Bike Finder · MAXX
MAXX FAB.4 ELS X2
MAXX
FAB.4 ELS X2 2025
CurrentFull Power · EnduroAgeing · 4.7/10iFreshness 4.7/10
Travel F/R
170/160mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£5,620
View the MAXX FAB.4 ELS X2 on MAXX’s site
MAXX FAB.4 ELS X2 2025
From £5,620
EMTB Forums verdict
The MAXX FAB.4 ELS X2 is the Bavarian brand's alloy E-enduro, built around a 6061-T6 Octatube frame with 160mm of rear travel and a 170mm fork. The geometry is properly modern enduro: a 65 degree head angle, 75 degree effective seat angle and a tight 455mm chainstay held constant across all five sizes, with reach growing from 427mm on the S to 525mm on the XXL.
Power comes from Shimano's EP801 motor with 85Nm of torque and up to 400 percent assistance, fed by a removable down-tube pack that can be specified from 600Wh up to 800Wh, so range can be tuned to the ride. The standard build pairs a RockShox ZEB Select fork with a Fox Float X TR shock, four-piston Shimano Deore brakes on a 203mm front rotor, and a robust Shimano XT Linkglide 11-speed drivetrain on hand-built 29in wheels.
MAXX sells direct from Germany as a made-to-order, configurable bike, so the listed figure is a starting price and there is no UK RRP; the build, finish and battery size are chosen at order. Within the FAB.4 line the ELS X2 sits below the newer carbon FAB.4 ELA, offering the durable aluminium chassis and the proven Shimano drive system at a lower entry point.
Geometry read
Size
Descending
59
A solid all-round descender (65° head angle, 160mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
26
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
96
Balanced front-to-rear in L (FC:RC 1.80) — weight sits evenly between the wheels.
Technical climbing
70
Climbs well — a 75° seat keeps the front planted. 600W of peak power and 85Nm of torque — a strong full-power motor.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 128 bikes in the database)
Battery600 Wh135 Wh below average
Motor torque85 Nm19 Nm below average
Value for money50/100from £5,620 · most Shimano EP801 bikes ~£5,620
Bike geometry diagram
SMLXLXXL
Reach427 mm453 mm470 mm498 mm525 mm
Stack634 mm639 mm652 mm670 mm688 mm
Seattube380 mm420 mm460 mm500 mm540 mm
Chainstay455 mm455 mm455 mm455 mm455 mm
Headtube Angle65°65°65°65°65°
Seattube Angle (eff)75°75°75°75°75°
Wheelbase1222 mm1251 mm1274 mm1310 mm1346 mm
Headtube115 mm120 mm135 mm155 mm175 mm
BB Height355 mm355 mm355 mm355 mm355 mm
Front Centre767 mm*796 mm*819 mm*855 mm*891 mm*
FC:RC1.691.751.801.881.96
Trims · 1
Base
£5,620
MotorShimano EP801 · 85 Nm
BatteryDarfon 600Wh · 600 Wh
Travel F/R170/160 mm
FrameAluminium (6061-T6 Octatube custom tubing)
ForkRockShox ZEB Select, 170mm, 29", black
ShockFox Float X TR 185x55 XXL-Setup
HeadsetFSA Block-Lock 180 deg, ZS44/28.6 | ZS56/40, ICR
Steme*thirteen Base 0 deg, 40mm, 35mm dia
Handlebare*thirteen Base, 35mm dia, 800mm width, 20mm rise, 9 deg
GripsMAXX Race Grip Lock-On
SaddleErgon SMC10, 149mm, black
SeatpostMAXX Premium rigid, 31.6x350mm
BrakesShimano Deore BL-M6100 / BR-M6120, 4-piston, 203/180mm
Rear derailleurShimano XT Linkglide RD-M8130 SGS, 11-speed
CrankShimano Steps FC-EM600, 165mm
ShiftersShimano XT Link Glide SL-M8130, 11-speed
CassetteShimano CS-LG700, 11-50T, 11-speed Linkglide
ChainShimano SLX CN-HG601, 11-speed
DrivetrainShimano XT Linkglide RD-M8130 SGS, 11-speed; Shimano Steps FC-EM600, 165mm; Shimano XT Link Glide SL-M8130, 11-speed; Shimano CS-LG700, 11-50T, 11-speed Linkglide; Shimano SLX CN-HG601, 11-speed
WheelsMiche XM-H550 HG / Newmen Perf. 30 Base, 28/29", 28H (hand-built)
TyresSchwalbe Nobby Nic 62-622 / 29x2.4", Performance folding
Price£5,620
Rides similarly
Spot a mistake?
