Bike Finder · Kona
Kona Remote 160
Kona
Remote 160 2022
DiscontinuedLightweight · EnduroLegacy · 0/10iFreshness 0/10
Straightforward alloy enduro with modest range and easy power
Motor
Shimano E7000 · 60Nm · 250W
Battery
Shimano BT-E8035 504Wh
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£6,000
View the Kona Remote 160 on Kona’s site
Kona Remote 160 2022
From £5,999
EMTB Forums verdict
The 2022 Kona Remote 160 was the affordable, alloy long-travel option in Kona's e-MTB range: a 29in full-suspension enduro bike with 160mm of travel at both ends, built around a Kona 6061 aluminium frame and Kona's Beamer Independent Suspension. It sat below the pricier Remote 160 DL and above the shorter-travel Remote 130 and the Remote hardtail.
Where the flagship 160 DL ran Shimano's newer EP8 motor and a larger battery, this base Remote 160 used the older Shimano E7000 mid-drive with a 504Wh pack, a Shimano SC-E7000 display and a value-focused build: a RockShox 35 Gold RL fork, RockShox Deluxe Select+ shock, SRAM Guide RE brakes on 200mm rotors, and a 10-speed microSHIFT Advent X drivetrain. Grippy Maxxis Minion DHF/DHR II EXO+ tyres and a TranzX dropper rounded out a sensible, hard-wearing spec at a UK RRP of GBP 5,999.99.
The geometry is firmly enduro for its era: a slack 64.0 degree head angle held across all four sizes, a moderate 75 to 75.1 degree effective seat angle, fixed 435mm chainstays and a low 350mm bottom bracket. Reach runs from 417mm on the S to 502mm on the XL, so the fit is progressive without being extreme by 2022 standards.
The Remote 160 is discontinued. Kona replaced the Remote line for 2024 with a redesigned Remote family (including the Remote 160 and Remote 160 DL on newer Shimano EP8 power), so this E7000-powered alloy 160 is very much an end-of-generation model rather than a current option.
Geometry read
Size
Descending
73
Slack 64° head angle, 160mm travel and a long 1254mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
57
Size balance
77
Front-long in L: 819mm front centre on 435mm stays (FC:RC 1.88). Planted and composed; rewards a forward, attacking stance.
Technical climbing
38
A workmanlike climber — expect to put in more rider effort on the steep stuff. 250W of peak power and 60Nm of torque.
Watch out forL runs front-long (FC:RC 1.88).
A 819mm front centre on 435mm stays means taller riders must actively weight the front to keep it gripping. The chainstay stays 435mm on every size, so L feels more front-long than the smaller sizes.
How it stacks up vs other Lightweight · Enduro bikes (from 19 bikes in the database)
Battery504 Wh72 Wh above average
Motor torque60 Nmclass-leading torque
Value for money69/100from £6,000 · comparable bikes ~£6,895
💬 Forum discussion
Kona Remote 160
42 replies · 18.1k views · last reply 70 months ago
Join the discussion →
“Kona’s got a bike worth looking at. Definitely real Trail Bike geometry in keeping with their Process series. Not very many eMTB truly this progressive in the geometry. Rides great. Fits 27+ or 29 widetrail. Rides great! Shimano drive.…”
— sparrow · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach417 mm442 mm467 mm502 mm
Stack620 mm625 mm635 mm644 mm
Seattube385 mm410 mm450 mm485 mm
Chainstay435 mm435 mm435 mm435 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)75.1°75°74.9°74.8°
Wheelbase1198 mm1225 mm1254 mm1294 mm
Headtube115 mm120 mm130 mm140 mm
BB Height350 mm350 mm350 mm350 mm
Standover752 mm767 mm765 mm778 mm
Front Centre763 mm*790 mm*819 mm*859 mm*
FC:RC1.751.821.881.97
Trims · 1
Base
£6,000
MotorShimano E7000 · 60 Nm
BatteryShimano BT-E8035 504Wh · 504 Wh
Travel F/R160/160 mm
FrameKona 6061 Aluminum Butted
ForkRockShox 35 Gold RL DebonAir 160mm Tapered 110 Spacing
ShockRockShox Deluxe Select + Trunnion
HeadsetFSA No.57E
StemKona XC/BC 35
HandlebarKona XC/BC 35
GripsKona Key Grip
SaddleWTB Volt
SeatpostTranzX Dropper Internal 31.6mm
BrakesSRAM Guide RE (hydraulic disc); brake levers SRAM Guide RE; front and rear rotor SRAM Centerline 200mm
Rear derailleurMicroshift Advent X
CrankShimano E8000, 34t
ShiftersMicroshift Advent X
CassetteMicroshift Advent X 11-48t 10spd
ChainKMX X10
DrivetrainMicroshift Advent X; Shimano E8000, 34t; Microshift Advent X; Microshift Advent X 11-48t 10spd; KMX X10
WheelsWTB ST i30 TCS 2.0
TyresFront: Maxxis Minion DHF EXO+ TR 3C 29x2.5" WT, Rear: Maxxis Minion DHR II EXO+ TR 3C 29x2.5" WT
Price£6,000
Rides similarly
Spot a mistake?
