Bike Finder · Lapierre
no image yet
Lapierre
Overvolt GLP III 2025
CurrentEnduro eMTBMature · 5.3/10iFreshness 5.3/10
Motor
Bosch Performance Line CX-R · 85Nm · 600W
Battery
Bosch PowerPack 800 · 800Wh
Travel F/R
170/173mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
23.4 kg
Price
From £7,599
View the Lapierre Overvolt GLP III on Lapierre’s site
Lapierre Overvolt GLP III 2025
From £7,599
EMTB Forums verdict
The Overvolt GLP III is Lapierre's e-enduro race weapon, built around an aluminium frame with a four-bar Horst-link layout, 173mm of rear travel and a 170mm fork. The mullet wheel setup, a 64-degree head angle and a steep 77-degree effective seat tube put it firmly in the bike-park and enduro-racing camp, while the short 440mm chainstay across every size is aimed at keeping things playful.
All three builds share the same Bosch power unit family. The Team and SE run the Bosch Performance CX Race motor; the Elite drops to the standard Performance Line CX. All carry the same 800Wh removable Bosch PowerPack and the KIOX 300 display, so range and assistance feel are consistent across the range.
On value, the Team at GBP 11,144 buys RockShox ZEB Ultimate and Vivid Ultimate suspension, SRAM X0 AXS T-Type wireless shifting, carbon eAM+ wheels and a claimed 23.4kg weight. The SE at GBP 10,698 swaps to Fox Factory 38 and Float X Factory damping with the same X0 AXS drivetrain and DT Swiss HX1501 wheels. The Elite at GBP 7,599 is the clear value pick: Fox Performance Elite suspension, a cable-actuated Shimano XT 12-speed drivetrain and an alloy wheelset, for several thousand pounds less than its siblings.
Reach runs from 435mm on the S to 505mm on the XL, with seat tubes kept short (390 to 460mm) to free up dropper insertion and lower the standover. It is a long, slack, gravity-focused chassis rather than an all-day trail tourer.
💬 Forum discussion
Lapierre overvolt 727i first impression.
9 replies · 5.9k views · last reply 88 months ago
Join the discussion →
Bike geometry diagram
SMLXL
Reach435 mm460 mm480 mm505 mm
Stack629 mm638 mm647 mm656 mm
Seattube390 mm400 mm430 mm460 mm
Chainstay440 mm440 mm440 mm440 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)77°77°77°77°
Wheelbase1225 mm1279 mm1308 mm
Headtube110 mm120 mm130 mm140 mm
Front Centre785 mm*839 mm*868 mm*
Trims · 3
Elite
£7,599
SE
£10,698
Team
£11,144
MotorBosch Performance Line CX Gen 4 · 85 NmBosch Performance Line CX-R · 85 NmBosch Performance Line CX-R · 85 Nm
BatteryBosch PowerPack 800 · 800 Wh · all trims
Travel F/R170/173 mm · all trims
FrameAluminium · all trims
ForkFOX Factory 38 Float Performance Elite GRIP X2 170 mmFox 38 Float Factory Kashima Grip 2 boost 15x110, 170mm travel (29")RockShox ZEB Ultimate Charger 3.1 RC2 170 mm
ShockFOX Factory Float X Performance Elite 2pos 205x65mm TrunnionFOX Factory Float X Performance Elite 2pos 205x65mm TrunnionRockShox Vivid Ultimate, 2-Pos Lever, 205x65mm Trunnion
StemLapierre Thirty Five alloy 0deg, diameter 35mm, L: 35mm (S/M), 45mm (L/XL)Lapierre Thirty Five alloy 0deg, diameter 35mm, L: 35mm (S/M), 45mm (L/XL)Renthal Apex, diameter 35mm, L: 33mm (S/M), 40mm (L/XL)
HandlebarLapierre Thirty Five 6061DB, Width: 800mm, Rise: 30mm, diameter 35mmLapierre Thirty Five 6061DB, Width: 800mm, Rise: 30mm, diameter 35mmRenthal Fatbar, Width: 800mm, Rise: 30mm, diameter 35mm
GripsLapierre grips, small diameter
SaddleSelle Royal Terra Aidon X5 145mm S-Alloy MobiusSelle Royal Terra Ridon X3 145mm Kium MobiusSelle Royal Terra Ridon X3 145mm Kium Mobius
SeatpostLapierre dropper by JD YSI05, diameter 31.6mm, travel 125mm (S), 150mm (M), 170mm (L), 200mm (XL)Lapierre dropper by JD YSI05, diameter 31.6mm, travel 125mm (S), 150mm (M), 170mm (L), 200mm (XL)SRAM Reverb AXS, diameter 31.6mm, travel 125mm (S), 150mm (M), 170mm (L,XL)
BrakesShimano Deore XT 4 pistons hydraulic disc, 203 mmSRAM Maven Silver 4 pistons, 200 mmSRAM Maven Ultimate 4 pistons, 220 mm
Rear derailleurShimano Deore XT 12s Shadow+SRAM X0 Eagle AXS T-TYPE, 12sSRAM X0 Eagle AXS T-TYPE, 12s
CrankE13 Helix Core 160mm + E13 Helix Core steel chainring 34T 55CLE Thirteen Race Carbon + SRAM XX T-TYPE 55CLE Thirteen Race Carbon + SRAM XX T-TYPE 55CL
ShiftersSRAM AXS Pod 12sSRAM AXS Pod 12s
CassetteShimano SLX CS-M7100 10-51T 12sSRAM XS 1295 T-TYPE 10-52T 12sSRAM XS 1295 T-TYPE 10-52T 12s
ChainShimano CN-M7100 12sSRAM X0 T-TYPE Powerlock 12sSRAM X0 T-TYPE 12s
DrivetrainShimano Deore XT 12s Shadow+; E13 Helix Core 160mm + E13 Helix Core steel chainring 34T 55CL; Shimano SLX CS-M7100 10-51T 12s; Shimano CN-M7100 12sSRAM X0 Eagle AXS T-TYPE, 12s; E Thirteen Race Carbon + SRAM XX T-TYPE 55CL; SRAM AXS Pod 12s; SRAM XS 1295 T-TYPE 10-52T 12s; SRAM X0 T-TYPE Powerlock 12sSRAM X0 Eagle AXS T-TYPE, 12s; E Thirteen Race Carbon + SRAM XX T-TYPE 55CL; SRAM AXS Pod 12s; SRAM XS 1295 T-TYPE 10-52T 12s; SRAM X0 T-TYPE 12s
WheelsLapierre eAM+ Alloy 32H Front: 622x33c J-Bend / Rear: 584x35c J-BendDT Swiss HX1501 Spline One front: 622x30, rear: 584x30, XD DriverLapierre eAM+ carbon, front: 622x30 Straight pull, rear: 584x33 J-bend, Tubeless Ready
TyresSchwalbe front: 62-622 Magic Mary Evo 67TPI Super Trail Addix Ultra Soft TR / rear: 65-584 Big Betty 67TPI Super Trail Addix Soft TRFront: Schwalbe Magic Mary Evo Super Trail TLE Addix Ultra Soft 62-622 67TPI / Rear: Schwalbe Big Betty Super Trail TLE Addix Soft 62-584 67TPISchwalbe front: 62-622 Magic Mary Evo 67TPI Super Trail Addix Ultra Soft TR / rear: 65-584 Big Betty 67TPI Super Trail Addix Soft TR
Weight23.4 kg
Price£7,599£10,698£11,144
Rides similarly
Spot a mistake?
