Bike Finder · MAXX
MAXX Tourmaxx ELS Sport
MAXX
Tourmaxx ELS Sport 2025
CurrentFull Power · Cross-CountryAgeing · 4.7/10iFreshness 4.7/10
Travel F/R
130/130mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£5,190
View the MAXX Tourmaxx ELS Sport on MAXX’s site
MAXX Tourmaxx ELS Sport 2025
From £5,190
EMTB Forums verdict
The MAXX Tourmaxx ELS Sport is a German-built, made-to-order alloy allmountain eMTB running 130mm of travel front and rear on 29in wheels. MAXX is a direct-sales custom builder from Rosenheim, so rather than fixed trims the bike is configured to order, with a choice between the Shimano EP600 and EP801 motors (both rated 85Nm and compatible with Shimano AUTO and FREE SHIFT). The frame uses MAXX's Octatube eight-sided down tube in 6061-T6 alloy and carries a removable 720Wh down-tube battery.
Because the bike is built through the configurator there is a single base specification rather than priced trims. That base build leans on dependable, serviceable Shimano kit: an XT Linkglide 11-speed drivetrain with an 11-50T cassette, four-piston Deore brakes on a 203/180mm rotor pairing, and a RockShox Psylo Gold RC fork matched to a Fox Float X TR shock. Hand-laced Sunringle/Newmen 30 Strong wheels on Schwalbe Nobby Nic tyres round out a touring-focused package.
Geometry is set up for relaxed, stable touring rather than aggressive trail riding. The 75 degree effective seat angle is consistent across the size run, and the head angle sits at 66.5 degrees on most sizes with the L slackened to 65 degrees per MAXX's published figures. Reach grows from 427mm on the S to 501mm on the XXL, with a long 470mm chainstay across all sizes and short seat tubes to suit long dropper posts. The five-size range covers riders from 1.60m to 2.08m.
Geometry read
Size
Descending
61
A solid all-round descender (65° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
42
Size balance
78
Rear-long with a planted front in L (FC:RC 1.68) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
75
Shimano EP6 (DU-EP600) and a steep 75° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Cross-Country bikes (from 104 bikes in the database)
Battery720 Whabout average capacity
Motor torque85 Nm8 Nm below average
Value for money5/100from £5,190 · most Shimano EP6 (DU-EP600) bikes ~£3,799
Bike geometry diagram
SMLXLXXL
Reach427 mm447 mm465 mm483 mm501 mm
Stack633 mm642 mm643 mm665 mm679 mm
Seattube380 mm420 mm460 mm520 mm540 mm
Chainstay470 mm470 mm470 mm470 mm470 mm
Headtube Angle66.5°66.5°65°66.5°66.5°
Seattube Angle (eff)75°75°75°75°75°
Wheelbase1214 mm1237 mm1260 mm1283 mm1307 mm
Headtube125 mm135 mm135 mm160 mm175 mm
BB Height345 mm345 mm345 mm345 mm345 mm
Front Centre744 mm*767 mm*790 mm*813 mm*837 mm*
FC:RC1.581.631.681.731.78
Trims · 1
Base
£5,190
MotorShimano EP6 (DU-EP600) · 85 Nm
BatteryDarfon 720Wh Gen 1.5 · 720 Wh
Travel F/R130/130 mm
FrameAluminium
ForkRockShox Psylo Gold RC, 140mm, 29 inch, black
ShockFox Float X TR 185x55 XXL-Setup
HeadsetFSA Block-Lock 180 deg, ZS44/28.6 | ZS56/40, ICR
HandlebarMAXX Low Riser, 35mm dia, 740mm width, 15mm rise, 9 deg
GripsMAXX Race Grip Lock-On
SaddleErgon SMC10, 149mm, black
SeatpostMAXX Premium rigid, 31.6x400mm
BrakesShimano Deore BL-M6100/BR-M6120, 4-piston, 203/180mm
Rear derailleurShimano XT LINKGLIDE RD-M8130 SGS, 11-speed
CrankShimano Steps FC-EM600, 170mm
ShiftersShimano XT Link Glide SL-M8130, 11-speed
CassetteShimano CS-LG700, 11-50T, 11-speed Linkglide
ChainShimano SLX CN-HG601, 11-speed
DrivetrainShimano XT LINKGLIDE RD-M8130 SGS, 11-speed; Shimano Steps FC-EM600, 170mm; Shimano XT Link Glide SL-M8130, 11-speed; Shimano CS-LG700, 11-50T, 11-speed Linkglide; Shimano SLX CN-HG601, 11-speed
WheelsSunringle SRC B HG / Newmen Performance 30 Strong, 28/29 inch, 32H (front and rear)
TyresSchwalbe Nobby Nic 62-622 / 29x2.4 inch, Performance, folding
Price£5,190
Rides similarly
Spot a mistake?
