Bike Finder · MAXX
MAXX Racemaxx ELS
MAXX
Racemaxx ELS 2023
DiscontinuedFull Power · Cross-CountryLegacy · 0.4/10iFreshness 0.4/10
Full-power alloy hardtail with big battery range for long climbs
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£0
View the MAXX Racemaxx ELS on MAXX’s site
MAXX Racemaxx ELS 2023
EMTB Forums verdict
The MAXX Racemaxx ELS is the full-power hardtail in the boutique Bavarian brand's e-mountain bike line. It pairs a Shimano EP8 mid-motor (85Nm) with a fully integrated, removable 726Wh down-tube battery, and runs roughly 100 to 120mm of fork travel on a relaxed 68 degree head angle and 73 degree effective seat angle chassis. The rear is rigid, so this is a true e-hardtail.
The frame is welded from MAXX's own 6061-T6 aluminium custom tubing with the distinctive eight-sided Octatube down tube, a Boost 12x148mm rear axle and a twin-layer powder coat. MAXX pitches it as a multitool: XS and S sizes roll on 27.5in wheels while M and up take 29in or optional B+ tyres up to 75mm wide, and the bike can be set up as a sporty trail e-MTB or as a touring ATB with rack, mudguards and kickstand. The size run is unusually broad, spanning eight frames from XS to 4XL for riders from about 1.50m to 2.12m.
As with every MAXX, this is built to order through the configurator, so equipment, ergonomics and finish are specified per customer rather than sold as a fixed off-the-peg model. The 2023 page does publish a standard class specification, which is captured here: a Shimano XT M8130 1x11 drivetrain, Magura MT5 Trail brakes on 203/180mm rotors, SunRingle Duroc 30 rims and Schwalbe Nobby Nic tyres. The suspension fork is still chosen through the configurator rather than fixed, so no fork brand is listed.
This is a low-volume German hand-built bike with no meaningful pool of owner feedback, and it has since been superseded in the MAXX range, so it is now a discontinued model.
Geometry read
Size
Wheels
Descending
43
Steeper 68° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Playfulness
53
Size balance
46
Rear-long with a planted front in L (FC:RC 1.54) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
72
Shimano EP8 (DU-EP800) and a steep 73° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
Watch out forNot built for serious descending — happier on flow than in the rough and steep.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
Battery726 Whabout average capacity
Motor torque85 Nmabout average torque
Bike geometry diagram
XSSMLXLXXL3XL
Reach412 mm427 mm421 mm428 mm445 mm462 mm479 mm
Stack600 mm600 mm652 mm661 mm670 mm679 mm689 mm
Seattube360 mm400 mm440 mm480 mm520 mm560 mm600 mm
Chainstay452 mm452 mm468 mm468 mm468 mm480 mm480 mm
Headtube Angle68°68°68°68°68°68°68°
Seattube Angle (eff)73°73°73°73°73°73°73°
Wheelbase1129 mm1144 mm1178 mm1189 mm1210 mm1243 mm1264 mm
Headtube135 mm135 mm145 mm155 mm165 mm175 mm185 mm
BB Height305 mm305 mm314 mm314 mm314 mm314 mm314 mm
Front Centre677 mm*692 mm*710 mm*721 mm*742 mm*763 mm*784 mm*
FC:RC1.501.531.521.541.591.591.63
Trims · 1
Base
£0
MotorShimano EP8 (DU-EP800) · 85 Nm
BatteryShimano down-tube 726Wh · 726 Wh
Travel F/R120/? mm
Frame6061-T6 aluminium, Octatube (8-sided down tube) MAXX Custom Tubing, twin-layer powder coat
ForkSuspension fork, 100-120mm travel on M and up (XS/S 80-100mm). No fork brand/model published in the 2023 Class Specification - the fork is a configurator selection.
HeadsetOversized tapered headset.
StemMAXX MTB 0 or 7 degree
HandlebarMAXX Rizer 35 MTB
GripsHandlebar race grip with bolt, 130 mm, black
SaddleSelle Italia Man Flow
SeatpostMAXX Premium
BrakesMagura MT5 Trail Sport 4/2 piston disc 203/180 mm
Rear derailleurShimano XT RD M8130
CrankShimano SMCRME80 Boost 34T
ShiftersShimano XT SL M8130
CassetteShimano CS LG700 11-50, 1 x 11
ChainShimano 11-speed CNHG601
DrivetrainShimano XT RD M8130; Shimano SMCRME80 Boost 34T; Shimano XT SL M8130; Shimano CS LG700 11-50, 1 x 11; Shimano 11-speed CNHG601
WheelsSunRingle Duroc 30, 32H, SV, black
TyresSchwalbe Nobby Nic Performance folding 60-584 (27.5x2.35) on the XS/S standard build; M and up run 29in or optional B+ up to 75mm (3in).
Price£0
Rides similarly
Spot a mistake?
