Bike Finder · MAXX
MAXX Jinxx ELF
MAXX
Jinxx ELF 2025
CurrentLightweight · TrailAgeing · 4.4/10iFreshness 4.4/10
Motor
Fazua Ride 60 · 60Nm · 450W
Battery
Fazua Energy 430 · 430Wh
Travel F/R
140/140mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£4,320
View the MAXX Jinxx ELF on MAXX’s site
MAXX Jinxx ELF 2025
From £4,320
EMTB Forums verdict
The MAXX Jinxx ELF is a German hand-built lightweight trail eMTB centred on the Fazua Ride 60 motor (60 Nm, 450 W peak) paired with a removable 430 Wh down-tube battery. The 6061-T6 aluminium frame keeps system weight low, aimed at riders who want moderate, natural-feeling assistance rather than the heft of a full-power drive.
MAXX sells the Jinxx ELF as a custom configurator bike, so the listed build is the standard specification rather than a range of fixed trims. It is a sensible, function-first kit: a RockShox Pike Select fork and Fox Float X TR shock front the suspension, with Shimano XT/SLX 11-speed Linkglide shifting and four-piston Shimano Deore brakes on 203/180mm rotors. Wheels are hand-built on Miche/Newmen rims, and finishing kit is mostly MAXX's own components.
Geometry is consistent and trail-oriented across the size run, with a 66-degree head angle and a 75 to 75.5-degree effective seat angle throughout. Reach grows from 443mm on the S to 505mm on the XL. The S size runs 27.5in wheels with 130mm rear travel, while M, L and XL move to 29in wheels and 140mm rear travel, giving smaller riders a more manageable stance and taller riders the rollover of the bigger hoops.
Geometry read
Size
Wheels
Descending
56
A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
31
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
92
Rear-long with a planted front in L (FC:RC 1.75) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
67
Climbs well — a 75° seat keeps the front planted. 450W of peak power and 60Nm of torque.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Lightweight · Trail bikes (from 87 bikes in the database)
Battery430 Whabout average capacity
Motor torque60 Nmabout average torque
Value for money70/100from £4,320 · comparable bikes ~£4,999
Bike geometry diagram
SMLXL
Reach443 mm458 mm481 mm505 mm
Stack589 mm625 mm635 mm653 mm
Seattube380 mm420 mm460 mm500 mm
Chainstay445 mm461 mm461 mm461 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)75°75°75°75.5°
Wheelbase1197 mm1240 mm1266 mm1298 mm
Headtube110 mm120 mm140 mm150 mm
BB Height342 mm345 mm345 mm345 mm
Front Centre752 mm*779 mm*805 mm*837 mm*
FC:RC1.691.691.751.82
Trims · 1
Base
£4,320
MotorFazua Ride 60 · 60 Nm
BatteryFazua Energy 430 · 430 Wh
Travel F/R140/140 mm
FrameAluminium 6061-T6 MAXX Custom tubing
ForkRockShox Pike Select, 140mm, 27.5", black
ShockFox Float X TR 185x55 XXL setup
HeadsetFSA Block-Lock 180°, ZS44/28.6 | ZS56/40, ICR (Acros)
StemMAXX Flat Oversize 0°, 35mm, Ø35mm
HandlebarMAXX Low Riser, 35mm Ø, 740mm width, 15mm rise, 9°
GripsMAXX Race Grip Lock-On
SaddleErgon SMC10, 149mm, black
SeatpostMAXX Premium rigid, 31.6x350mm
BrakesShimano Deore BL-M6100/BR-M6120, 4-piston
Rear derailleurShimano XT LINKGLIDE RD-M8130 SGS, 11-speed
CrankSamox Crank Arms EC38F, Fazua Ride 60, 165mm
ShiftersShimano XT Link Glide SL-M8130 11-speed
CassetteShimano CS-LG700, 11-50T, 11-speed Linkglide
ChainShimano SLX CN-HG601, 11-speed
DrivetrainShimano XT LINKGLIDE RD-M8130 SGS, 11-speed; Samox Crank Arms EC38F, Fazua Ride 60, 165mm; Shimano XT Link Glide SL-M8130 11-speed; Shimano CS-LG700, 11-50T, 11-speed Linkglide; Shimano SLX CN-HG601, 11-speed
WheelsMiche XM-H 550 / Newmen Performance 30 Base, 27.5", 28H (hand-built)
TyresSchwalbe Nobby Nic 62-584 / 27.5x2.4", Performance, folding
Price£4,320
Rides similarly
Spot a mistake?
