A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Remote 2022
Simple alloy hardtail with modest Shimano assistance for casual trail use
The 2022 Kona Remote is a 29in aluminium hardtail trail eMTB built on a Kona 6061 butted alloy frame derived from the Honzo. It runs a Shimano STEPS E7000 motor (250W, 60Nm) with an in-tube 504Wh battery, and pairs 140mm of Suntour Zeron35 front travel with a hardtail rear for a simple, practical package aimed at riders dipping a toe into e-MTB.
The single build is value-focused Shimano throughout: a 1x10 Deore drivetrain with an 11-46t cassette and 34t chainring, MT410 hydraulic brakes on a 203mm front and 180mm rear rotor, and a TranzX internal dropper. Rolling kit is WTB ST i35 rims wrapped in Maxxis Minion DHF 2.6in front and DHR II 2.4in rear, giving it more grip and descending intent than a typical entry hardtail.
Geometry is trail-oriented but conservative by later standards, with a fixed 66 degree head angle and 76.1 degree seat angle across all four sizes, reach growing from 425mm on the S to 510mm on the XL, short 435mm chainstays and a 320mm BB height. It sits below the full-suspension Remote 160 and shorter-travel Remote 130 in Kona's 2022 e-MTB range.
This bike is discontinued and was only sold as one unnamed build, so availability is limited to remaining stock and the used market. There is no owner forum history captured here, so no reliability or long-term ride data is asserted. Launch price was listed at 4,799 USD; a genuine GBP RRP was not verified this session.
Short 435mm rear and a lighter build — easy to pop, manual and throw around.
Balanced front-to-rear in L (FC:RC 1.83) — weight sits evenly between the wheels.
Climbs well — a 76.1° seat keeps the front planted. 250W of peak power and 60Nm of torque.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Lightweight · Cross-Country bikes (from 70 bikes in the database)
| S | M | L | XL | |
| Reach | 425 mm | 450 mm | 475 mm | 510 mm |
| Stack | 645 mm | 650 mm | 659 mm | 668 mm |
| Seattube | 385 mm | 410 mm | 450 mm | 485 mm |
| Chainstay | 435 mm | 435 mm | 435 mm | 435 mm |
| Headtube Angle | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 76.1° | 76.1° | 76.1° | 76.1° |
| Wheelbase | 1175 mm | 1202 mm | 1231 mm | 1270 mm |
| Headtube | 115 mm | 120 mm | 130 mm | 140 mm |
| BB Height | 320 mm | 320 mm | 320 mm | 320 mm |
| Standover | 736 mm | 736 mm | 736 mm | 736 mm |
| Front Centre | 740 mm* | 767 mm* | 796 mm* | 835 mm* |
| FC:RC | 1.70 | 1.76 | 1.83 | 1.92 |
Trims · 1
Base $4,799 | |
| Motor | Shimano E7000 · 60 Nm |
| Battery | Shimano BT-E8035 · 504 Wh |
| Travel F/R | 140/? mm |
| Frame | Kona 6061 Aluminum Butted |
| Fork | Suntour Zeron35 140mm Tapered 110 Spacing |
| Headset | FSA No.57B |
| Stem | Kona XC/BC 35 |
| Handlebar | Kona XC/BC 35 |
| Grips | Kona Key Grip |
| Saddle | WTB Volt |
| Seatpost | TranzX Dropper Internal 31.6mm |
| Brakes | Shimano MT410 Hydraulic (Shimano Deore Hydraulic Disc); front rotor Shimano RT30 203mm, rear rotor Shimano RT30 180mm |
| Rear derailleur | Shimano Deore |
| Crank | Shimano E8000 crankarms, 34t chainring |
| Shifters | Shimano Deore |
| Cassette | Shimano Deore 11-46t 10spd |
| Chain | KMC X10 |
| Drivetrain | Shimano Deore; Shimano E8000 crankarms, 34t chainring; Shimano Deore; Shimano Deore 11-46t 10spd; KMC X10 |
| Wheels | WTB ST i35 TCS 2.0 |
| Tyres | Front: Maxxis Minion DHF EXO TR DUAL 29x2.6"; Rear: Maxxis Minion DHR II EXO TR DUAL 29x2.4" WT |
| Price | $4,799 |
Rides similarly
Spot a mistake?
