Bike Finder · MAXX
MAXX Tourmaxx ELS Sport
MAXX
Tourmaxx ELS Sport 2026
CurrentFull Power · Cross-CountryLegacy · 2.5/10iFreshness 2.5/10
Shimano EP801/EP600 all-mountain eMTB with 726Wh battery, 130mm travel, configurable
Travel F/R
140/130mm
Wheels
29F/29R
Frame
Aluminium
Weight
Price
£5,043
View the MAXX Tourmaxx ELS Sport on MAXX’s site
MAXX Tourmaxx ELS Sport 2026
From £5,043
EMTB Forums verdict
The MAXX Tourmaxx ELS Sport 2026 is an aluminium touring and trail eMTB from the German MAXX house brand, built around the Shimano EP801 drivetrain and an 800 Wh removable battery. Headline numbers: 130 mm of fork and rear travel, 85 Nm of torque, a 470 mm chainstay across all sizes, head angle ranging 65 to 66.5 degrees depending on size and reach progressing from 427 mm on S through to 501 mm on XXL. MAXX is one of the smaller German cottage brands building hand-assembled trail bikes for touring duty, and the ELS Sport is their entry-level Tourmaxx tier at €4899. No curated rider quotes are yet on file for this bike on the forum.
Drive system and range. Shimano EP801 (DU-EP801) is the latest-generation Shimano full-power unit, delivering 85 Nm of torque, 250 W nominal and a manufacturer-claimed 600 W peak. EP801 has earned a reputation for smooth power modulation and intuitive control, especially on technical climbing in tight switchbacks. Press testing has flagged two weaker points worth knowing about: traction on wet ground can be inconsistent versus Bosch CX, and the motor tends to develop a slight rattle on descents which is intermittent and not a fault. The 800 Wh removable battery is class-competitive at this travel and weight, supporting genuinely long touring rides. Real-world range on EP801 at 800 Wh in trail use typically lands 45 to 70 km depending on assist, terrain and rider weight.
Geometry and handling. A 66.5 degree head angle on S, M, XL and XXL with the L at 65 degrees is an unusual size-tuned approach: the larger frames being a touch slacker than the medium and small. Reach steps clean from 427 mm S, 447 mm M, 465 mm L, 483 mm XL and 501 mm XXL, a steady 20 mm-per-size progression. The 470 mm chainstay is held constant across all five sizes, which is on the longer side for a trail bike and keeps the back end planted: it points to a touring-friendly, stable-feel ride character rather than playful agility. Wheelbase progression 1214 to 1307 mm reinforces the touring brief.
Build and value. MAXX publishes a single base trim at €4899 for the spec we have on file. At this price you get the EP801 drive unit, an 800 Wh removable battery, the aluminium 130 mm chassis and the chassis features (hand-assembled in Germany, custom paint options) that are MAXX's traditional differentiators. Component spec at this entry tier is mid-grade rather than top-shelf, which is consistent with the touring brief. The trade for the cottage-brand pricing is a much smaller dealer network outside Germany, Austria and Switzerland.
Verdict. The MAXX Tourmaxx ELS Sport 2026 is a niche, hand-assembled German touring eMTB. Strengths are real. 130/130 mm of travel paired with the latest Shimano EP801 motor and an 800 Wh battery is a sensible match for touring, alpine hut-to-hut and long mixed trail rides. The 470 mm chainstay across all sizes gives stability for long hours in the saddle. The size-tuned head angle is unusual but works for the riding brief. The honest caveats are clear. The 65 to 66.5 degree head angle is touring-leaning rather than aggressive trail or enduro: this is a tourer with mountain-bike capability, not a hardcore trail tool. The dealer network for warranty and service work outside German-speaking Europe is thin. There is no on-file forum data on long-term reliability or owner experience: the curated quotes block is empty. Buyers in the UK or elsewhere will be relying on shipped-in service rather than local dealer support. The Tourmaxx ELS Sport suits the rider who wants a touring-capable aluminium full-suspension trail eMTB with EP801 power and 800 Wh of battery, and is happy with cottage-brand pricing and a German-centric dealer network. Riders prioritising broad dealer footprint, slacker enduro-style geometry or top-shelf component spec at this price should look at a Cube Stereo Hybrid, Canyon Spectral:ON or Specialized Levo SL. Production status is current.
Geometry read
Size
Descending
61
A solid all-round descender (65° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
42
Size balance
78
Rear-long with a planted front in L (FC:RC 1.68) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
75
Shimano EP801 and a steep 75° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Cross-Country bikes (from 104 bikes in the database)
Battery800 Wh102 Wh above average
Motor torque85 Nm8 Nm below average
Value for money5/100from £5,043 · comparable bikes ~£3,399
Bike geometry diagram
SMLXLXXL
Reach427 mm447 mm465 mm483 mm501 mm
Stack633 mm642 mm643 mm665 mm679 mm
Chainstay470 mm470 mm470 mm470 mm470 mm
Headtube Angle66.5°66.5°65°66.5°66.5°
Seattube Angle (eff)75°75°75°75°75°
BB Drop30 mm30 mm30 mm30 mm30 mm
Wheelbase1214 mm1237 mm1260 mm1283 mm1307 mm
Headtube125 mm135 mm135 mm160 mm175 mm
BB Height345 mm345 mm345 mm345 mm345 mm
Front Centre744 mm767 mm790 mm813 mm837 mm
FC:RC1.581.631.681.731.78
Trims · 1
Tourmaxx ELS Sport
£5,043
MotorShimano EP801 · 85 Nm
Battery800 Wh
Travel F/R140/130 mm
FrameAluminium (6061-T6 Octatube)
ForkRockShox Psylo Gold RC, 140mm, 29"
ShockFox Float X TR 185x55
HeadsetFSA Block-Lock 180°, ZS44/28.6 | ZS56/40, ICR
StemMAXX stem (45mm/0° S, 55mm/0° M, 70mm/7° L, 80mm/7° XL, 90mm/7° XXL)
HandlebarMAXX Low Riser, 35mm, 740mm width, 15mm rise, 9°
GripsMAXX Race Grip Lock-On
SaddleErgon SMC10, 149mm, black
SeatpostMAXX Premium rigid, 31.6x400mm
BrakesShimano Deore BL-M6100/BR-M6120
Rear derailleurShimano XT Linkglide RD-M8130 SGS, 11-speed
CrankShimano Steps FC-EM600, 170mm
ShiftersShimano XT Link Glide SL-M8130, 11-speed
CassetteShimano CS-LG700, 11-50T, 11-speed Linkglide
ChainShimano SLX CN-HG601, 11-speed
DrivetrainShimano XT Linkglide 11-speed
WheelsSun Ringle SRC B rims, Newman Performance 30 Strong hubs, 32-spoke
TyresSchwalbe Nobby Nic 62-622/29x2.4", Performance, folding
Price£5,043
Rides similarly
Spot a mistake?
