StemMarin 3D Forged Alloy, 35mmMarin CNC, 35mm Length, 35mm Bar BoreMarin CNC, 35mm Length, 35mm Bar Bore
HandlebarMarin Mini-Riser, 6061 Double Butted Aluminum, 780mm WidthMarin Trail, 35mm Clamp, 7000 Alloy Bar, 800mm Length, 20mm RiseMarin Trail, 35mm Clamp, 7000 Alloy Bar, 800mm Length, 20mm Rise
GripsMarin Grizzly Lock-On · all trims
SaddleMarin Speed Concept · all trims
SeatpostTranzX, YSI34 QL, Plastic 1x RemoteTranzX, YSP39 1x Remote, 34.9 Diameter, S=150mm / M-L=170mm / XL=200mmPNW Loam Post with Range Lever
BrakesTRP Slate EVO, 4-piston hydraulic disc, 203mm rotorsSRAM Code Bronze, 4-piston hydraulic disc, 200mm HS2 rotorsMagura MT7 with HC3 Lever, 4-piston hydraulic disc, 203mm MDR rotors
Rear derailleurShimano CUES RD-U6000 GS, 10-speedSRAM Eagle 90SRAM GX Eagle AXS T-Type (12-speed wireless)
Cranke*thirteen e*spec Plus, 160mm Length, 34Te*thirteen e*spec Plus, 160mm Length, 34Te*thirteen e*spec Plus Carbon, 160mm Length, 34T
ShiftersShimano CUES SL-U6000-10R, 10-SpeedSRAM EAGLE 90 MMX Mount, Single ClickSRAM AXS POD Controller, Infinity Mount
CassetteShimano CS-LG300-10, 11-48TSRAM XG-1275 Eagle Cassette, 10-52TSRAM XS-1275 T-Type, 10-52T
ChainShimano LG500SRAM GX T-TypeSRAM GX T-Type
DrivetrainShimano CUES RD-U6000 GS, 10-speed; e*thirteen e*spec Plus, 160mm Length, 34T; Shimano CUES SL-U6000-10R, 10-Speed; Shimano CS-LG300-10, 11-48T; Shimano LG500SRAM Eagle 90; e*thirteen e*spec Plus, 160mm Length, 34T; SRAM EAGLE 90 MMX Mount, Single Click; SRAM XG-1275 Eagle Cassette, 10-52T; SRAM GX T-TypeSRAM GX Eagle AXS T-Type (12-speed wireless); e*thirteen e*spec Plus Carbon, 160mm Length, 34T; SRAM AXS POD Controller, Infinity Mount; SRAM XS-1275 T-Type, 10-52T; SRAM GX T-Type
WheelsMarin Aluminum Double Wall, 29", 32mm Inner Rim Width, Tubeless Compatible, Shimano hubsMarin Aluminum Double Wall, 29", 32mm Inner Rim Width, Tubeless CompatibleMarin Aluminum Double Wall, 29", 32mm Inner Rim Width; Formula hubs (front DCL-3482 XD, rear DC-711)
TyresMaxxis Minion DHF 29x2.5in (front), Maxxis Forekaster 29x2.4in (rear) · all trims
Weight21.5 kg
Price£3,899£4,899£5,799
Rides similarly
Spot a mistake?
