Shorter and steeper (1209mm, 67°) — quick to react but less planted flat-out.
Racemaxx ELF 2026
The Racemaxx ELF is MAXX's lightweight e-hardtail, built around a 6061-T6 aluminium frame with the brand's custom tubing and the compact Fazua Ride 60 motor. With 60 Nm and a 450 W Boost peak fed by a removable 430 Wh in-tube battery, it sits firmly in the light-assist camp rather than the full-power category, aimed at riders who want a natural, agile feel close to a non-assisted bike.
It is sold as a single configurable build through MAXX's own configurator. The base kit pairs an SR Suntour Raidon34 fork with a Shimano XT Linkglide 11-speed transmission, a hard-wearing CS-LG700 11-50T cassette and four-piston Shimano Deore brakes on a 203/180 mm rotor pairing, plus MAXX's own cockpit and Schwalbe Nobby Nic tyres. The rigid seatpost and 740 mm bar reflect the cross-country and tour brief rather than a gravity setup.
Geometry is conservative and sporty rather than slack: a 67 degree head angle and 73 degree effective seat angle run across all four sizes, with reach growing from 398 mm on the XS to 457 mm on the L. Notably the two smaller sizes (XS and S) roll on 27.5 inch wheels with shorter 435 mm chainstays, while the M and L switch to 29 inch wheels with 455 mm stays, so MAXX tailors wheel size and rear-centre to rider height. Short seat tubes leave room for longer dropper posts should a buyer add one.
| XS | S | M | L | |
| Reach | 398 mm | 426 mm | 440 mm | 457 mm |
| Stack | 578 mm | 587 mm | 637 mm | 646 mm |
| Seattube | 350 mm | 380 mm | 420 mm | 460 mm |
| Chainstay | 435 mm | 435 mm | 455 mm | 455 mm |
| Headtube Angle | 67° | 67° | 67° | 67° |
| Seattube Angle (eff) | 73° | 73° | 73° | 73° |
| Wheelbase | 1100 mm | 1131 mm | 1188 mm | 1209 mm |
| Headtube | 110 mm | 120 mm | 130 mm | 140 mm |
| Front Centre | 665 mm* | 696 mm* | 733 mm* | 754 mm* |
| FC:RC | 1.53 | 1.60 | 1.61 | 1.66 |
Computed from this bike's geometry and spec — reach, wheelbase, chainstay, head and seat angles, travel, motor, battery and weight — and worked out per size, because a fixed chainstay can make an S and an XL feel very different.
Rear-long with a planted front in L (FC:RC 1.66) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
A workmanlike climber — expect to put in more rider effort on the steep stuff.
Fine at trail pace; ease off on the really fast, rough stuff.
How it stacks up vs other Lightweight · Cross-Country bikes (from 56 bikes in the database)
Trims · 1
Base £3,630 | |
| Motor | Fazua Ride 60 · 60 Nm |
| Battery | Fazua Energy 430 · 430 Wh |
| Travel F/R | 100/? mm |
| Frame | 6061-T6 aluminium, MAXX Custom Tubing, twice powder-coated |
| Fork | SR Suntour Raidon34, 80 mm, 27.5", black |
| Headset | FSA Block-Lock 180 deg, ZS56/28.6 | ZS56/40, ICR (Acros internal cable routing) |
| Stem | MAXX Flat Oversize 0 deg, 35 mm, 35 mm dia |
| Handlebar | MAXX Low Riser, 35 mm dia, 740 mm wide, 15 mm rise, 9 deg |
| Grips | MAXX Race Grip Lock-On |
| Saddle | Ergon SMC10, 149 mm, black |
| Seatpost | MAXX Premium rigid, 31.6 x 350 mm |
| Brakes | Shimano Deore BL-M6100 / BR-M6120, 4-piston, 203/180 mm |
| Rear derailleur | Shimano XT LINKGLIDE RD-M8130 SGS, 11-speed |
| Crank | Samox EC38F crank arms, Fazua Ride 60, 165 mm |
| Shifters | Shimano XT Link Glide SL-M8130, 11-speed |
| Cassette | Shimano CS-LG700, 11-50T, 11-speed Linkglide |
| Chain | Shimano SLX CN-HG601, 11-speed |
| Drivetrain | Shimano XT LINKGLIDE RD-M8130 SGS, 11-speed; Samox EC38F crank arms, Fazua Ride 60, 165 mm; Shimano XT Link Glide SL-M8130, 11-speed; Shimano CS-LG700, 11-50T, 11-speed Linkglide; Shimano SLX CN-HG601, 11-speed |
| Wheels | Miche XM-H 550 hubs / Newmen Performance 30 Base rims, 27.5", 28H (front and rear) |
| Tyres | Schwalbe Nobby Nic 62-584 / 27.5x2.4", Performance, folding |
| Price | £3,630 |
Rides similarly
Spot a mistake?
