A solid all-round descender (67° head angle, 100mm) — capable in the rough and steep without being an all-out bruiser.
Racemaxx ELF 2025
Light Fazua hardtail for XC pace and long fire-road days
The MAXX Racemaxx ELF Ride 60 is a lightweight aluminium e-hardtail built around the Fazua Ride 60 motor, a 60 Nm 250 W unit, paired with a removable 430 Wh down-tube battery. MAXX position it for sportier, lighter riders from 150 cm who want assistance on tour and training rides without the weight of a full-power system. The hand-built 6061-T6 Custom Tubing frame uses Acros internal routing and a double powder-coat finish in the buyer's chosen colour.
It is a custom-configured bike rather than a fixed-trim model, so the build listed here is the base specification: a Shimano XT Linkglide 1x11 drivetrain with an 11-50T cassette, Shimano Deore four-piston brakes on 203/180mm rotors, and a Fazua-specific Samox 165mm crank. The smaller XS and S frames run 27.5in wheels with an 80mm SR Suntour Raidon34 fork, while M and L step up to 29in wheels and 100-120mm of travel.
Geometry is deliberately conservative and tour-oriented: a 67 degree head angle and 73 degree effective seat angle hold across all four sizes, with reach growing from 398mm on the XS to 457mm on the L. Short seat tubes (350-460mm) leave room for longer dropper posts, though the base build ships with a rigid MAXX seatpost. With a hardtail rear and modest front travel, this is a fast, efficient trail and training platform rather than a descent-focused machine.
Rear-long with a planted front in L (FC:RC 1.66) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Climbs well — a 73° seat keeps the front planted. 450W of peak power and 60Nm of torque.
How it stacks up vs other Lightweight · Cross-Country bikes (from 70 bikes in the database)
| XS | S | M | L | |
| Reach | 398 mm | 426 mm | 440 mm | 457 mm |
| Stack | 578 mm | 587 mm | 637 mm | 646 mm |
| Seattube | 350 mm | 380 mm | 420 mm | 460 mm |
| Chainstay | 435 mm | 435 mm | 455 mm | 455 mm |
| Headtube Angle | 67° | 67° | 67° | 67° |
| Seattube Angle (eff) | 73° | 73° | 73° | 73° |
| Wheelbase | 1100 mm | 1131 mm | 1188 mm | 1209 mm |
| Headtube | 110 mm | 120 mm | 130 mm | 140 mm |
| BB Height | 304 mm | 304 mm | 308 mm | 308 mm |
| Front Centre | 665 mm* | 696 mm* | 733 mm* | 754 mm* |
| FC:RC | 1.53 | 1.60 | 1.61 | 1.66 |
Trims · 1
Base £3,630 | |
| Motor | Fazua Ride 60 · 60 Nm |
| Battery | Fazua Energy 430 · 430 Wh |
| Travel F/R | 100/? mm |
| Frame | Aluminium 6061-T6 MAXX Custom Tubing |
| Fork | SR Suntour Raidon34, 80mm, 27.5", black (XS/S); M/L 100-120mm 29" |
| Headset | FSA Block-Lock 180deg, ZS44/28.6 | ZS56/40, ICR (Acros internal routing) |
| Stem | MAXX Flat Oversize 0deg, 35mm, 35mm dia |
| Handlebar | MAXX Low Riser, 35mm dia, 740mm width, 15mm rise, 9deg |
| Grips | MAXX Race Grip Lock-On |
| Saddle | Ergon SMC10, 149mm, black |
| Seatpost | MAXX Premium rigid, 31.6x350mm |
| Brakes | Shimano Deore BL-M6100/BR-M6120, 4-piston, 203/180mm |
| Rear derailleur | Shimano XT LINKGLIDE RD-M8130 SGS, 11-speed |
| Crank | Samox crank arms EC38F, Fazua Ride 60, 165mm |
| Shifters | Shimano XT Link Glide SL-M8130 11-speed |
| Cassette | Shimano CS-LG700, 11-50T, 11-speed Linkglide |
| Chain | Shimano SLX CN-HG601, 11-speed |
| Drivetrain | Shimano XT LINKGLIDE RD-M8130 SGS, 11-speed; Samox crank arms EC38F, Fazua Ride 60, 165mm; Shimano XT Link Glide SL-M8130 11-speed; Shimano CS-LG700, 11-50T, 11-speed Linkglide; Shimano SLX CN-HG601, 11-speed |
| Wheels | Miche XM-H 550 hub / Newmen Performance 30 Base, 27.5", 28H (front and rear) |
| Tyres | Schwalbe Nobby Nic 62-584 / 27.5x2.4", Performance folding |
| Price | £3,630 |
Rides similarly
Spot a mistake?
