Bike Finder · Kona
Kona Remote Ctrl
Kona
Remote Ctrl 2020
DiscontinuedTrail eMTBLegacy · 1/10iFreshness 1/10
Aluminium full-suspension eMTB with Bosch Performance CX motor and 500Wh battery
Travel F/R
150/150mm
Wheels
27.5F/27.5R
Frame
Aluminium
Weight
25.31 kg
Price
£4,499
View the Kona Remote Ctrl on Kona’s site
Kona Remote Ctrl 2020
From £4,499
EMTB Forums verdict
The Kona Remote Ctrl 2020 is the Canadian brand's aluminium trail eMTB, built around Bosch's Performance Line CX Gen 4 motor on a single-pivot rear end. It runs 160 mm of fork travel and 150 mm rear, with a removable 500 Wh PowerTube battery and a claimed 25.31 kg system weight. Headline numbers: 85 Nm of torque, 600 W peak power, a 66 degree head angle, a long 485 mm chainstay and reach growing from 425 to 510 mm across four sizes. £4,499 for the base trim at launch. Production status: discontinued. Community verdict: a sensible, well-priced trail platform that served well as Kona's main eMTB before the brand stepped back from the eMTB market.
Drive system and range. The Bosch Performance Line CX Gen 4 is the most-deployed motor in eMTB and the proven workhorse, with 85 Nm of torque and 600 W of peak power. The motor weighs 2.9 kg. The 500 Wh PowerTube battery is removable for off-bike charging and gives moderate trail-day range, with mixed-terrain use typically reaching 35 to 55 km depending on assist mode and rider weight. Bosch's app-driven firmware updates through Bosch Flow have steadily refined the Gen 4 motor's character over its service life, including the PU2.0 update that has lifted earlier Bosch motors closer to Gen 5 performance.
Geometry and handling. A 66 degree head angle is conservative by modern trail standards, half a degree steeper than the now-common 65 degree norm. Reach grows from 425 mm in SM to 510 mm in XL. The 485 mm chainstay is properly long for a trail eMTB, identical across all sizes, which favours stable climbing and straight-line composure but limits agile direction-change for smaller sizes. Wheelbases run 1237 to 1327 mm. The single-pivot rear suspension is simple, durable and predictable, though it sits behind multi-link Horst designs on pedal-bob isolation and bump-absorption sophistication.
Build and value. One trim at launch, £4,499. The Remote Ctrl shipped with Maxxis DHF MaxxTerra front and DHR MaxxTerra rear tyres, with mid-tier suspension and Shimano-or-SRAM 12-speed drivetrains depending on dealer stock and configuration. The standout strength was the price-to-spec ratio at launch: a sub-£4,500 Bosch CX Gen 4 alloy trail eMTB with a removable battery and Maxxis MaxxTerra rubber was genuinely competitive for the 2020 market. The questionable note is the long chainstay and conservative head angle, which positioned the Remote Ctrl as a touring-trail tool rather than an aggressive descender.
Community-verified strengths. Owners have praised the Remote Ctrl's stability and tyre choice, with the Maxxis DHF/DHR MaxxTerra combination drawing positive comments for mixed-trail grip. The Bosch Smart System pairing with Kiox displays integrates well with the cockpit. The aluminium chassis durability has held up through community ownership, with the simple single-pivot rear end requiring minimal long-term maintenance.
Caveats and known gripes. Kona discontinued their eMTB line, which means new buyers will need to confirm warranty support arrangements before purchasing remaining stock. The 500 Wh battery is small by 2025 standards: most current rivals run 625 to 800 Wh capacity. The single-pivot suspension layout is functional but lacks the small-bump compliance of Horst Link or VPP rivals. The 25.31 kg system weight is mid-pack for an aluminium full-power eMTB. The Bosch CX Gen 4 motor is solid but a generation behind the current Gen 5 with its 120 Nm and 750 W peak. And the 66 degree head angle and 485 mm chainstay tilt the bike firmly toward stable trail use rather than modern aggressive geometry.
Verdict. The Remote Ctrl 2020 suits the buyer looking for an end-of-line discount on a sensibly proportioned trail eMTB with proven Bosch reliability, particularly for tourist and gentle trail use. Riders wanting current production status, modern geometry, bigger batteries or newer Bosch CX Gen 5 power should look at the Cannondale Moterra Neo, the Marin Alpine Trail E or the Trek Powerfly+ FS. Production status: discontinued.
💬 Forum discussion
Kona Remote 160
42 replies · 17.9k views · last reply 69 months ago
Join the discussion →
“Kona’s got a bike worth looking at. Definitely real Trail Bike geometry in keeping with their Process series. Not very many eMTB truly this progressive in the geometry. Rides great. Fits 27+ or 29 widetrail. Rides great! Shimano drive.…”
— sparrow · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach425 mm450 mm475 mm510 mm
Stack626 mm626 mm626 mm635 mm
Chainstay485 mm485 mm485 mm485 mm
Headtube Angle66°66°66°66°
Seattube Angle (eff)74.3°74.3°74.3°74.2°
BB Drop15 mm15 mm15 mm15 mm
Wheelbase1237 mm1262 mm1287 mm1327 mm
Headtube130 mm130 mm130 mm140 mm
Standover790 mm778 mm770 mm790 mm
Front Centre752 mm777 mm802 mm842 mm
Trims · 2
Base
£4,499
Remote CTRL
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 500 · 500 Wh · all trims
Travel F/R150/150 mm · all trims
FrameKona 6061 butted aluminium · all trims
ForkRockShox Yari RC Motion Control DebonAir, 150mm · all trims
ShockRockShox Monarch Plus R Solo Air · all trims
HeadsetFSA No.57B · all trims
StemKona XC/BC 35 · all trims
HandlebarKona XC/BC 35 · all trims
GripsKona Key Grip · all trims
SaddleWTB Volt Sport · all trims
SeatpostTrans-X Dropper Internal 30.9mm · all trims
BrakesSRAM Guide RE, 200mm front / 180mm rear rotorSRAM Guide RE
Rear derailleurSRAM NX · all trims
CrankSRAM EX1 · all trims
ShiftersSRAM NX · all trims
CassetteSRAM PG1130, 11-42t, 11spd · all trims
ChainSRAM NX · all trims
DrivetrainSRAM NX; SRAM EX1; SRAM NX; SRAM PG1130, 11-42t, 11spd; SRAM NX · all trims
WheelsWTB ST i40 TCS rims on Formula hubs (110x15mm front / 148x12mm rear) · all trims
TyresMaxxis Rekon EXO TR DUAL 27.5x2.8 front + rearMaxxis Rekon EXO TR DUAL 27.5x2.8"
Weight25.31 kg
Price£4,499
Rides similarly
Spot a mistake?
